Camera vibration mount.
Just tried to take a video today of my flight and used about 1" of
foam under the camera to hold it down. It does ok to absorb actual frame vibrations but not the jiggles (potholes) on the taxiway and other sudden shocks which send the camera rattling on the soft foam. Any suggestions for material that will absorb the vibs but not too rigid to send the camera shaking too much? |
wrote in message ... Just tried to take a video today of my flight and used about 1" of foam under the camera to hold it down. It does ok to absorb actual frame vibrations but not the jiggles (potholes) on the taxiway and other sudden shocks which send the camera rattling on the soft foam. Any suggestions for material that will absorb the vibs but not too rigid to send the camera shaking too much? Gyro mount? A little expensive, for most. g Counterweight the camera, so it only bounces straight up and down. -- Jim in NC |
Work out some arrangement so you can WEAR the camera -- helmet mount,
shoulder mount, etc. A 3-axis gyro-stabilized camera mount is not only an expensive piece of gear, it takes up quite a bit of space and is something of a power hog. With a body-mount there is still some jerkiness imposed by UNEXPECTED bumps but your body does a pretty good job of automatically compensating for such motions when they are expected. -R.S.Hoover |
wrote in message ... Just tried to take a video today of my flight and used about 1" of foam under the camera to hold it down. It does ok to absorb actual frame vibrations but not the jiggles (potholes) on the taxiway and other sudden shocks which send the camera rattling on the soft foam. Any suggestions for material that will absorb the vibs but not too rigid to send the camera shaking too much? I had my best results with hand held, but jammed tight right up against a window or door post. Seems the more rigid the mounting then better the shot.... |
Similar Threads | ||||
Camera mount for Diamond DA-40? | cjcampbell | Piloting | 7 | December 1st 05 04:03 AM |
C206H w/Leica camera mount STC for sale | Juan Jimenez | General Aviation | 9 | February 1st 05 04:59 AM |
C206H w/Leica camera mount STC for sale | Juan Jimenez | Owning | 9 | February 1st 05 04:59 AM |
Vibration Testing | Jim Weir | Owning | 21 | October 10th 04 07:22 AM |
Vibration is Citabria | TIm Gilbert | Owning | 8 | December 14th 03 03:34 PM |
