Expanded Glider Budget - Choices?
Old March 28th 08, 12:00 AM posted to rec.aviation.soaring
noel.wade
Default Expanded Glider Budget - Choices?
Hi All,
Back at the beginning of the year, I anticipated being able to upgrade
my glider. I bought my Russia AC-4a in 2007 on a very limited budget
and have thoroughly enjoyed its sprightly handling, easy rigging, and
climb capability. However, a big jump in my position at work has
given the the means to afford a better glider. Since my job also
means I may fly less often, I want a ship that I can stretch out with
more on longer glides (here in Seattle we get a lot of days with
3,000' - 4,000' cloudbases and only 2 - 3 knots of lift. I'm thinking
that 38:1 *measured* is the minimal L/D I'll be interested in).
Initially I was thinking I'd have a $25k - $30k limit and probably try
something with flaps (a la LS-3, Mini-Nimbus, Mosquito, DG-200, etc).
There was a long thread here where people provided some great advice.
Recently its begun looking like I may actually be able to afford a
$35k - $40k glider. This price-range opens up a few new doors
(ASW-20, perhaps a DG-202 or maybe DG-300, LS-4 mayyyybe, Pegasus, or
others?)... I was wondering if folks would be willing to tell me
their pick, and state why.
Priorities: I am interested in good ergonomics (the Apises and
DG-300's at our airfield make me envious), good/responsive handling,
good performance in weak weather, good visibility (one piece canopy),
and easy rigging (automatic hookups preferred - for safety as well as
rigging convenience).
Obviously PU or good Gel-Coat and a good trailer are important; but
what I'm after here are the inherent traits of the glider model you
suggest.
Thanks a bunch in advance!
--Noel
Old March 28th 08, 12:11 AM posted to rec.aviation.soaring
Sarah Anderson[_2_]
Congratulations on your good fortune and opportunity to try a new glider.
To start off the chorus of "the best glider is the one I fly", add the LS-6 to your maybe list.
They're harder to find in the US that the '20s, but you may be lucky. The '6 hasn't the
interesting flaps-down stall the '20 is known for, and handles wonderfully slow or fast with
those full-span flaperons. It is easy to land, less easy on take-off ( cg hook and long ground roll.)
It is relatively easy to rig, though a wing-rigging aid may be helpful. The wings are not light,
though I am comparing it to a Libelle which isn't fair. The downside may be it's interior room. If you're big & tall the LS6 may be as much of a
squeeze as the older Ventus-As.
Good luck!
Sarah
noel.wade wrote:
Hi All,
suggest.
--Noel
Old March 28th 08, 01:55 AM posted to rec.aviation.soaring
noel.wade
Thanks, Sarah! I didn't think an LS-6 would be within my budget...
If it is, cool! Although yes, I'm 6' 1" and 205 lbs. I can fit in a
Libelle, but its tight. Don't know about an early Ventus cockpit. :-
P
(Leg-room is the bigger issue for me)
Thanks!
--Noel
On Mar 27, 5:11*pm, Sarah Anderson wrote:
though I am comparing it to a Libelle which isn't fair. The downside may be it's interior room. *If you're big & tall the LS6 may be as much of a
Good luck!
Sarah
Old March 28th 08, 12:50 AM posted to rec.aviation.soaring
rlovinggood
Noel,
With your stated budget, my first and only stop would be at the local
ASW-20 store.
Ray Lovinggood
Carrboro, North Carolina, USA
Old March 28th 08, 12:53 AM posted to rec.aviation.soaring
rlovinggood
Noel,
nearest ASW-20 store.
Ray Lovinggood
Old March 28th 08, 01:17 AM posted to rec.aviation.soaring
Tim Taylor
On Mar 27, 6:00 pm, "noel.wade" wrote:
Hi All,
suggest.
--Noel
Buy something about $32K and save the rest to upgrade the panel. Most
in that price range will not have a current panel with GPS-Logger-
Integrated Vario and computer.
You will not be able to tell much performance difference in anything
in this price range and vintage.
Tim
Old March 28th 08, 01:34 AM posted to rec.aviation.soaring
Paul Cordell
Noel
I am a big fan of the ASW-20. Great handling, very comfortable and
most importantly, the best landing features. As you head out on your
cross country adventures, eventually, you will have to face
outlanding. Flying a '20 will give you the confidence to accurately
place your sailplane in those small Western Washington random fields
you may have to use.
But Why do you suffer? For a couple additional hours, you can fly in
Eastern Washington. Beautiful High thermals marked by Cu and dust
devils. Landing fields that are full sections BIG. I'd be happy
to give you a Columbia Basin tour in the 2 seat Nimbus. All ya gotta
do is show up.
Paul Cordell (ex '20 driver)
Ephrata
Nimbus 3D
Old March 28th 08, 02:43 AM posted to rec.aviation.soaring
noel.wade
This is slightly off-topic - but the basic reasons a time and
money. Gas prices and the cost of lodging/meals (even with the SGC
bunkhouse) eat into money that I could use for tows on the west-side
(or for taking ladies out on dates - but where are my priorities?
*chuckle*).
Also, I keep hearing "for only a couple of hours" - but I live in
Bothell and work in Bellevue. Once you factor in traffic, its at
least 3+ hours each way. If I was retired, I'd get a cheap motorhome
or pop-up camper and spend my spring and early summer in EPH without
question... But not when I am at work until 6 or 7pm on Friday, and
have to be back at work by 7 or 8am on Monday. :-P
Thanks,
--Noel
P.S. I really do appreciate the offer! Jim Simmons and Tom Udd have
both offered to show me around the area playing tag-along, too. I am
definitely planning on flying a couple of times a year over there;
just can't make it a weekly occurrance.
On Mar 27, 6:34*pm, Paul Cordell wrote:
But Why do you suffer? * For a couple additional hours, you can fly in
Eastern Washington. * *Beautiful High thermals marked by Cu and dust
Old March 28th 08, 07:05 AM posted to rec.aviation.soaring
Cats
On Mar 28, 12:00*am, "noel.wade" wrote:
snip
Priorities: *I am interested in good ergonomics (the Apises and
suggest.
Ergonomics depends so much on your individual shape and the only way
to find out is to sit in a glider. We have a Discus at our club and
lots of people fit it, but there are a number of people who for
various reasons don't.
Traits of the glider also depends on where you have the CoG - mine was
very difficult to round out when I started flying it, an adjustment to
move the CoG aft and it's a great improvement. I suspect that almost
any 15m glass glider can handle nicely if you get the CoG in the right
place. How critical that is depends on the type of glider - if the
elevator is relatively small then having it too far forwards can be a
nightmare getting it to round out.
Re the Pegase - seems to be loved or loathed, but there is a problem
(at present) about the maximum hours in the US.
I fly the glider I do as 1) I fit it, 2) it was what was available at
the time, 3) I could afford it (just) and 4) the CFI approved.
Old March 28th 08, 01:00 PM posted to rec.aviation.soaring
JJ Sinclair
Noel,
Most of the ships on your list will do quite nicely if tuned up
(contoured wings, proper CG, mylar, etc.). The questions I would be
asking are; How's the finish? What kind of shape is the trailer in?
What's in the instrument panel? Now days you want an airborne computer
driven by a GPS/flight recorder. If you buy a ship with questionable
gelcoat, you're looking at a minimum of 16K down the road to get it re-
finished. A "sagging" trailer with bad brakes will run you a bundle,
soon.
Now, it just so happens that old JJ will be offering a DG-300 that has
been completely re-finished in acrylic urethane with a good Cobra
trailer and the above mentioned good instruments. Available on/about
the first of May, 2008. E-mail me for particulars.
JJ Sinclair
Expanded World Class Ian Cant Soaring 59 October 11th 07 03:57 PM
Choices Jim Culp Soaring 6 March 20th 06 02:54 PM
Choices Jim Culp Soaring 0 February 19th 06 04:12 AM
Choices... Brinks Owning 7 September 30th 04 02:43 AM
GPS Choices Sully Piloting 20 December 3rd 03 02:20 AM
