iPAQ repair
Old March 21st 08, 05:47 PM posted to rec.aviation.soaring
Default iPAQ repair
I know this a way off topic, but I have a 4705 that won't boot any
more. Battery is fully charged, I've tried to 'hard reset' it, but it
gets to the initial splash screen and stops. Does anyone repair these
things? I'll use my 2495 if I can't get the 4705 fixed, but the 4705
display IS easier to read.
TIA
Old March 21st 08, 06:31 PM posted to rec.aviation.soaring
chipsoars
Default iPAQ repair
more. *Battery is fully charged, I've tried to 'hard reset' it, but it
gets to the initial splash screen and stops. *Does anyone repair these
things? *I'll use my 2495 if I can't get the 4705 fixed, but the 4705
TIA
I have had good and fast turn-around repairs done by: www.pocketpctechs.com
Chip F.
Old March 21st 08, 10:52 PM posted to rec.aviation.soaring
Default iPAQ repair
TIA
I have had good and fast turn-around repairs done by: *www.pocketpctechs..com
Chip F.
Thanks Chip. I called them and they assured me it's fixable. All it
takes is money!
Old March 22nd 08, 02:38 PM posted to rec.aviation.soaring
November Bravo
Default iPAQ repair
TIA
Chip F.
takes is money!
If you are sending it to pocketpctechs, have the internal battery
replaced as well. The internal battery is specialized, extremely hard
to find. Unfortunately, Pocketpctech has them on backorder and they
are not expecting shipment until April. If your internal battery is
dead, you will continue to experience problems. I myself am going for
the memory upgrade as well. Good luck.
Old March 23rd 08, 03:59 PM posted to rec.aviation.soaring
Default iPAQ repair
TIA
I have had good and fast turn-around repairs done by: *www.pocketpctechs.com
Chip F.
Thanks Chip. *I called them and they assured me it's fixable. *All it
takes is money!
replaced as well. *The internal battery is specialized, extremely hard
to find. *Unfortunately, Pocketpctech has them on backorder and they
are not expecting shipment until April. *If your internal battery is
dead, you will continue to experience problems. *I myself am going for
the memory upgrade as well. *Good luck.- Hide quoted text -
- Show quoted text -
Thanks NB, will do. I'm not in a huge hurry since my HX2495 is setup
up, so that will work for me.
Old March 24th 08, 06:59 PM posted to rec.aviation.soaring
Default iPAQ repair
Considering the obvious first, which you certainly have, but the
battery has to be locked for the HP to boot. Did you check if the lock
switch at the bottom of the unit is moved towards the "locked"
position?
I wish it was only that simple
Cheers
Robert
Old April 3rd 08, 04:47 PM posted to rec.aviation.soaring
Default iPAQ repair
gets to the initial splash screen and stops. *Does anyonerepairthese
TIA
CLOSURE
With the help of those here on RAS who pointed me to a GOOD forum, my
HX4705 is back in service. Thanks to all!
New iPAQ 210 Paul Remde Soaring 2 September 7th 07 05:05 PM
FS iPaq Ed Hollestelle Soaring 6 April 28th 05 12:28 AM
New iPAQ 4700 Paul Remde Soaring 2 October 9th 04 11:06 PM
New iPAQ Jacek Kobiesa Soaring 7 September 26th 04 06:44 PM
MLR+IPAQ->OLC? jaro Soaring 0 June 23rd 04 03:06 PM
