Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Snap roll vs. Va
Old November 29th 03, 04:06 AM
Greg Esres
Default Snap roll vs. Va
For those of you who have aerobatic airplanes, I'd be interested in
data about the recommended entry speed for a snap roll vs. what Va is
in your airplane.
Thanks for any info.
Old November 29th 03, 03:54 PM
Ken Ibold
In a 7GCAA, Va at max gross is 120 mph and the recommended snap roll entry
speed is 85 mph.
"Greg Esres" wrote in message
in your airplane.
Old November 29th 03, 05:24 PM
Greg Esres
entry speed is 85 mph.
Thank you. Can a snap roll be done at max gross ?
Old November 29th 03, 06:55 PM
Ken Ibold
Yes.
Old November 29th 03, 08:43 PM
Greg Esres
Yes.
Thank you.
Old November 30th 03, 12:57 AM
Rich Stowell
Most things in aviation are related to the wings-level, 1-g stall
speed, Vso. The maneuvering speed, Va, is actually the stall speed of
the airplane at the design limit, and it is related to Vso by the
square root of the g-load. (Of course, all of these are CAS, so you
may have to do some massaging through the airseed calibration data to
convert back and forth between IAS and CAS to find the numbers you
must read on the airspeed indicator.)
For example, in aerobatic airplanes like the Citabria which were
certificated at +5.0 g's (at max. gross), Va = 2.24 x Vso. In
aerobatic airplanes certificated at +6.0 g's (at max. gross), Va =
2.45 x Vso.
In terms of the snap roll entry speed (and snap rolls are really
accelerated stall/spins), the speed will naturally fall somewhere
between Vso and either 2.24 or 2.45 x Vso.
In Eric Muller's book, Flight Unlimited, he recommends intially
practicing snap rolls at 1.5 x Vso, so there's a starting point. In my
experience, I'd recommend around 1.6 x Vso as a good "recommended"
snap roll speed, which translates into a 2.5-g pull to stall/spin the
airplane at that speed. The MAXIMUM snap roll speed should probably be
no greater than about 1.7 to 1.8 x Vso...
Hope this helps (and HI Ken!),
Rich
http://www.richstowell.com
"Ken Ibold" wrote in message . com...
speed is 85 mph.
in your airplane.
Old November 30th 03, 01:38 AM
Greg Esres
which translates into a 2.5-g pull to stall/spin the airplane at
that speed. The MAXIMUM snap roll speed should probably be no greater
Rich:
Thanks for your reply.
The genesis for my question is that there are a number of aerodynamic
sources which discuss the concept of a "dynamic stall", where when the
a/c is rapidly rotated to a high AOA, it can generate a much higher
lift coefficient than in steady state conditions.
My thought is that a snap roll should duplicate those conditions.
However, the g-forces you're reporting don't seem to match that
theory. Bill Kershner said that he does snap rolls at 80 knots, and
has never seen more than 3 g's in his Aerobat.
Old November 30th 03, 04:20 PM
Rich Stowell
Hi Greg,
You're right, dynamic stall occurs when a wing or other lifting
surface is subjected to time-dependent pitching (or other type of
time-dependent) motion, resulting in a greater effective angle of
attack than the normal, static stall angle.
But the "dynamic stall" phenomenon does not really apply to light
airplanes. It is is an unsteady stall phenomenon which can be
experienced by the retreating blade of a helicopter in forward flight
and by highly maneuverable fighter aircraft.
"Dynamic stall" means something to skydivers as well, I think when a
skydiver pendulums under the canopy too close to the ground...
Rich
Greg Esres wrote in message . ..
Rich:
Old December 1st 03, 02:26 AM
Greg Esres
Rich, it's true the phenomenon is most important in helicopter flight,
but it certainly happens in airplanes as well.
I have a copy of a NACA flight test which shows a 30% increase in lift
with a rapid AOA increase, in airplanes. The increase in lift was
directly proportional to the rate of AOA increase and showed no signs
of leveling off; the test pilots just got scared, and quit. :-)
What I'm curious about is under what conditions it happens. The only
difference in a snap roll and what these pilots were doing is your
application of ruddder (as far as I can tell). Perhaps the fact that
you stall one wing earlier than the other short circuits this effect.
I'm curious.
Old November 30th 03, 06:10 PM
Dave
"Rich Stowell" wrote in message
om...
2.45 x Vso.
Rich
Don't forget that the structural g limit is for a symmetrical stall and is
reduced to 2/3 for an asymmetric stall - therefore the absolute max snap
roll speed at MAUW for a 6g airframe is 2xVso.
Also, this speed should decrease at lighter weights by the ratio of the
square roots of the weights. Vso at weight w = Vso x sqrt(w)/sqrt(MAUW),
this can make a 10% difference to Vso so could easily affect the max snap
speed by 10kts or more.
Dave Sawdon
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
Barrel roll And g's Quest. Robert11 Aerobatics 6 July 16th 03 02:51 PM
