Winch launch clinic at Faribault, Minnesota
Old May 23rd 08, 03:45 PM posted to rec.aviation.soaring
Bill Daniels
Default Winch launch clinic at Faribault, Minnesota
Frank Whiteley and I spent the first three days of this week training the
folks at Cross Country Soaring (
http://www.crosscountrysoaring.com/index.html ) to use their new winch.
Frank trained the winch drivers and I trained pilots.
I lost track of the number of launches but it was probably over 80.
Faribault is a fairly busy GA airport but we were able to use their main
runway without causing any problems for the 'power' traffic by making radio
calls on the CTAF frequency like, "Faribault traffic, Glider 37M position
and hold runway 30 at taxiway Bravo, winch launch to 1500 AGL in one minute.
Arriving traffic please advise"
Every day offered thermic conditions allowing for sustained flight whenever
needed to accomodate arriving or departing 'power traffic'. "Glider 37M
holding 2 miles NW Faribault for arriving Cessna."
We pulled out the rope on the ten foot wide strip of grass between the edge
of the asphalt and the edge lights on the side opposite the taxiways. This
kept the rope off the runway surface until needed. No aircraft could taxi
over the rope.
Simultaineously training winch drivers and pilots can lead to chaotic
results but occasional glitches by newbie drivers gave just the right level
of emergiency training to the pilots. In addition to driver glitches, we
suffered a few rope breaks, mostly knots made by the previous owner giving
way, but since we were using Spectra rope, these led to minimum delay.
There were no tangles. Spectra allows convincing simulations of rope breaks
since pulling the release under high tension causes no tangles.
We gave one of the local mechanics a ride. Afterwards I asked him how he
liked it. "Kinda nice", he said but he was having trouble enunciating the
words through an enormous ear to ear grin. To allow Don to stay at the
winch for more training, I took one of his scheduled students who told me he
was having trouble with landings. Four quick winch launches for landing
practice had him much improved. Three or four more would have him ready for
solo.
At the end, no one questioned whether winch launch can co-exist with GA
traffic. I chatted with some of the airplane owners at the fuel pump.
Their main question was, "How much gas does that thing use?" My answer was,
"About a quart of Unleaded per launch". That made them look wistfully at
the $200 figure on the pump.
Old May 23rd 08, 03:54 PM posted to rec.aviation.soaring
John Scott
What type of winch was being used?
John Scott
Old May 23rd 08, 04:39 PM posted to rec.aviation.soaring
Bill Daniels
"John Scott" wrote in message
John Scott
It was an ex-Canadian Gerhlein style single drum winch with a Chevy 350 V8
and a GM TH400 series transmission. It's a well maintained example of a
1960's style winch. It's not ideal but cheap enough to get started with
winch launch. The ~1500' AGL launches it delivered were just fine for
contacting thermals. Had we not been in training mode, I could have
thermalled away on almost every launch.
The power was just right to allow the glider pilot to control airspeed with
pitch inputs but it did exhibit tension oscillations whenever the launch was
disturbed by a rough gear change or thermals as is typical with this type of
winch. We were able to reduce oscillations by using 2nd gear. 2nd gear
also eliminates the tendency for the TH400 to make a 3 - 2 downshift near
the top of the launch.
A modern tension controlled winch would probably increase the release
heights to 2000' AGL by holding rope tension nearly perfect.
Bill Daniels
Old May 24th 08, 03:59 PM posted to rec.aviation.soaring
Derek Copeland[_2_]
We don't seem to get 'tension oscillations' using basically similar
winches in the UK! Deliberately launching in second gear sounds like a
good way of over-reving the winch engine or running out of available cable
speed, unless there is a reasonable headwind. Perhaps Bill should have a
word with our gearbox supplier? We just launch in 'Drive' without
experiencing any of these problems!
We weren't told how long the winch run was, but I note that Bill felt
that 1500ft launches were usually high enough for contacting thermals.
That also mirrors our finding on this side of the pond. More height is
alway welcome though!
Derek Copeland
John Scott
V8
with
with
was
type
of
Bill Daniels
Old May 24th 08, 05:21 PM posted to rec.aviation.soaring
Bill Daniels
I have no intention of getting into any exchange with Derek who has a
profoundly biased view of winch launch. There is a substantial body of
engineering measurements and expert opinion that contradicts just about
everything Derek has to say. Knowledgeable people just ignore him since his
prupose is just to start arguments.
His favorite winch (Which he serves as the chief cheerleader - probably to
the great embarassment of the maker.) exibits huge tension oscillations
which have been measured by logging tensionmeters. These oscillations are
easily felt and disturbing to all pilots - except Derek who seems somehow
unable to notice them. If you want to see tension logs of these
oscillations, contact me privately. I can link anybody to videos showing
this winch downshifting and breaking winch ropes.
I can assure everyone that Frank Whiteley can read an engine tachometer
better than just about anybody. There was no overrevving of the Faribault
winch, it was simply geared too tall to use 3rd gear. Using second gear
also eliminated the surging 3-2 downshift near the top of the launch.
Bill Daniels
"Derek Copeland" wrote in message
Derek Copeland
John Scott
V8
with
with
was
type
of
Bill Daniels
Old May 24th 08, 06:14 PM posted to rec.aviation.soaring
Derek Copeland[_2_]
I am a senior instructor at a major UK gliding club and regularly take
winch launches on Tost and Skylaunch winches, which both have large
capacity GM Marine V8 engines and TH400 changing 3 speed automatic
gearboxes. To me, and everyone else who launches on them, they give smooth
and safe launches. The Skylaunch is the preferable design as it is much
more modern and fitted with a semi-automatic form of launch control. The
Tost is purely manually controlled. Please see the following videos as
examples of this: The one winch launch failure was simulated by the
gliding instructor as a training exercise BTW:
http://www.youtube.com/watch?v=FCQTkCFqLjc
(Tost)
http://www.youtube.com/watch?v=F2SD7USG1n4
(Tost and Skylaunch)
http://www.youtube.com/watch?v=HNcEtvcnnGc
(Skylaunch)
Derek Copeland
his
to
are
showing
Faribault
Bill Daniels
a
cable
a
Derek Copeland
Old May 23rd 08, 06:56 PM posted to rec.aviation.soaring
folks at Cross Country Soaring (http://www.crosscountrysoaring.com/index.html) to use their new winch.
needed to accomodate arriving or departing 'power traffic'. *"Glider 37M
of the asphalt and the edge lights on the side opposite the taxiways. *This
kept the rope off the runway surface until needed. *No aircraft could taxi
over the rope.
of emergiency training to the pilots. *In addition to driver glitches, we
way, but since we were using Spectra rope, *these led to minimum delay.
There were no tangles. *Spectra allows convincing simulations of rope breaks
We gave one of the local mechanics a ride. *Afterwards I asked him how he
liked it. *"Kinda nice", he said but he was having trouble enunciating the
words through an enormous ear to ear grin. *To allow Don to stay at the
was having trouble with landings. *Four quick winch launches for landing
practice had him much improved. *Three or four more would have him ready for
solo.
traffic. *I chatted with some of the airplane owners at the fuel pump.
Their main question was, "How much gas does that thing use?" *My answer was,
"About a quart of Unleaded per launch". *That made them look wistfully at
Awesome, I wish I could've made it, but darn work got in the way. A
couple people from my club were there though so I look forward to
debriefing with them. And I just may have to get up there with Don
now and take some launches!
Old May 24th 08, 06:40 AM posted to rec.aviation.soaring
As a long time booster of soaring in the upper midwest I want to thank
Bill and Frank for making the trip and doing the great training and
promotion that I'm sure has motivated many here. And to Don at CC
Soaring for taking a chance and making it work. You guys ROCK! Sorry
I couldn't be there. Matt Michael Ames Iowa
Old May 24th 08, 07:25 AM posted to rec.aviation.soaring
ContestID67
Coupla' questions;
1) What was the highest release?
2) What was the lowest release?
3) Was it skill/training/experience of the pilot/operator/both that
allowed you to get to the highest release?
4) What types of line was used? Steel? Spectra? How long was the
line?
Thanks.
Old May 24th 08, 03:47 PM posted to rec.aviation.soaring
Bill Daniels
"ContestID67" wrote in message
Coupla' questions;
A little over 1700 feet AGL with the ASK21 (K21's always seem to come out
on top)
~50 feet (rope break). But I think what you meant was lowest release when
nothing went wrong and that was about 1400 feet with the G103 Twin II.
Nope, just following standard winch launch protocol.
This winch allowed a fairly simple technique of just "capturing" the
airspeed and holding it at 60 knots with the 103 and 65 knots with the K21.
If you didn't let the airspeed get high it was easy to control it with
elevator inputs.
I just let the glider float off the runway and climb gently with rapidly
increasing airspeed until 50 knots and then smoothly pitched up to "capture"
the airspeed at the pre-selected "target". All the pilots found this easy
to master.
line?
We were .25" diameter double braid (Kermantle?) Spectra. There was a 5/32"
12 strand load bearing core of Spectra (UHMWPE) and a braided cover. The
cover was probably polyester and was suffering from the rollers. I think we
were using about 3700 feet according to Google Earth.
The 1//4" diameter meant that the winch drum wouldn't hold a runway length
of rope so we used a taxiway intersection as the launch point. 1/4" also
meant that the aerodynamic drag was high which limited the achieved release
height. Don will probably switch to 3/16" 12-strand single braid Spectra
when this stuff wears out. Using the full runway length and thinner rope
should permit 2000' launches.
Bill Daniels.
Pay out winch launch to 2500ft agl.. WAVEGURU Soaring 8 June 5th 07 07:06 AM
Winch Clinic Southern Nevada November 11 and 12 [email protected] Soaring 0 October 31st 06 02:26 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Avenal auto-tow ground launch clinic March 6-7 Mark James Boyd Soaring 0 January 30th 04 08:41 PM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
