Hello-
Is there some kind of easy trick to understanding what type of weather to expect at certain weather systems and fronts in term of explaining this to the DPE during the checkride? I am not trying to avoid learning weather theory...i just wonder if I am looking to far into the meaning of all the charts and symbols...i have no problem with the instructor pointing to a trough and asking what does this mean...Or asking me what an echo top means or anything...i just keep getting confused as to pressure systems... High Pressure Systems The weather is warm here and the visibility is good, atmosphere is stable. This makes me think of summer weather. The book says that visibility in terms of clouds is not good...am i missing something here... Low Pressure Systems The weather is cold here, visibility is poor and the atmosphere is less stable. This makes me think of winter weather. My confusion lies mainly with the visibility...i would think that a low system would have bad visibilty and be cloudy and high pressure system would have few clouds. Any advice or suggestions would be helpful. Thanks SD |
On Mar 26, 4:19*pm, Sushidot wrote:
Hello- Is there some kind of easy trick to understanding what type of weather to expect at certain weather systems and fronts in term of explaining this to the DPE during the checkride? *I am not trying to avoid learning weather theory...i just wonder if I am looking to far into the meaning of all the charts and symbols...i have no problem with the instructor pointing to a trough and asking what does this mean...Or asking me what an echo top means or anything...i just keep getting confused as to pressure systems... High Pressure Systems The weather is warm here and the visibility is good, atmosphere is stable. *This makes me think of summer weather. *The book says that visibility in terms of clouds is not good...am i missing something here... Low Pressure Systems The weather is cold here, visibility is poor and the atmosphere is less stable. *This makes me think of winter weather. My confusion lies mainly with the visibility...i would think that a low system would have bad visibilty and be cloudy and high pressure system would have few clouds. Any advice or suggestions would be helpful. Thanks SD Think of them as rivers. High Pressue is a soft flowing stream. Low Pressure is a raging rapid. -Robert |
Examiners are no better at understanding weather than the majority of
pilots, so I wouldn't expect an in-depth analysis. Which book makes the statement about clouds that you quote? A high pressure exists when air is descending, and when air descends it warms....making clouds less likely, not more likely. When it hits the surface, it spreads outward. A low pressure center exists when air is rising; rising air cools, and moisture condenses out as clouds and/or precipitation. Air moves inward toward the low pressure center (nature abhors a vacuum, right?). As a VFR pilot, you want to stay well clear of any location where the presence of visible moisture in the air reduces visibility. First clue is the temperature/dewpoint spread. T/DP at your departure airport should be getting larger as the day wears on....you don't want to come back from a cross-country and find that home base is socked in. Let's assume that you are going west to a destination airport; check its current METAR and those for a couple of hours previous. T/DP spread should be increasing with time. Check METARS for airports further west than your destination...is their weather getting better, or worse? Is it moving toward your destination? Now look over your shoulder to the east and check METARS to see if any reduced spreads are moving your way. Always fly toward improving weather. There are scads of web sites that discuss weather. Get familiar with the ADDS page and read the explanations provided with each chart. Bob Gardner "Sushidot" wrote in message ... Hello- Is there some kind of easy trick to understanding what type of weather to expect at certain weather systems and fronts in term of explaining this to the DPE during the checkride? I am not trying to avoid learning weather theory...i just wonder if I am looking to far into the meaning of all the charts and symbols...i have no problem with the instructor pointing to a trough and asking what does this mean...Or asking me what an echo top means or anything...i just keep getting confused as to pressure systems... High Pressure Systems The weather is warm here and the visibility is good, atmosphere is stable. This makes me think of summer weather. The book says that visibility in terms of clouds is not good...am i missing something here... Low Pressure Systems The weather is cold here, visibility is poor and the atmosphere is less stable. This makes me think of winter weather. My confusion lies mainly with the visibility...i would think that a low system would have bad visibilty and be cloudy and high pressure system would have few clouds. Any advice or suggestions would be helpful. Thanks SD |
"Sushidot" wrote in message ... High Pressure Systems The weather is warm here and the visibility is good, atmosphere is stable. This makes me think of summer weather. The book says that visibility in terms of clouds is not good...am i missing something here... Haze, smog and temperature inversions. Think of a smokey room. The warm, stable air causes the smoke to just hang there and the room gets stale, but turning on a fan will mix things up. Another way to think of it is that rain washes away haze which is why the air is so clear right after a thunderstorm has passed. So if you go flying on a nice summer afternoon, a few thousand feet up you're likely to climb above a haze layer that is difficult to see through. Low Pressure Systems The weather is cold here, visibility is poor and the atmosphere is less stable. This makes me think of winter weather. Visibility is poor if the air is saturated, but for a memory aid you can recall the most extreme-cold below-zero days, when the sky is sunny and the air is crystal clear. Or, recall looking out the window of a jet at cruise altitude. Low pressure and unlimited visibility, but sometimes it's turbulent. If it makes you feel any better, this stuff is hard to remember because as a private pilot, unless you're flying cross-country a lot you don't get much exposure to it and the knowledge is lost due to lack of recency. The main thing he'll want to know on the checkride is that you're able to identify bad or deteriorating weather--thunderstorms, lenticular clouds and their implications. I'd be pretty surprised if he asked you much beyond what's covered in the written in terms of charts and symbols and if he does, as long as you have a reference source for planning he probably won't abuse you too much for the PPL. He's going to focus more on your flying. For example, if you're flying cross-country in the northern hemisphere and you pick up an increasing wind from the left, it means you're probably flying toward low pressure (hurricanes spin counterclockwise and all you have to do to remember that is recall how Katrina pushed the water in from the Lake Ponchartrain as the storm passed to the east.) By knowing the direction that the weather system is rotating, for flight planning purposes you can determine which side of the system you want to fly in order to use the tailwind to your advantage. For your flight planning, as long as you have the basic idea and a good reference source such as the AVIATION WEATHER book by the FAA/NTSB, you'll probably do just fine. -c |
On Mar 27, 9:27 am, "gatt" wrote:
"Sushidot" wrote in message ... High Pressure Systems The weather is warm here and the visibility is good, atmosphere is stable. This makes me think of summer weather. The book says that visibility in terms of clouds is not good...am i missing something here... Haze, smog and temperature inversions. Think of a smokey room. The warm, stable air causes the smoke to just hang there and the room gets stale, but turning on a fan will mix things up. Another way to think of it is that rain washes away haze which is why the air is so clear right after a thunderstorm has passed. So if you go flying on a nice summer afternoon, a few thousand feet up you're likely to climb above a haze layer that is difficult to see through. Low Pressure Systems The weather is cold here, visibility is poor and the atmosphere is less stable. This makes me think of winter weather. Visibility is poor if the air is saturated, but for a memory aid you can recall the most extreme-cold below-zero days, when the sky is sunny and the air is crystal clear. Or, recall looking out the window of a jet at cruise altitude. Low pressure and unlimited visibility, but sometimes it's turbulent. If it makes you feel any better, this stuff is hard to remember because as a private pilot, unless you're flying cross-country a lot you don't get much exposure to it and the knowledge is lost due to lack of recency. The main thing he'll want to know on the checkride is that you're able to identify bad or deteriorating weather--thunderstorms, lenticular clouds and their implications. I'd be pretty surprised if he asked you much beyond what's covered in the written in terms of charts and symbols and if he does, as long as you have a reference source for planning he probably won't abuse you too much for the PPL. He's going to focus more on your flying. For example, if you're flying cross-country in the northern hemisphere and you pick up an increasing wind from the left, it means you're probably flying toward low pressure (hurricanes spin counterclockwise and all you have to do to remember that is recall how Katrina pushed the water in from the Lake Ponchartrain as the storm passed to the east.) By knowing the direction that the weather system is rotating, for flight planning purposes you can determine which side of the system you want to fly in order to use the tailwind to your advantage. For your flight planning, as long as you have the basic idea and a good reference source such as the AVIATION WEATHER book by the FAA/NTSB, you'll probably do just fine. -c Thank You ! |
On Mar 26, 7:19 pm, Sushidot wrote:
Hello- Is there some kind of easy trick to understanding what type of weather to expect at certain weather systems and fronts in term of explaining this to the DPE during the checkride? I am not trying to avoid learning weather theory...i just wonder if I am looking to far into the meaning of all the charts and symbols...i have no problem with the instructor pointing to a trough and asking what does this mean...Or asking me what an echo top means or anything...i just keep getting confused as to pressure systems... High Pressure Systems The weather is warm here and the visibility is good, atmosphere is stable. This makes me think of summer weather. The book says that visibility in terms of clouds is not good...am i missing something here... Low Pressure Systems The weather is cold here, visibility is poor and the atmosphere is less stable. This makes me think of winter weather. My confusion lies mainly with the visibility...i would think that a low system would have bad visibilty and be cloudy and high pressure system would have few clouds. Any advice or suggestions would be helpful. Thanks SD Where are you getting this information from? High pressure systems are descending air masses. Since air aloft is clean, dry and cool, you will get clear skies, and cool weather (and sometimes windy) conditions under a high pressure systems. But it can lead to unstable air (ie bumpy ride). Low pressure systems are rising air masses. Since air near the surface is moist and warm, you will get cloudy skies and warmer temperatures and more stable conditions. These observations do not apply to frontal weather. |
| Sport Pilot Instructor instruction & checkride questions | john hawkins | Piloting | 8 | October 3rd 07 07:24 PM |
| Private Pilot Checkride SEL | captainsj | Piloting | 11 | April 18th 07 05:19 AM |
| I passed my Private Checkride (A long, rambling post) | Larry Dighera | Instrument Flight Rules | 0 | April 10th 07 03:24 PM |
| FS 2002 Private Pilot Checkride | Calvin | Simulators | 1 | April 14th 04 07:54 PM |
| Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 07:06 AM |
