Has anyone built their own landing gear?
Old May 11th 08, 12:20 PM posted to rec.aviation.homebuilt
Lou
Default Has anyone built their own landing gear?
I'm curious if anyone has either designed and built or built from
plans, their own
landing gear and how they did it. I know, I know, I could follow the
plans. But the plans call for a retractable gear system that I don't
want at this time. What I'm looking for is a oleo strut style with
brackets that attach to the spars. Anyone?
Anyone? Anyone?
Lou
Old May 11th 08, 02:53 PM posted to rec.aviation.homebuilt
Dick[_1_]
simplest I've seen is the Hummelbird , which has an internal spring inside a
single tube connected to the front wing spar. Connection bracketry might be
adaptable to your oleo type...
"Lou" wrote in message
plans, their own
Anyone? Anyone?
Lou
Old May 11th 08, 03:37 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
plans, their own
Anyone? Anyone?
Lou
What design, Lou?
(remove the X to email)
Now just why the HELL do I have to press 1 for English?
John Wayne
Old May 11th 08, 04:25 PM posted to rec.aviation.homebuilt
Bill Daniels
"cavelamb himself" wrote in message
plans, their own
Anyone? Anyone?
Lou
What design, Lou?
John Wayne
This could be an interesting thread. There's a lot to this subject that
often gets overlooked.
Just a thought but the air/oil spring/shockabsorbers used on motorcycle rear
suspenson might be useful in a trailing link maingear. They are fairly
light and the weight they support would be about the same as a 2-seater
light aircraft.
Old May 11th 08, 06:02 PM posted to rec.aviation.homebuilt
Lou
light aircraft.
It's funny you should say that. I've wondering about that and possibly
the rear or
front shocks of the motocross bikes. They take a hell of a beating and
seem to stay
together.
Caveman, it's called an Asso V. Asso is Italian for Ace or thats
what I've been told. The picture
that the link goes to is red, so that means that somewhere there is a
big red asso flying around.
Lou
http://www.homebuilt.org/kits/littner/champion.html
Old May 11th 08, 07:03 PM posted to rec.aviation.homebuilt
light aircraft.
the rear or
seem to stay
together.
Lou
That looks suspiciously like a Falco!
1000 pounds gross weight
Say 3 G's impact loading (on each leg, becaues sometimes that's exactly
what happens.
I'g go with 3000 pounds leg loading vertical and 1-1/2 G side load (1500
pounds)
Are you up on landing gear design?
(I'm guesing no, since you are asking here)
How about this...
Build it per plans, but with a fixed retract link?
Richard
And it's Lamb, Lou.
We're real sensitave about that the since Geico commercials.
John Wayne
Old May 11th 08, 08:01 PM posted to rec.aviation.homebuilt
Lou
And it's Lamb, Lou.
Sorry Cavelamb, I think I've done that before.
Nothing personal.
Other people have said it looks like a small falco. Maybe
I should finish this up so I can build a Falco.
Lou
Old May 13th 08, 12:49 AM posted to rec.aviation.homebuilt
Peter Dohm
m...
rear
light aircraft.
the rear or
seem to stay
together.
Lou
what happens.
pounds)
How about this...
Richard
And it's Lamb, Lou.
It looks suspiciously like a Falco to me as well--despite the reduced power
and weight. But, so do a lot of my own doodle pad sketches and that makes
it hard for me to critisize.
BTW, those Geico commercials are /really/ annoying!
Peter
Old May 11th 08, 07:31 PM posted to rec.aviation.homebuilt
Bill Daniels
rear
light aircraft.
the rear or
seem to stay
together.
My Kawasaki weighs about 700 pounds with 65% of that on the rear wheel. It
has a monoshock strut that has adjustable damping and is load adjustable by
adding compressed air. The trailing link lever arm is probably 4:1 so that
strut is holding up about 1600 pounds. Sounds like it might be workable.
BTW, there is a main gear design trick used on the very last piston engine
fighters like the Bearcat. The main struts rotated as they compressed so as
to increase the toe-out. This had the effect of making the airplane
resistant to a ground loop - in effect, steering into the skid. In a
swerve, the weight would transfer to the outside main wheel compressing that
strut and turning the wheel to the outside.
Old May 12th 08, 01:30 AM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
In article
light aircraft.
the rear or
seem to stay
together.
Lou
I have a question:
Why do you want to cobble up such a beautiful, clean design with a fixed
landing gear? It seems to me that you want to spend a lot of time,
effort and money on making your plane slower and less efficient than the
basic design.
Remove _'s from email address to talk to me.
Gear Up, pt 6 - P-39 belly-landing.jpg (1/1) Mitchell Holman Aviation Photos 0 April 19th 07 03:31 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Lufthansi Piloting 18 July 19th 06 05:13 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 04:01 AM
gear up landing: "There are those who have, and..." Daniel L. Lieberman Piloting 26 January 29th 05 12:03 AM
Landing Gear Lou Parker Home Built 2 April 11th 04 04:08 AM
