Adding an airplane rating to private pilot glider
Old April 7th 08, 05:47 AM posted to rec.aviation.soaring
gmcd05
Default Adding an airplane rating to private pilot glider
Does anyone know what the requirements are to add a private pilot
airplane rating if you already have a private pilot glider? I know
the training requirements would be reduced for an airplane pilot
transitioning to glider but I dont know how it works going the other
way.... Does anyone have info on this?
Old April 7th 08, 05:54 AM posted to rec.aviation.soaring
theres not a lot of reduction in hourly requirements for the PP-ASEL
add on to the glider certificate. In fact, I dont know that there is
any gain. you can make some real gains towards your commercial
airplane and possibly instrument rating if you have many flights that
ended in a landing more than 50 nautical miles away from the departure
point. It is spelled out fairly well in Part 61.
Old April 7th 08, 06:32 AM posted to rec.aviation.soaring
Andy[_1_]
airplane rating if you already have a private pilot glider? *I know
way.... *Does anyone have info on this?
If you are a competent glider pilot you can expect to solo an airplane
in less time than someone with no flight experience. You may also
know what your feet are for, but your instructor may not. Section
61.109: Aeronautical experience defines the requirements.
Commercial and ATP allow you to use a lot of glider time but I don't
think there is any benefit for private except you should be competent
in the minimum specified time whereas most student pilots are not.
Andy
Old April 7th 08, 07:10 AM posted to rec.aviation.soaring
As one who recently added single engine after 20 years of strictly
glider flying I can say that one thing you don't learn flying gliders
that they are really picky about in airplane flying is holding
altitude. Man, I sucked at that!
Also, get a really good comfortable ANR headset like a 30-3G or Bose.
Airplanes are painfully loud!
MM
Old April 7th 08, 01:29 PM posted to rec.aviation.soaring
rlovinggood
altitude. *Man, I sucked at that!
MM
I agree with all that's been said. I "corrupted" my glider-only
ticket a few years ago with the Single Engine Land license. I too
sucked, and still do, at "holding" altitude in an airplane. Turns
around a point? Yea, I'm drifting with the wind, so what? Oh yea.
Stall recovery. Easy. Just drop the nose. POWER. ADD POWER. I
keep forgetting about the throttle. One other thing to remember:
Range. When flying the glider, the "range" is the preset task and all
the variables involved. In the airplane, there's only so much fuel in
the tanks, plus the other variables. When four and five hour flights
are somewhat "natural" in a glider, the ol' Cezzna 150/152 will be on
the ground and out of gas at four hours.
Ray Lovinggood
Carrboro, North Carolina, USA
Old April 7th 08, 04:23 PM posted to rec.aviation.soaring
Andy[_1_]
On Apr 7, 4:32*am, John Smith wrote:
When, on my first powered flight in mountains, I hit a strong downdraft,
my natural reaction was to push the stick forward. My instructor was not
amused, pulled the stick back and asked me to hold altitude! We had a
long discussion after that.
I wonder how that discussion turned out. I always use thermals when
flying cross country in the airplane and work ridge, wave and thermal
lift in the mountains. The only time I care about being on a constant
or assigned altitude is when on an instrument flight plan or when
flying airways. The hemispheric rule only applies when you are in
level flight not when climbing or descending.
On the way back from Arizona breakfast runs other club pilots usually
complain about the turbulence. I usually reply that I didn't notice
any turbulence but there were some great thermals!
Andy
Old April 8th 08, 04:33 AM posted to rec.aviation.soaring
Tony Verhulst
Other things to get used to: You don't need airbrakes because the whole
plane is just one huge airbrake. When your approach is too high, just
push, the airspeed won't increase.
That works (to a point) in a Cessna. Try that in a Mooney and you'll get
a very close look at the numbers on the far end of the runway as you go
by them. It depends on the airplane.
Tony
Old April 8th 08, 05:07 AM posted to rec.aviation.soaring
sisu1a
Tony
Don't they put airbrakes on those Moony things, some type of dragons
teeth arrangement?
Paul
Old April 8th 08, 06:27 AM posted to rec.aviation.soaring
BT
Yes it will, it depends on the airplane.
BT
sport airplane from private glider Andy[_1_] Soaring 5 November 28th 07 02:29 AM
FA: 1-Day-Left: 5 AVIATION BOOKS: JEPPS, Instrument Rating, IFR, Private Pilot Maneuvers, Pocket Simulator, etc. Jeff[_6_] Aviation Marketplace 0 October 20th 07 03:05 PM
FA: 5 AVIATION BOOKS: Instrument Rating, IFR, Private Pilot Maneuvers, Pocket Simulator, JEPPS, etc. Brent Aviation Marketplace 0 October 8th 07 04:28 AM
endorsements for private pilot glider rating Joel Taylor Soaring 2 October 2nd 03 07:44 AM
Private Pilot Glider Rating Requirements John Soaring 8 August 21st 03 02:09 AM
