Having followed the discussions here on the SPOT messenger
(findmespot.com) I just bought one -- andhope never to need it of course. While far from perfect, it seems like a very good aid should search and rescue be needed. A few observations: I had thought I might use it in OK mode to report my position more frequently than the every 10 minutes in "track mode." At 120 kts, that's every 20 nm, leaving as much as 1500 sq miles to search. Better than those looking for Steve Fosset had, but still a lot. Of course, the average will be less than 1500 sq miles. There is a 50% chance it will be less than 400 sq miles. Unfortunately, the OK mode and track mode cannot be used at the same time. Also, it looks like the unit takes 20 minutes to send an OK message -- sending it repeatedly at several minute intervals to increase the probability of having a clear view of the sky. So track mode's every 10 minutes is best for aviation use. I also was a bit concerned that the unit could be in OK mode when I really wanted tracking mode. You get either one by pressing the OK button, momentarily to get OK mode and holding it for at least 5 seconds to get tracking mode. The problem is that, in both cases, the indicator lights look the same: the power LED and the OK LED flash in unison every 3 seconds! But there are two ways to distinguish between the two that are not described in the manual: 1. When you hold the OK button to go into tracking mode, the OK LED comes on constantly (not flashing) for 5 seconds and then starts the 3 second flash -- so it looks like it goes out after 5 seconds. Getting to OK mode, you hit the OK button only momentarily and the OK LED starts flashing every 3 seconds immediately. 2. In OK mode, the OK LED flashes in unison with the Power LED for 15-20 minutes, after which the OK transmissions are complete and only the Power LED flashes. So, if you start tracking mode more than 20 minutes before starting your flight and check that both LED's are still flashing when you get in the plane, you know you're in tracking mode. I also suggested to the company that they offer an aviation tracking option that reports every minute instead of every 10 minutes, but was told the unit takes 4 minutes to get each GPS fix. I guess that's how it last so long on a set of batteries. I then suggested they offer an every 4 minute tracking option and was told they will think about it. Hoping this helps. Martin N56WT |
On May 14, 9:13*am, wrote:
Having followed the discussions here on the SPOT messenger (findmespot.com) I just bought one -- andhope never to need it of course. While far from perfect, it seems like a very good aid should search and rescue be needed. A few observations: I had thought I might use it in OK mode to report my position more frequently than the every 10 minutes in "track mode." At 120 kts, that's every 20 nm, leaving as much as 1500 sq miles to search. Better than those looking for Steve Fosset had, but still a lot. Of course, the average will be less than 1500 sq miles. There is a 50% chance it will be less than 400 sq miles. I have Spot because I travel to Mexico a lot. 400 sq miles may seem like a pretty bad worse case scenario but I can tell you from having partisipated in several S&R missions that we would have loved to have narrowed the target down to 400 sq miles. I've been on many searches that were many states. My first one was a plane that took off from Iowa bound for Davis, CA. We must have spent hundrends of man hours searching the track between Iowa and California. 400 sq miles would have been wonderful. -Robert |
I have been told by a firend that deals in Sat Phones that there will be an
Iridium based (True World Wide) device but will be 3 times the cost. and have a key pad to enter text personal messages and your position will be on display. wrote in message ... Having followed the discussions here on the SPOT messenger (findmespot.com) I just bought one -- andhope never to need it of course. While far from perfect, it seems like a very good aid should search and rescue be needed. A few observations: I had thought I might use it in OK mode to report my position more frequently than the every 10 minutes in "track mode." At 120 kts, that's every 20 nm, leaving as much as 1500 sq miles to search. Better than those looking for Steve Fosset had, but still a lot. Of course, the average will be less than 1500 sq miles. There is a 50% chance it will be less than 400 sq miles. Unfortunately, the OK mode and track mode cannot be used at the same time. Also, it looks like the unit takes 20 minutes to send an OK message -- sending it repeatedly at several minute intervals to increase the probability of having a clear view of the sky. So track mode's every 10 minutes is best for aviation use. I also was a bit concerned that the unit could be in OK mode when I really wanted tracking mode. You get either one by pressing the OK button, momentarily to get OK mode and holding it for at least 5 seconds to get tracking mode. The problem is that, in both cases, the indicator lights look the same: the power LED and the OK LED flash in unison every 3 seconds! But there are two ways to distinguish between the two that are not described in the manual: 1. When you hold the OK button to go into tracking mode, the OK LED comes on constantly (not flashing) for 5 seconds and then starts the 3 second flash -- so it looks like it goes out after 5 seconds. Getting to OK mode, you hit the OK button only momentarily and the OK LED starts flashing every 3 seconds immediately. 2. In OK mode, the OK LED flashes in unison with the Power LED for 15-20 minutes, after which the OK transmissions are complete and only the Power LED flashes. So, if you start tracking mode more than 20 minutes before starting your flight and check that both LED's are still flashing when you get in the plane, you know you're in tracking mode. I also suggested to the company that they offer an aviation tracking option that reports every minute instead of every 10 minutes, but was told the unit takes 4 minutes to get each GPS fix. I guess that's how it last so long on a set of batteries. I then suggested they offer an every 4 minute tracking option and was told they will think about it. Hoping this helps. Martin N56WT |
On May 14, 9:57*am, "NW_Pilot"
wrote: I have been told by a firend that deals in Sat Phones that there will be an Iridium based (True World Wide) device but will be 3 times the cost. and have a key pad to enter text personal messages and your position will be on display. We already have Iridium based products that work well. The entire point Spot is that its very inexpensive. -Robert |
On May 14, 9:13 am, wrote:
snip I also suggested to the company that they offer an aviation tracking option that reports every minute instead of every 10 minutes, but was told the unit takes 4 minutes to get each GPS fix. I guess that's how it last so long on a set of batteries. I then suggested they offer an every 4 minute tracking option and was told they will think about it. Makes me wonder what is going on during that 4 minutes. are there inaccuracies introduced by the fact that we are moving faster than a hiker? how about the fact that we change altitude over that 4 minutes? Is it averaging a bunch of signals? Is it gathering components of a single fix? Maybe it gets an instant fix, and then waits for an opening to upload to the satellite? Has anyone ever compared the spot time stamped location to an IGC trace temporally? In other words, even though there is a lag in getting the fix from spot, I wonder if the time it puts on the fix is accurate. If you flew over some point of interest and pushed the OK button to mark it would you get the right position 20 minutes later, or some random in between position n minutes later? Matt |
On May 14, 4:37 pm, "Matt Herron Jr." wrote:
On May 14, 9:13 am, wrote: snip I also suggested to the company that they offer an aviation tracking option that reports every minute instead of every 10 minutes, but was told the unit takes 4 minutes to get each GPS fix. I guess that's how it last so long on a set of batteries. I then suggested they offer an every 4 minute tracking option and was told they will think about it. Makes me wonder what is going on during that 4 minutes. are there inaccuracies introduced by the fact that we are moving faster than a hiker? how about the fact that we change altitude over that 4 minutes? Is it averaging a bunch of signals? Is it gathering components of a single fix? Maybe it gets an instant fix, and then waits for an opening to upload to the satellite? Has anyone ever compared the spot time stamped location to an IGC trace temporally? In other words, even though there is a lag in getting the fix from spot, I wonder if the time it puts on the fix is accurate. If you flew over some point of interest and pushed the OK button to mark it would you get the right position 20 minutes later, or some random in between position n minutes later? Matt You are making assumptions from what Martin said. In track mode I suspect it is sleeping, wakes up the GPS and then sends the location/ time (and it tries to resend it later as well, since it is simplex it never knows it the message goes out). But it knows exactly the time when it was exactly at some coordinate and tries to send that exact info, possibly delayed up to ~10 mins. Who know what exactly it does when you press OK, Help or 911. if I built it, it would wake up the GPS and grab a new fix and send that location - why would you build it any different? The very modern GPS chipset used definitly should not take 4 mins to acquire a (warm) fix and I'd eat my hat if they have to do a cold fix each time. The SPOT does not "wait for an opening" to talk to Globalstar, it has no idea where the Globalstar satelites are, it just sends blind, then retransmits the same message later. It's pure simplex, there is no "carrier detect", no handshake, no ACK. Nothing. The Globalstar satellites are just dumb one-way bent pipe repeaters. Sometime being simple is a beautiful thing. And to Martin's earlier comment, OK etc. does not always take 20 minutes to send, it might take up to that (or may never successfully send) but you can see that messages often go out quicker than this. I'm missing the point of the argument used, I use tracking becasue it is convenient and I don't want to press buttons, not because I think a track position report is more likely to get out than an OK report. BTW kind of a throw away comment but the circle of uncertainity for a 10 minute fix spot at reasonable fast cruise speed is about the same order as for a SARSAT doppler located plain old 121.5 MHz ELT. (which SARSAT service goes away next year) Of course if SAR is activated and they can home your ELT then they can find you (or your corpse). If SPOT survives they also find you or the corpse. The big issue with an ELT is they just don't activate on impact frequently enough and nobody know what the stats are for gliders ( ~12 percent for GA aircraft). At least with a SPOT in track mode you are not relying on impact activation and not at the mercy of the unit not being damaged and the antennas able to see the sky after impact. If SPOT simply halved the 10 minute location transmit times (which I've also heard from other sources they are looking at doing) the are of uncertainity drops a lot. The other thing is I suspect a lot more crashes/landouts happen when gliders are not cruising at high speed but scratching around low in weak lift or close in on ridges etc. In those cases the area of uncrtainty will be smaller. Previous flight trace fixes will often allow some guessing by SAR groups on the indended flight path, speed, etc. and that will often reduce the area of uncertainity as well. Executive summary: go buy yourself a SPOT messenger! Cheers Darryl |
On May 14, 11:34*pm, Darryl Ramm wrote:
On May 14, 4:37 pm, "Matt Herron Jr." wrote: On May 14, 9:13 am, wrote: *snip I also suggested to the company that they offer an aviation tracking option that reports every minute instead of every 10 minutes, but was told the unit takes 4 minutes to get each GPS fix. I guess that's how it last so long on a set of batteries. I then suggested they offer an every 4 minute tracking option and was told they will think about it. Makes me wonder what is going on during that 4 minutes. are there inaccuracies introduced by the fact that we are moving faster than a hiker? *how about the fact that we change altitude over that 4 minutes? *Is it averaging a bunch of signals? *Is it gathering components of a single fix? *Maybe it gets an instant fix, and then waits for an opening to upload to the satellite? *Has anyone ever compared the spot time stamped location to an IGC trace temporally? In other words, even though there is a lag in getting the fix from spot, I wonder if the time it puts on the fix is accurate. *If you flew over some point of interest and pushed the OK button to mark it would you get the right position 20 minutes later, or some random in between position n minutes later? Matt You are making assumptions from what Martin said. In track mode I suspect it is sleeping, wakes up the GPS and then sends the location/ time (and it tries to resend it later as well, since it is simplex it never knows it the message goes out). But it knows exactly the time when it was exactly at some coordinate and tries to send that exact info, possibly delayed up to ~10 mins. Who know what exactly it does when you press OK, Help or 911. if I built it, it would wake up the GPS and grab a new fix and send that location - why would you build it any different? The very modern GPS chipset used *definitly should not take 4 mins to acquire a (warm) fix and I'd eat my hat if they have to do a cold fix each time. The SPOT does not "wait for an opening" to talk to Globalstar, it has no idea where the Globalstar satelites are, it just sends blind, then retransmits the same message later. It's pure simplex, there is no "carrier detect", no handshake, no ACK. Nothing. *The Globalstar satellites are just dumb one-way bent pipe repeaters. Sometime being simple is a beautiful thing. And to Martin's earlier comment, OK etc. does not always take 20 minutes to send, it might take up to that (or may never successfully send) but you can see that messages often go out quicker than this. I'm missing the point of the argument used, I use tracking becasue it is convenient and I don't want to press buttons, not because I think a track position report is more likely to get out than an OK report. BTW kind of a throw away comment but the circle of uncertainity for a 10 minute fix spot at reasonable fast cruise speed is about the same order as for a SARSAT doppler located plain old 121.5 MHz ELT. (which SARSAT service goes away next year) Of course if SAR is activated and they can home your ELT then they can find you (or your corpse). If SPOT survives they also find you or the corpse. The big issue with an ELT is they just don't activate on impact frequently enough and nobody know what the stats are for gliders ( ~12 percent for GA aircraft). At least with a SPOT in track mode you are not relying on impact activation and not at the mercy of the unit not being damaged and the antennas able to see the sky after impact. If SPOT simply halved the 10 minute location transmit times (which I've also heard from other sources they are looking at doing) the are of uncertainity drops a lot. The other thing is I suspect a lot more crashes/landouts happen when gliders are not cruising at high speed but scratching around low in weak lift or close in on ridges etc. In those cases the area of uncrtainty will be smaller. Previous flight trace fixes will often allow some guessing by SAR groups on the indended flight path, speed, etc. and that will often reduce the area of uncertainity as well. Executive summary: go buy yourself a SPOT messenger! Cheers Darryl Good summary Darryl, thanks. I agree with your search area opinions as well. I assume it makes more sense to have the spot attached to the chute rather than the plane for pretty much all situations. Matt |
On May 14, 4:37 pm, "Matt Herron Jr." wrote: The SPOT does not "wait for an opening" to talk to Globalstar, it has no idea where the Globalstar satelites are, it just sends blind, then retransmits the same message later. It's pure simplex, there is no "carrier detect", no handshake, no ACK. Nothing. *The Globalstar satellites are just dumb one-way bent pipe repeaters. Sometime being simple is a beautiful thing. I always assumed the 20 minute thing was put into the SPOT system because sat time is expensive. Executive summary: go buy yourself a SPOT messenger! I did and I love it! I'm just waiting for them to create a public side to findmespot.com so I can share my tracks. Right now you have to give out the admin password to your account (which includes your credit card on file, etc) for people to see your tracks. -Robert |
Robert M. Gary wrote:
I did and I love it! I'm just waiting for them to create a public side to findmespot.com so I can share my tracks. Right now you have to give out the admin password to your account (which includes your credit card on file, etc) for people to see your tracks. They've done that already, and it works well. Take another look at the site to see how you can create public pages. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On May 15, 9:05*am, Eric Greenwell wrote:
Robert M. Gary wrote: I did and I love it! I'm just waiting for them to create a public side to findmespot.com so I can share my tracks. Right now you have to give out the admin password to your account (which includes your credit card on file, etc) for people to see your tracks. They've done that already, and it works well. Take another look at the site to see how you can create public pages. Thanks to all for posting. I'm gathering responses to several posts here. First, on the sharing option, they say it's a beta and in my experience (and that of three people who tried it on various computers) it does not work. While it may work some of the time, that's not good enough for the S&R application, so I've had to share my account password with my backup people. Second on Eric's post re zipper on top vs. the bottom (#13 in this thread), I emailed Allen Silver and, not surprisingly, there is a logic to the zipper location. Here's his response: "There actually is a reason why I mounted it on the bottom. One is to protect it from getting snagged and accidentally opened and the other is about gravity. If you left the snap that secures the zipper to the pack undone and you had to bailout the zipper could unzip during the g forces of opening. Not likely to occur, but you know about Murphy's Law." Thanks for the posts on vertical vs. horizontal. I'll have to try it in the SMAK PAK and see what happens. Martin WT |
See SPOT run... | [email protected] | Soaring | 11 | April 30th 08 08:57 PM |
SPOT Satellite Messenger | [email protected] | Soaring | 9 | January 3rd 08 06:30 PM |
SPOT Satellite Messenger | Marc Ramsey[_2_] | Soaring | 7 | October 3rd 07 10:30 PM |
Lawrence Sperry's Messenger biplane landing in front of the US Capitol Building, Washington DC | Dave Kearton | Aviation Photos | 1 | May 10th 07 07:48 AM |
Dont shoot the messenger | Jeff | Piloting | 5 | February 11th 04 09:12 AM |
