Former FAA aviation safety inspector thoughts
Old March 28th 08, 02:53 PM posted to rec.aviation.owning
Default Former FAA aviation safety inspector thoughts
The point of Standy by Vac & electrical is very valid! I have
investigated many IFR accidents with no indication as to WHY!
No radio calls no nothing!
On site investigations show the engine(s) making plenty of power
trees with prop gashes in them so we know that the aircraft had
engine power! but the airplane in in a heap of twisted aluminum!
Reviewing the pilots log books and speaking with instructors showed
them competent.
yet a big hole in the ground and guts everywhere!
(I myself have had TWO total electrical outages in aircraft and TWO
vac pump outages! : when a Vac pump hits about 500 hours....watch
out!)
To this VERY DAY is still wonder what happened! the crashes with NO
ANSWERS! I think more pilots get smoked with the above outages
more than anything!
Couple heavy rain, bouncing around, corroded /loose connections and
you have a very serious problem!
Hand held GPS is good??? but when the suction cup antenna falls off
and your fumbling in the cockpit trying to reinstall it, weak
batteries /changing batteries YOU !! are asking BEGGING for
unusual attitudes and Vertigo!
Partial panel is a JOKE! as most turn Coordinators flop around the
damping fluid is dried up
the rotor is not up to speed
Reviewing many crash log books I can tell you that the 'lowly'
Turn Coordinator get changed only when its DEAD!
Yet when the Vac system is out YOUR life depends on an instrument
that gets almost no attention...... unless its DEAD!
As an aside, when was the last time ALL of the tubing in the Vaccum
system was replaced??? ALL TUBING! and flexible hoses????
filters????? the VAC pump????
Do you send out the Gyros for regular overhauls???
YOUR LIFE IS ON THE LINE...don't be CHEAP!
Have you EVER had a REAL true case of Vertigo!!!!!! in REAL
IFR?????
No heads down, 5 minute worth training bull****!! ....... FOR
REAL!!!! ..... it last a LONG time and produces exceedingly STRONG
feelings when you get it for REAL!
Let me tell you when you get a REAL good 'TRUE TO LIFE' case of
it......... Vertigo you are in the fight of your life! now throw
in some partial panel, portable GPS falling on the floor, suction
cup pops off the windshield and STRESS Your Pax asking questions
and getting ALARMED and agitated....... puking all over the place
You manage to get upside down
( only takes seconds) and you have HAD IT!...the Turn coordinator
will show wings LEVEL! yet the airspeed is going UP !!! altimeter
unwinding FAST You pull back and the airspeed INCREASES! now
Confusion??????????? brain lock??? panic... then VNE ...
Them some FAA & NTSB inspector like me at the crash site WONDERING
what happened!
If you fly IFR get a stand by vac system installed! no bull
****!..... get it done!
Even a $ 60 Venturi ( be aware of icing) system driving a second
Horizion gyro is BETTER than partial panel!
Thoughts????
Please: No 'macho' pilots... Just REAL pilots who understand
this stuff is serious!
Old March 28th 08, 04:19 PM posted to rec.aviation.owning
Robert M. Gary
On Mar 28, 7:53*am, wrote:
*The point of Standy by Vac & electrical *is very valid! * I have
investigated many IFR accidents *with no indication as to WHY!
So, let me understand your point. *IF* my electrical system fails
*AND* my vac system goes out *AND* "suction cup antenna falls off " my
GPS panel; then I may not be capable of IFR. Are you serious or are
you just a troll? How many cases have you seen in which all 3 failed
at the same time?
-Robert, CFII
Old March 28th 08, 04:26 PM posted to rec.aviation.owning
Ron Natalie
at the same time?
-Robert, CFII
And the static system plugs up...
Old March 28th 08, 06:39 PM posted to rec.aviation.owning
Blanche
at the same time?
-Robert, CFII
And the flaps are inop....
Old March 28th 08, 09:11 PM posted to rec.aviation.owning
B A R R Y
at the same time?
-Robert, CFII
And the left wheel fell off at rotation...
Old March 29th 08, 02:03 AM posted to rec.aviation.owning
On Fri, 28 Mar 2008 17:11:48 -0400, B A R R Y
at the same time?
-Robert, CFII
"Then the storm broke out in all its fury...and the dam broke! And then the
volcano erupted!"
- Daffy Duck, "The Scarlet Pumpernickel," 1948
Old March 28th 08, 04:42 PM posted to rec.aviation.owning
Mike Isaksen
wrote ...
.... I have investigated many IFR accidents with no
indication as to WHY! ........ lots clipped
site WONDERING what happened!
Thoughts????
Dear David F,
I have no reason to doubt your pilot skills and experience, and your claim
to two total electric failures might explain your hyper-anxiety. But I
wonder if you aren't stretching your qualifications a bit with the claim of
being both an FAA and an NTSB Inspector.
Old March 28th 08, 08:25 PM posted to rec.aviation.owning
Michael[_1_]
Nah. I've had two total electricals, two partial engine failures and
one total, and one total vacuum failure, and I'm not particularly
anxious. These things happen when your hours are well into 4 digits
flying stuff mostly built before you were born. What's more, the
vacuum failure was in a twin (as was one of the electricals), and was
the result of two independent point failures. First the vacuum pump
on the left engine quit - but since I was on top, still had one good
one on the right engine, and was going home anyway, I elected to
continue. Then the right engine quit for unrelated reasons. That put
me in a single-engine, partial panel situation. Also, tops were above
my single engine service ceiling. And there was icing in the clouds.
And there I was, single engine, partial panel, shooting an ILS while
ice was building.
All I could think of was that song by Pink Floyd
"Ice is forming on the tips of my wings
Unheeded warnings I thought I thought of everything"
Fly long enough, **** will happen. Train hard enough, and when it
does you get a story to tell, not a closed casket funeral. I shot the
ILS and landed, no drama. It's the marginal pilots that get anxious.
Of course that's about all the FAA has, except for a few old timers.
Once knew a good pilot who joined the FAA. Didn't last - they drove
him out pretty quick.
But I
Well, the NTSB routinely delegates the accident investigation of GA
accidents to the FAA, and a lot of those guys like to puff up their
importance by claiming to be NTSB investigators - which they
technically are, by delegation.
See, all of you assume he's just a troll and not an ex-FAA employee at
all, but having seen what they've got working at the local FSDO, I'm
perfectly prepared to believe he worked there. He'd fit right in.
Certainly his level of aviation knowledge matches the typical
inspector.
Michael
Old March 28th 08, 08:53 PM posted to rec.aviation.owning
Robert M. Gary
Nah. *I've had two total electricals, two partial engine failures and
anxious.
I figure if you lose your vac and electrical at the same time God is
punishing you. Your best bet at that point is probably to pray
-Robert
Old April 4th 08, 05:27 PM posted to rec.aviation.owning
Ray Andraka
ice was building.
Sounds to me like you need to be spending a bit more on aircraft
maintenance.
FAA Inspector overstepping his authority (I think) Screwed Owning 7 May 2nd 05 03:52 PM
Aviation safety magazines Dr Doug General Aviation 2 March 3rd 05 01:56 AM
Aviation Safety Counselor's??? NW_PILOT Owning 20 March 2nd 05 04:15 AM
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) Barnyard BOb - Home Built 5 September 8th 04 07:27 PM
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) Cub Driver Piloting 0 September 8th 04 10:35 AM
