Just back from Bensen days and Sun'n Fun. I flew (hover taxiied) a 254#
legal ultralite helicopter. I was amazed at the lack of any tendency to depart to a foreign zip code. The little Mosquito Air felt more stable to me than a Bell 47. At Sun'n Fun John Snider demonstrated several autos to the ground in his experimental class Mosquito. Some of the autos were hovering autos from as high as 15-20 ft. John also has produced an outstanding video showing the techniques he uses in doing full down autos from varying positions and also demonstrates stretching and shortening the auto to reach a good spot. He also demonstrates a throttle chop with the collective held showing how long it takes the rotor to decay. While a bit pricey as videos go ($90) it is well worth the price and a must have if you are a Mosquito owner or considering a Mosquito or just want to walk thru some autos while in your easy chair. John can be reached at Stu |
![]() "The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in message ... On Sun, 20 Apr 2008 08:05:16 -0700, "Stuart & Kathryn Fields" wrote: Just back from Bensen days and Sun'n Fun. I flew (hover taxiied) a 254# legal ultralite helicopter. I was amazed at the lack of any tendency to depart to a foreign zip code. The little Mosquito Air felt more stable to me than a Bell 47. At Sun'n Fun John Snider demonstrated several autos to the ground in his experimental class Mosquito. Some of the autos were hovering autos from as high as 15-20 ft. John also has produced an outstanding video showing the techniques he uses in doing full down autos from varying positions and also demonstrates stretching and shortening the auto to reach a good spot. He also demonstrates a throttle chop with the collective held showing how long it takes the rotor to decay. While a bit pricey as videos go ($90) it is well worth the price and a must have if you are a Mosquito owner or considering a Mosquito or just want to walk thru some autos while in your easy chair. John can be reached at Stu I wish someone would create a small home built that'd lift us bigger (6'2", 230lbs) guys and still carry reasonable fuel... Kevin: You are not to far from the Legal Ultralite empty weight. I doubt if you will see one that can lift double its empty weight and still not cost a bundle. There are arguments about intermeshing rotors being able to pick up quite a load but the cost and complexity goes up. Extreme dieting may be the only way; while certainly less desirable, the bang for the buck seems to be there. I say that and I've been trying to drop from 186 to 170 for awhile. Stu Stu |
![]() "The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in message ... On Mon, 21 Apr 2008 13:05:22 -0700, "Stuart & Kathryn Fields" wrote: Kevin: You are not to far from the Legal Ultralite empty weight. I doubt if you will see one that can lift double its empty weight and still not cost a bundle. There are arguments about intermeshing rotors being able to pick up quite a load but the cost and complexity goes up. Extreme dieting may be the only way; while certainly less desirable, the bang for the buck seems to be there. I say that and I've been trying to drop from 186 to 170 for awhile. I can't even go the Rotorway route.. I physically don't fit in the cockpit of an Exec - I'm too tall in the torso.. The Hummingbird 260L would work, but it's kinda pricey for a homebuilt at $170k for the kit sans engine. I got sit in one at Heli Expo last year in Orlando and there's plenty of room inside for me and the useful load means I could carry a couple buddies for a couple hours. Of course, I'd have to ditch the Lycoming recip engine and bolt up a 300-ish HP Allison turbine. ![]() Kevin: The Allison project is underway. I met the guy at Sun'n Fun who is in the process of finding the engine. Should be ahead of the R-66 with all the time life history already verified. Stu |
![]() "Stuart & Kathryn Fields" wrote in message .. . Kevin: The Allison project is underway. I met the guy at Sun'n Fun who is in the process of finding the engine. Should be ahead of the R-66 with all the time life history already verified. OMG! What happened? he finally started using snopes! mk5000 "Out of control baby Although we've both moved on to another Still long for each other It's wrong but eternally I get so O.O.C. "--Mariah Carey |
The OTHER Kevin in San Diego wrote:
I wish someone would create a small home built that'd lift us bigger (6'2", 230lbs) guys and still carry reasonable fuel... I'm not 6'2" but I am heavy (250 lbs...sigh). According to the specs, Vortec's Ultralight version of the New Choppy can handle useful loads of upto 360 lbs. 254lbs craft (open frame) and a nice fuel burn of 1.5 hours or so. That'd get you about 80 miles. The non-ultralight version handles the same amount of weight, is enclosed, and has a range of 180 miles or more. ($16,000 or so) For the money, if you want range and a higher than normal useful load, you might want to consider the Air Command ultralights. Rotor craft but it does have a nice range for 5 gals. |
Harry: Before you buy the new Ultralite version of Choppy, take a look at
the gross weight, 254# +360#= 614# to meet the normal rule of thumb of 10#/hp the Ultralite would need in excess of 60hp. Now the coning angle of the blades is designed based on max gross wt and rotor rpm. Of course the hp and rpm required are based on the lifting ability of the particular blade airfoil and whether there is a linear twist or not. One of the things that I have not seen at any of the 13 events that we cover each year for the past 8 years, is any ultralite helicopters other than an Ultrasport and a Mosquito. One thing to insist on for the advertised claims: Show me a demonstration. It is easy to produce specifications on paper and another to actually have a flyer that meets those specifications. My Safari weighs empty 1,000 #. It's payload capacity is 500#. If it was easy to pickup 2,000# with the Safari, I'm sure the kit manufacturer would do it. Caveat Emptor Stu Fields Experimental Helo Magazine. "Harry Skelton" wrote in message news:481289c0$0$22074$7120d902@karibu... The OTHER Kevin in San Diego wrote: I wish someone would create a small home built that'd lift us bigger (6'2", 230lbs) guys and still carry reasonable fuel... I'm not 6'2" but I am heavy (250 lbs...sigh). According to the specs, Vortec's Ultralight version of the New Choppy can handle useful loads of upto 360 lbs. 254lbs craft (open frame) and a nice fuel burn of 1.5 hours or so. That'd get you about 80 miles. The non-ultralight version handles the same amount of weight, is enclosed, and has a range of 180 miles or more. ($16,000 or so) For the money, if you want range and a higher than normal useful load, you might want to consider the Air Command ultralights. Rotor craft but it does have a nice range for 5 gals. |
Ultralite jet - ultralite 04.jpg (1/1) | RK | Aviation Photos | 2 | July 30th 07 03:47 AM |
Ultralite Jet - ultralite 03.jpg (1/1) | RK | Aviation Photos | 1 | July 28th 07 04:07 AM |
Ultralite jet - ultralite 02.jpg (1/1) | RK | Aviation Photos | 0 | July 27th 07 11:18 PM |
Ultralite Jet - ultralite 01.jpg (1/1) | RK | Aviation Photos | 0 | July 27th 07 11:17 PM |
