![]() Is it possible (is it likely) that we will see a diesel aircraft engine small enough for a Piper Cub? Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 new from HarperCollins www.FlyingTigersBook.com |
Cubdriver usenet AT danford DOT net wrote in
: Is it possible (is it likely) that we will see a diesel aircraft engine small enough for a Piper Cub? Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 new from HarperCollins www.FlyingTigersBook.com Some guy put a mercedes diesel on a Piet years ago. Very nice looking installation in the traditional Piet style. He even had a three pointed star on the radiator. I wouldn't fancy propping it though. Bertie |
On Mar 23, 2:25*pm, Cubdriver usenet AT danford DOT net wrote:
Is it possible (is it likely) that we will see a diesel aircraft engine small enough for a Piper Cub? Blue skies! -- Dan Ford Almost. The local A&P community college here runs an STC'd diesel 172. The engine is made in Germany. They run it on French Fries. -Robert |
Sacre Bleu. Don't the French Fries clog fuel lines? :-)
"Robert M. Gary" wrote in : Almost. The local A&P community college here runs an STC'd diesel 172. The engine is made in Germany. They run it on French Fries. -- |
On Mar 23, 10:34*pm, John Godwin wrote:
Sacre Bleu. *Don't the French Fries clog fuel lines? :-) I'll tell you, you can smell if that plane is in the hanger before you open the door! Smells like McD's. Kind of takes your desire to eat lunch away; I can't imagine what it must be like flying it. -Robert |
Robert M. Gary wrote:
On Mar 23, 2:25 pm, Cubdriver usenet AT danford DOT net wrote: Is it possible (is it likely) that we will see a diesel aircraft engine small enough for a Piper Cub? Blue skies! -- Dan Ford Almost. The local A&P community college here runs an STC'd diesel 172. The engine is made in Germany. They run it on French Fries. -Robert The engine is made by Thielert in Germany. It is a modified Mercedes common-rail diesel engine. For more information, go to http://www.centurion-engines.com/. By the way, it runs on the big-airplane food: JET-A1. -- Tauno Voipio (CPL(A)) tauno voipio (at) iki fi |
Airbus wrote:
In article , says... Robert M. Gary wrote: On Mar 23, 2:25 pm, Cubdriver usenet AT danford DOT net wrote: Is it possible (is it likely) that we will see a diesel aircraft engine small enough for a Piper Cub? Blue skies! -- Dan Ford Almost. The local A&P community college here runs an STC'd diesel 172. The engine is made in Germany. They run it on French Fries. -Robert The engine is made by Thielert in Germany. It is a modified Mercedes common-rail diesel engine. For more information, go to http://www.centurion-engines.com/. By the way, it runs on the big-airplane food: JET-A1. -- I am personally aware of two such planes (Thielert-powered C-172's) which have been removed from service due to unexpected, and as yet unexplained engine stoppages. . . Anyone else heard of this? Thielert has had its portion of new-design woes: - problems in fuel and cooling plumbing, - gearbox / clutch problems, - broken high-pressure pumps. AFAIK, no real problems with the most feared component, FADEC (Full Authority Digital Engine Control). One twin with Thielerts came down immediately after take-off in Germany, when its electrical system collapsed. The engines had been started with external power and the battery was not in system at all. The procedure was prohibited in the operation manual. The electrical systems have been changed so that it is not anymore possible to repeat the preformance. This was actually more an airframe problem than an engine problem. At least one of the high-pressure pump failures happened here for the Cessna of our club. It seems that the pump had been dry some 5 hours before the failure. The Thielert manual especially warns running the pump dry, and if so happens, there should be an inspection of the pump before the next flight. -- Tauno Voipio tauno voipio (at) iki fi |
Tauno Voipio wrote in
: Airbus wrote: In article , says... Robert M. Gary wrote: On Mar 23, 2:25 pm, Cubdriver usenet AT danford DOT net wrote: Is it possible (is it likely) that we will see a diesel aircraft engine small enough for a Piper Cub? Blue skies! -- Dan Ford Almost. The local A&P community college here runs an STC'd diesel 172. The engine is made in Germany. They run it on French Fries. -Robert The engine is made by Thielert in Germany. It is a modified Mercedes common-rail diesel engine. For more information, go to http://www.centurion-engines.com/. By the way, it runs on the big-airplane food: JET-A1. -- I am personally aware of two such planes (Thielert-powered C-172's) which have been removed from service due to unexpected, and as yet unexplained engine stoppages. . . Anyone else heard of this? Thielert has had its portion of new-design woes: - problems in fuel and cooling plumbing, - gearbox / clutch problems, - broken high-pressure pumps. AFAIK, no real problems with the most feared component, FADEC (Full Authority Digital Engine Control). One twin with Thielerts came down immediately after take-off in Germany, when its electrical system collapsed. The engines had been started with external power and the battery was not in system at all. The procedure was prohibited in the operation manual. The electrical systems have been changed so that it is not anymore possible to repeat the preformance. This was actually more an airframe problem than an engine problem. Bull****. Engine installation problem. Bertie |
Wind limits - small single engine aircraft | [email protected] | Piloting | 30 | February 7th 07 07:36 AM |
Help ! SMALL Radial engine | Chris Wertman | Home Built | 12 | July 18th 05 02:46 PM |
Small 4 stroke engine? | Ron Wanttaja | Home Built | 35 | July 2nd 05 07:25 PM |
What is the single-engine small plane with the best range? | Bob | Owning | 24 | February 19th 04 04:15 AM |
Help ! SMALL Radial engine | Chris Wertman | Military Aviation | 11 | January 4th 04 08:22 AM |
