Do ANR and other headsets usually provide sidetone? (sidetone = a small part
of your speech is fed back to your phones). I've used some aviation headsets with no sidetone, it's a bit like talking with your fingers in your ears, not too good. Is aircrafts sidetone generation an intregal part of the aircrafts intercom system? The reason I ask as once being a local radio presenter and maritime comms I don't know of anytime where sidetone was absent from headphones or headsets. Mike |
It's not the headset. Its' the device it's plugged into. ANR or passive
makes no difference. -- ------------------------------- Travis Lake N3094P PWK "Mike Gilmour" wrote in message ... Do ANR and other headsets usually provide sidetone? (sidetone = a small part of your speech is fed back to your phones). I've used some aviation headsets with no sidetone, it's a bit like talking with your fingers in your ears, not too good. Is aircrafts sidetone generation an intregal part of the aircrafts intercom system? The reason I ask as once being a local radio presenter and maritime comms I don't know of anytime where sidetone was absent from headphones or headsets. Mike |
![]() Ok, thanks however the Lightspeed Thirty 3G has 'Personal Side-Tone EQ' which seems to imply headset control in that case? Mike "Travis Marlatte" wrote in message ... It's not the headset. Its' the device it's plugged into. ANR or passive makes no difference. -- ------------------------------- Travis Lake N3094P PWK "Mike Gilmour" wrote in message ... Do ANR and other headsets usually provide sidetone? (sidetone = a small part of your speech is fed back to your phones). I've used some aviation headsets with no sidetone, it's a bit like talking with your fingers in your ears, not too good. Is aircrafts sidetone generation an intregal part of the aircrafts intercom system? The reason I ask as once being a local radio presenter and maritime comms I don't know of anytime where sidetone was absent from headphones or headsets. Mike |
Mike,
has 'Personal Side-Tone EQ' which seems to imply headset control in that case? That's just marketing speak for it having the option of enhancing the sound that comes into it. Makes music sound much better. As Travis said, the sidetone comes from the intercom/radio. -- Thomas Borchert (EDDH) |
On Mar 23, 9:10 am, Thomas Borchert
wrote: Mike, has 'Personal Side-Tone EQ' which seems to imply headset control in that case? That's just marketing speak for it having the option of enhancing the sound that comes into it. Makes music sound much better. As Travis said, the sidetone comes from the intercom/radio. -- Thomas Borchert (EDDH) But there is no inherent reason why side tone cannot be provided within the headset. It's got a battery and an amplifier, so it would not be a big stretch to redirect the microphone signal into the headset. However, when the sidetone is generated by the intercom, and you can hear yourself speak, you can safely assume that the other party can hear you too. That would not be the case if the side tone is generated by the headset. |
Andrew,
That would not be the case if the side tone is generated by the headset. Well, it would diminish battery life, of course. Also, the microphone is powered by the intercom/radio through its plug. Interestingly, the new Lightspeed Zulu has an option to power the mic from the headset battery, since it can be used as a Bluetooth headset for your phone and you might want to do that with aircraft power of. -- Thomas Borchert (EDDH) |
On Sun, 23 Mar 2008 10:20:22 -0000, "Mike Gilmour"
wrote: Do ANR and other headsets usually provide sidetone? (sidetone = a small part of your speech is fed back to your phones). I've used some aviation headsets with no sidetone, it's a bit like talking with your fingers in your ears, not too good. Is aircrafts sidetone generation an intregal part of the aircrafts intercom system? The reason I ask as once being a local radio presenter and maritime comms I don't know of anytime where sidetone was absent from headphones or headsets. I don't think the sidetone ever generates in the headset, it's a function of the audio panel isn't it?? |
![]() "Peter Clark" wrote in message ... On Sun, 23 Mar 2008 10:20:22 -0000, "Mike Gilmour" wrote: Do ANR and other headsets usually provide sidetone? (sidetone = a small part of your speech is fed back to your phones). I've used some aviation headsets with no sidetone, it's a bit like talking with your fingers in your ears, not too good. Is aircrafts sidetone generation an intregal part of the aircrafts intercom system? The reason I ask as once being a local radio presenter and maritime comms I don't know of anytime where sidetone was absent from headphones or headsets. I don't think the sidetone ever generates in the headset, it's a function of the audio panel isn't it?? It is apparently, therefore some audio panels don't provide sidetone. |
On Sun, 23 Mar 2008 14:20:49 -0000, "Mike Gilmour"
wrote: "Peter Clark" wrote in message .. . On Sun, 23 Mar 2008 10:20:22 -0000, "Mike Gilmour" wrote: Do ANR and other headsets usually provide sidetone? (sidetone = a small part of your speech is fed back to your phones). I've used some aviation headsets with no sidetone, it's a bit like talking with your fingers in your ears, not too good. Is aircrafts sidetone generation an intregal part of the aircrafts intercom system? The reason I ask as once being a local radio presenter and maritime comms I don't know of anytime where sidetone was absent from headphones or headsets. I don't think the sidetone ever generates in the headset, it's a function of the audio panel isn't it?? It is apparently, therefore some audio panels don't provide sidetone. That I can attest to. Some older panels I've run into don't, or the sidetone circuit is busted. |
Mike Gilmour wrote:
Do ANR and other headsets usually provide sidetone? This is not a headset issue. This is an intercom issue. And usually the answer is yes. Most if not all modern (in the past 10-15 years) aviation radios and intercoms have built in sidetone functionality. |
Headsets | tony roberts | Piloting | 4 | September 8th 06 03:46 AM |
Headsets | tony roberts | Owning | 2 | September 2nd 06 07:30 PM |
about headsets | Sylvain | Piloting | 0 | August 11th 06 05:36 AM |
In-Ear Headsets | John Clonts | Piloting | 3 | November 22nd 05 09:19 PM |
Anyone tried any of the "in the ear" headsets? | Charles | General Aviation | 4 | August 14th 05 01:41 PM |
