Three Gallons Per Hour
Old April 13th 08, 05:53 PM posted to rec.aviation.piloting
Phil J
Default Three Gallons Per Hour
Aero News has a story today about Indus Aviation flying a diesel
Thorpedo burning only three gallons of Jet-A per hour. It uses a
WAM-120 turbocharged three-cylinder diesel engine generating 120
horsepower. One drawback of the engine - the installed weight is 279
pounds. But on the plus side it uses a mechanical control unit rather
than electronic. The "projected" TBO is 3000 hours.
Phil
Old April 14th 08, 12:13 AM posted to rec.aviation.piloting
Phil J
On Apr 13, 2:10*pm, Bertie the Bunyip wrote:
Phil J wrote in news:748b4d47-77dc-49a8-8252-
Thorpedo burning only three gallons of Jet-A per hour. *It uses a
horsepower. *One drawback of the engine - the installed weight is 279
pounds. *But on the plus side it uses a mechanical control unit rather
than electronic. *The "projected" TBO is 3000 hours.
Phil
Last I heard of that one it was more like 4-5 GPH. That might be an
Imperial measurement.
Bertie
Indus claimed three gallons per hour for a flight from Dallas, Texas
to Lakeland, Florida. I would guess that they throttled back to the
leanest possible cruise. In an EAA news article they are claiming 3.5
to 4 gallons per hour ( http://www.eaa.org/news/2008/2008-04-12_indus.asp
Phil
Old April 14th 08, 12:21 AM posted to rec.aviation.piloting
M[_1_]
No doubt that 3gph figure must be an economic cruise power setting,
likely below 50% power.
BTW on a diesel, the combustion is well lean of stoichiometric even at
the max rated power. The air intake is not throttle and the
"throttle" control in a diesel engine is the fuel flow control.
There's no such thing as lean of peak or best power mixture :-) You
reduce the fuel flow and the engine produces less power. You increase
the fuel flow and the engine produces more power - until you reach the
soot limit or other thermo/mechanical limit for the particular engine
and that's the max rated power.
Old April 14th 08, 03:50 AM posted to rec.aviation.piloting
Phil J
to Lakeland, Florida. *I would guess that they throttled back to the
the max rated power. *The air intake is not throttle and the
There's no such thing as lean of peak or best power mixture :-) *You
reduce the fuel flow and the engine produces less power. *You increase
See this is what I like about this newsgroup. I am always learning
something new. I've never had direct experience with a diesel engine,
although I suspect that there are going to be more of them in cars as
American fuel prices rise.
Phil
Old April 14th 08, 04:35 AM posted to rec.aviation.piloting
to Lakeland, Florida. ?I would guess that they throttled back to the
the max rated power. ?The air intake is not throttle and the
There's no such thing as lean of peak or best power mixture :-) ?You
reduce the fuel flow and the engine produces less power. ?You increase
Diesel used to be cheaper then gasoline and people started buying
diesel cars.
Diesel now costs about the same as gasoline and people have stopped
buying diesel cars.
Unless the price of diesel drops significantly with respect to gasoline,
there is no reason to think diesel cars will make a comeback.
Jim Pennino
Remove .spam.sux to reply.
Old April 13th 08, 08:29 PM posted to rec.aviation.piloting
Denny
Hmmm, My BS meter is twitching...This is a BSFC of ~0.142
The very best diesel BSFC is the huge japanese engines used in
container ships at roughly 0.30...
denny
Old April 14th 08, 12:04 AM posted to rec.aviation.piloting
M[_1_]
denny
How did you get SFC of 0.142?
That 3gph might be based on say 50% power (60HP is plenty for cruise
flight on a LSA on a local sight-seeing trip). That'll make SFC: 3 *
6.8 / 60 = 0.34 lb-hr/HP. That's quite doable on a diesel.
Old April 14th 08, 12:15 AM posted to rec.aviation.piloting
M[_1_]
BTW, SFC 0.30 is achievable on mid-size ship diesel. The largest ship
diesel engines can do 0.28 lb-hr/HP or less:
http://people.bath.ac.uk/ccsshb/12cyl/
Old April 14th 08, 01:30 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Denny wrote in news:b71e5ad0-64ee-483e-8102-
denny
Well, here they're saying somethign quite different
http://www.wilksch.com/wam-120.html
The 3 GPH might not have been at econ cruise, but it was probably at max
endurance, i.e., just enough to keep them aloft.
Bertie
C-172 $20 / hour! C-210 $30 / hour! I found my new job... Ricky Piloting 9 February 14th 08 02:01 PM
1800 Gallons of De-icing fluid... Jay Honeck Piloting 30 January 20th 07 03:39 PM
Turn & Bank Indicator and 2 gallons of poyester resin [email protected] Aviation Marketplace 1 February 14th 05 06:36 PM
Turn & Bank Indicator and 2 gallons of poyester resin [email protected] Piloting 0 February 12th 05 07:53 PM
Turn & Bank Indicator and 2 gallons of poyester resin [email protected] Instrument Flight Rules 0 February 12th 05 07:52 PM
