F-104 maxed out
Old February 10th 04, 02:01 AM
Bjørnar Bolsøy
Default F-104 maxed out
http://www.f-16.net/reference/versions/f16_79.html
I've read that the F-104's speed is really limited by the
compressor inlet temperature on the J79, and that the
airframe itself supports much higher speeds. Since the
J79 fits (modified) in a F-16, what then if we were to
fit a GE-F110 type engine with closer to twice the thrust?
Regards...
Old February 10th 04, 02:22 AM
Jim Yanik
"Bjørnar Bolsøy" wrote in
Regards...
What's the point? It's still not going to handle all that well,perhaps
worse with the extra speed. And probably not worth the money spent on the
project.
BTW,would the F-104's inlets then become the major restriction for airflow
into the engine? I believe the jets that use the newer engines have much
larger inlets.
Jim Yanik
jyanik-at-kua.net
Old February 10th 04, 04:35 AM
Orval Fairbairn
Regards...
project.
larger inlets.
The speed limitation due to the (fixed geometry) inlets arises from the
fact that, going too fast, the inlet will swallow the shockwave,
resulting in compressor stall and other engine misbehavior.
Old February 10th 04, 05:29 PM
Jake
Orval Fairbairn wrote in message .. .
Regards...
project.
larger inlets.
While it is fesible, and it is a possibility to modify the
inlets...you would get to the point where you have to ask yourself "it
is worth it, or is it cheaper to design a new aircraft".
Old February 10th 04, 05:21 PM
Bjørnar Bolsøy
Jim Yanik wrote in
Regards...
What's the point?
Apart from the shear fun? :^) Acceleration, climbrate, fuel
economy.
well,perhaps worse with the extra speed. And probably not worth
the money spent on the project.
for airflow into the engine? I believe the jets that use the
newer engines have much larger inlets.
http://www.dcr.net/~stickmak/JOHT/joht12f-104.htm
"Early Starfighters could not exceed Mach 2.2 without
damaging the engine; on later models with the -19 engine
this was increased to Mach 2.3. The canopy limit is
around Mach 2.6. The airframe on late models is stable
out to Mach 2.8."
Don't know if this can be verified, but I guess a F110 would
be a tight squeeze anyway, having a larger diameter than the j79.
Regards...
Old February 11th 04, 03:02 PM
Andy Bush
How much do you know about how the F-104 "handled"? Got any personal
experience?
I do...and I think your statement is typical of the ill-educated BS
associated with this aircraft.
"Jim Yanik" wrote in message
Regards...
project.
larger inlets.
Jim Yanik
jyanik-at-kua.net
Old February 10th 04, 01:36 PM
John Carrier
Relatively easy to fit a smaller diameter engine into the space in which a
larger one fit. The retrofit of the 110 engine into the F-14's engine bays
(TF-30's somewhat physically larger than a J-79 BTW) was a real squeeze.
Compressor inlet temp can be handled by water injection (Skyburner F-4 had
it, Greenameyer's F-104 was getting it). Canopy overheating is another
problem.
R / John
"Bjørnar Bolsøy" wrote in message
Regards...
Old February 10th 04, 10:03 PM
Scott Ferrin
On Tue, 10 Feb 2004 06:36:25 -0600, "John Carrier"
problem.
R / John
If you have access to AW&ST you might want to read about Rascal that
DARPA is kicking around. It's pretty interesting and it's along
similar lines.
Old February 11th 04, 01:15 AM
Paul F Austin
"Scott Ferrin" wrote in message
a
bays
had
problem.
R / John
similar lines.
Can you be more specific? I searched AvWeek's site for DARPA and Rascal and
came up empty.
Old February 11th 04, 02:19 AM
Bjørnar Bolsøy
"Paul F Austin" wrote in
(Skyburner F-4
had
is another problem.
R / John
that DARPA is kicking around. It's pretty interesting and it's
along similar lines.
Rascal and came up empty.
You're Googled! :^)
http://www.google.com/search?hl=en&l...UTF-8&oe=UTF-8
&q=DARPA+Rascal
Regards...
