Worlds smallest helecopter
Old May 16th 08, 12:42 PM posted to rec.aviation.homebuilt
Default Worlds smallest helecopter
http://www.cnn.com/2008/TECH/05/15/s....ap/index.html
Karl
Old May 16th 08, 02:15 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Karl
Anyone have a clue as to how it controls yaw?
Old May 16th 08, 02:40 PM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
"Gig 601Xl Builder" wrote in message
m...
Karl
As a guess, differential torque. The blades are fixed pitch so differential
collective ala Kaman is not possible. Note that the guy says while it is
possible to fly as high as 165 yds, his demo would be at 16.5 yds altitude.
If the engines fail, though it would require all 4 failing, the helo quickly
converts to a lawn dart. If it was me I would demo at 1.65yds altitude and
no faster than I could run. I saw a demo of this ship at Sun'n Fun a number
of years ago. The pilot got a bit carried away with some low altitude
swooping and tipped the ship over to far and it hit the ground shedding
rotor parts:; some of which were later found several hundred feet down the
flight line in front of an RV. No injuries though.
Stu
Old May 17th 08, 02:46 PM posted to rec.aviation.homebuilt
Hasn't that been done in the past? I once asked about a tandem-rotor
fixed-pitch helicopter. At the time, it seemed reasonable that such
a device could be controlled by differential torque; forward movement
would be produced by tilting the entire craft (my thought at the time
was a sliding weight).
Hmmm... All I really need is a way to get to the grocery store.
Over the power lines and through the alley to the street is all I'd
need.
Any idea why there are four engines?
is this the famous "Head-o-copter"?
http://www.flurl.com/item/Head_o_Copter_u_307813
Mike
Old May 16th 08, 02:39 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Karl
http://www.acecraftusa.com/specs.html
But how can it be called a helicopter if it has a fixed pitch rotor?
These things outta be called something else...
Richard
(remove the X to email)
Now just why the HELL do I have to press 1 for English?
John Wayne
Old May 16th 08, 02:47 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Karl
Richard
Counter rotating rotors that explains it. Not that I think that it is
any less of a death trap but at least I know how it works now.
Old May 16th 08, 07:42 PM posted to rec.aviation.homebuilt
Lou
I want one for the golf course.
Lou
Old May 16th 08, 09:15 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
"Lou" wrote in message
Lou
Careful Lou, that thing would leave a giant sized divot.
Old May 17th 08, 04:32 AM posted to rec.aviation.homebuilt
For use as a golf cart, or as a mower? :-)
Old May 17th 08, 02:39 PM posted to rec.aviation.homebuilt
Peter Dohm
"cavelamb himself" wrote in message
m...
Karl
Richard
John Wayne
I'm also having a little trouble calling it a helicopter; but thanks for the
link, which provided the following answer to the frequently asked question
about yaw:
Yaw is controlled through a differential gear within the transmission.
An electric motor adjusts the positioning of a differential gear, which
changes the speed of the counter rotating blades in relation to each other
causing torque on the helicopter which results in yaw in either direction as
directed by the pilot.
Peter
The smallest jet aircraft in the world - BD-5J (homebuilt) [email protected] Home Built 18 March 21st 08 02:40 PM
Re Worlds 1st Jonathon May Soaring 1 February 16th 08 09:29 AM
pre worlds BB Soaring 5 July 29th 07 01:59 AM
Worlds smallest FlyBaby! cavelamb himself Home Built 0 March 27th 07 04:37 PM
Biggest and smallest aviators José Herculano Naval Aviation 23 February 7th 05 02:12 PM
