FS. 206 As350 md500 mechanic cleaning out tool box of stuff
Old March 27th 08, 02:21 PM posted to rec.aviation.rotorcraft
Default FS. 206 As350 md500 mechanic cleaning out tool box of stuff
I'm selling off a bunch of stuff a field mechanic would have need of.
AS350 Spares box with Orings starter brushes and nuts etc for As350,
Honeywell switches, metric sockets. Line plug for particle separator
for ground runs.1/4" socket set
206 Nozzle socket, ceco crowsfoot and idle wrench, 7/32 wrench, 1/2x
9/16 ratchet wrench
90 degree grease gun end , fitting to allow grease to purge to a bag
when doing head.11/16 x 3/4 thin wrench for L fuel line ..starter
spline socket. spare hyd filter. special handled syringe for oil pump
(doesn't swell) wobble Phillips bit for baggage hold, Proper facet
test tool for bypass check.
Special Ford model A 90 degree adjustable wrench great for big lines
and PC filter removal. (probably 80 yrs old) and rare as hens teeth
small camera size black light for oil leak checking,
500 thin wrench for Damper and tail rotor, 716 and 9/16 allen wrench
pieces to make sockets up
snap on stuff
torque wrench cases for 3/8 , 1/4" drive long handle plastic case.10
piece std wrenches plus a 7/32 thread cleanup file (correct angle)
sheet metal microstop with 12 bits bucking bars some clecos. 24
volt test light , micronta true rms multimeter cresent duck bills,
and alot more as time progresses, REMOVE NO SPAM FROM EMAIL
ec120guyNOSPAM
at
gmail
dot com
Best spark plug cleaning tool? Dan Luke Owning 5 August 10th 05 07:08 AM
A-65 mechanic question Michael Horowitz Home Built 24 May 30th 05 11:08 PM
AS350 B3 lands on top of Everest Guy Alcala Rotorcraft 0 May 26th 05 11:36 AM
Mechanic in MN [email protected] Piloting 2 March 24th 05 03:09 AM
I need an MD500 electrical schematic mlminnich Rotorcraft 1 October 1st 03 12:38 AM
