Question: Can a conventional powered airplane take off from a conveyor
belt which is moving at the same speed but in an opposite direction? I was surprised at people's range and passion of answers when I asked this of my glider club. People were absolutely sure it wouldn't work or it would work. I guess that goes to show that performing this as a thought experiment is not easy even for pilots. Please make your own guess before you watch these Youtube videos (in order) for the final answer. http://youtube.com/watch?v=KSBFQOfas60 Start http://youtube.com/watch?v=S377HwOthjo http://youtube.com/watch?v=0ul_5DtMLhc Finish What I am really surprise about is that the "test" pilot in this video of the airplane had the wrong answer before his attempt and was very surprised afterwards. Well, maybe not surprised, he was a light sport pilot after all. Personally, I knew the correct answer from the get- go. Hint: The answer is in the wheels. - John |
Hallo ContestID67, Du schriebst am 01.05.2008 07:18
Question: Can a conventional powered airplane take off from a conveyor belt which is moving at the same speed but in an opposite direction? rather simple question. Two possibilities: 1.) If the conveyor belt is already moving at the beginning of the experiment (driving the airplane backwards), it just takes more time for the airplane to accelerate and reach its appropriate airspeed for takeoff. The wheels just turn faster than "usually" (take-off speed plus conveyor belt speed). 2.) If both begin to accelerate at the same time, it makes no significant difference to a usual start. The rolling drag of the undercarriage wheels pulls the airplane a *little* backwards, but this effect is negligible. - The wheels just turn faster (as above). The higher rotation speed of the wheels *could* be a problem, if bearings become too hot and lock. Regards Werner |
Werner Schmidt wrote:
2.) If both begin to accelerate at the same time, it makes no significant difference to a usual start. The rolling drag of the undercarriage wheels pulls the airplane a *little* backwards, but this effect is negligible. - The wheels just turn faster (as above). In standard Newtonian dynamics, rubbing (or rolling) friction is independent of speed, so long as you're moving at all. So the extra speed of the wheels is no penalty at all, barring problems with extra heat as you mentioned. -- Michael Ash Rogue Amoeba Software |
Hallo Michael Ash, Du schriebst am 01.05.2008 17:42
Werner Schmidt wrote: 2.) If both begin to accelerate at the same time, it makes no significant difference to a usual start. The rolling drag of the undercarriage wheels pulls the airplane a *little* backwards, but this effect is negligible. - The wheels just turn faster (as above). In standard Newtonian dynamics, rubbing (or rolling) friction is independent of speed, so long as you're moving at all. So the extra speed of the wheels is no penalty at all, barring problems with extra heat as you mentioned. But same friction at higher speed releases more energy (=heat). Why does a spaceship need a heat shield and a ASK13 doesn't? And special gearboxes do need cooling (air may suffice). Bearings become hot if rotation speed is high and cooling not adequate. A too hot bearing may jam. Regards Werner |
Ugh, this old topic again? :-P
I understand why you say "the answer is in the wheels". But that's exactly the wrong attitude to take, and it illustrates why so many pilots (IMHO) don't fly well. The answer is in the wing!!! :-) The answer is ALWAYS *the wing* when it comes to flying! (OK, some smartass will point out that its sometimes *the tail* - but that's really just another wing!) If more pilots could think about their aircraft in terms of "what is the wing doing right now" or "what is the wing __feeling__ right now", there would be a lot more pilots who were a lot more skilled (and possibly a lot fewer accidents!) Take care, --Noel |
"noel.wade" wrote:
I understand why you say "the answer is in the wheels". But that's exactly the wrong attitude to take, and it illustrates why so many pilots (IMHO) don't fly well. The answer is in the wing!!! :-) Maybe it would help by simply saying "The answer is in the air." |
Hallo Michael Ash, Du schriebst am 01.05.2008 17:42 Werner Schmidt wrote: 2.) If both begin to accelerate at the same time, it makes no significant difference to a usual start. The rolling drag of the undercarriage wheels pulls the airplane a *little* backwards, but this effect is negligible. - The wheels just turn faster (as above). In standard Newtonian dynamics, rubbing (or rolling) friction is independent of speed, so long as you're moving at all. So the extra speed of the wheels is no penalty at all, barring problems with extra heat as you mentioned. But same friction at higher speed releases more energy (=heat). Right, that's why I mentioned extra heat. Why does a spaceship need a heat shield and a ASK13 doesn't? And special gearboxes do need cooling (air may suffice). Bearings become hot if rotation speed is high and cooling not adequate. A too hot bearing may jam. The comparison with the spaceship isn't quite apt. Aerodynamic friction increases with the square of the speed so the total rate of generated heat increases with the cube of the speed. Rolling friction is constant so the total rate increases linearly. In any case, if the extra heat is enough to cause problems then that would certainly make a difference, but I think the original question more or less assumes that it's not a factor. -- Michael Ash Rogue Amoeba Software |
Hello Michael Ash, you wrote at 02.05.2008 05:12
Werner Schmidt wrote: [...] Why does a spaceship need a heat shield and a ASK13 doesn't? And special gearboxes do need cooling (air may suffice). Bearings become hot if rotation speed is high and cooling not adequate. A too hot bearing may jam. The comparison with the spaceship isn't quite apt. Aerodynamic friction increases with the square of the speed so the total rate of generated heat increases with the cube of the speed. Rolling friction is constant so the total rate increases linearly. Correct. In any case, if the extra heat is enough to cause problems then that would certainly make a difference, but I think the original question more or less assumes that it's not a factor. I just wanted to mention that a jamming wheel bearing (caused by extra heat due to higher rotation speed) might cause an accident. Regards Werner |
Seeing as it's not soarable today or only briefly between showers, here's my
guess prior to looking at the videos:-- Yes, with a minor reduction in acceleration due to the extra friction from the wheels needing to rotate faster and possibly some sort of reduction in actual ground speed required due to the air tending to be dragged towards the aircraft by the moving belt. A bit like an inverted conventional ground effect. Now I'll look at the videos and then try to get out more. "ContestID67" wrote in message ... Question: Can a conventional powered airplane take off from a conveyor belt which is moving at the same speed but in an opposite direction? I was surprised at people's range and passion of answers when I asked this of my glider club. People were absolutely sure it wouldn't work or it would work. I guess that goes to show that performing this as a thought experiment is not easy even for pilots. Please make your own guess before you watch these Youtube videos (in order) for the final answer. http://youtube.com/watch?v=KSBFQOfas60 Start http://youtube.com/watch?v=S377HwOthjo http://youtube.com/watch?v=0ul_5DtMLhc Finish What I am really surprise about is that the "test" pilot in this video of the airplane had the wrong answer before his attempt and was very surprised afterwards. Well, maybe not surprised, he was a light sport pilot after all. Personally, I knew the correct answer from the get- go. Hint: The answer is in the wheels. - John |
![]() Question: Can a conventional powered airplane take off from a conveyor belt which is moving at the same speed but in an opposite direction? I was surprised at people's range and passion of answers when I asked this of my glider club. * People were absolutely sure it wouldn't work or it would work. *I guess that goes to show that performing this as a thought experiment is not easy even for pilots. Please make your own guess before you watch these Youtube videos (in order) for the final answer. http://youtube.com/watch?v=KSBFQOfas60* Start http://youtube.com/watch?v=S377HwOthjo http://youtube.com/watch?v=0ul_5DtMLhc Finish What I am really surprise about is that the "test" pilot in this video of the airplane had the wrong answer before his attempt and was very surprised afterwards. *Well, maybe not surprised, he was a light sport pilot after all. *Personally, I knew the correct answer from the get- go. *Hint: The answer is in the wheels. - John Relativity!! The misunderstanding probably derives from the fact that the question is inadequate in not specifying whether the plane is to be regarded as moving as the same speed (but opposite direction) as the conveyor relative to the belt or relative to the ground/nil wind airmass. The motor vehicles in the videos are moving oppositely at the same speed relative to the belt - i.e. stationary relative to the ground/ airmass. The propeller aeroplane is moving oppositely relative to the ground/airmass and so obviously should have no great difficulty in taking off - it is, however, at take off, moving at about twice the speed relative to the belt as the belt is relative to the ground. The fact that the freewheel/propeller derived thrust characteristics of an aeroplane allow it to achieve take does not negate the fact that at a lower power setting it could be set up such that it remained stationary relative to the ground (like the cars) in which case it would not take off - and this is what many people would probably assume was meant by the question. The question not logically valid as it implies two possible but different hypotheses. John Galloway |
MythBusters airplane on a conveyor belt | Peter Clark | Piloting | 56 | February 3rd 08 10:05 PM |
Mythbusters | Rich S.[_1_] | Home Built | 7 | February 1st 08 12:03 PM |
Two conveyor belt scenarios | [email protected] | Piloting | 24 | September 27th 06 05:32 AM |
MythBusters | Hilton | Piloting | 7 | February 4th 04 03:30 AM |
