Seeking FAA designee in southern Arizona (Phoenix/Tucson)
Old March 21st 08, 07:20 PM posted to rec.aviation.soaring
Tuno
Default Seeking FAA designee in southern Arizona (Phoenix/Tucson)
If anyone knows an FAA designee in Arizona who can do an experimental
C of A on a new glider, please let me know ASAP. (Not Mike Moyer at
the Scottsdale FSDO -- he's busy until mid April.)
Advance thanks --
~ted/2NO
480-296-9022
ps Also -- I have conflicting advice about whether a FSDO in one area
(say, Houston) can issue an Experimental C of A (racing/exhibition)
for another area (say, Phoenix). Does anyone have any solid
information on this?
Old March 22nd 08, 01:27 AM posted to rec.aviation.soaring
Frank Whiteley
Advance thanks --
~ted/2NO
480-296-9022
Don't know the answer to the PS.
Here's the list.
http://www.faa.gov/other_visit/aviat...RDirectory.pdf
Presuming you have your N-number, look for AZ _Maintenance_ DAR's that
are authorized Function code 26. I count 9 total maintenance DARs in
AZ with function 26. Whether they all will do gliders, I don't know.
Codes are defined in FAA Order 8100.8C
(4) Code 26 -- Issue recurrent/original special airworthiness
certificates, in the
experimental category, for the purposes of operating exhibition or air
racing on U.S.-registered
aircraft located in the United States.
Good luck,
Frank Whiteley
ps: maybe someone will have a name and number handy
Old March 22nd 08, 01:37 AM posted to rec.aviation.soaring
BT
Its' a long way to go, but I know a DAR in El Monte CA, and
gliders/motorgliders a specialty.
And yes, he can cross FSDO boundaries.
BT
"Tuno" wrote in message
Advance thanks --
~ted/2NO
480-296-9022
Old March 22nd 08, 02:12 AM posted to rec.aviation.soaring
Frank Whiteley
BT
They may be authorized to do so IAW para 904 of FAA Order 8100.8C. If
you're in a hurry, suggest checking with the local guys first.
Frank Whiteley
Old March 22nd 08, 05:11 PM posted to rec.aviation.soaring
Tuno
BT,
Can you send me his contact info please?
-ted/2NO
D-M AFB, Tucson, AZ Lonnie[_2_] Aviation Photos 12 September 9th 07 04:55 AM
Southern Arizona Storm Ken Reed Piloting 14 June 10th 06 04:01 AM
Southern Arizona Storm Ken Reed Owning 12 June 10th 06 04:01 AM
FS: Russia AC-4c (Tucson, AZ, USA) LOV2AV8 Soaring 0 May 16th 06 08:51 PM
Phoenix Arizona airspace Andy Soaring 0 August 3rd 05 12:24 AM
