RAS,
I graduate with a degree in Aerospace Engineering in December. Ive decided to entitle my senior project: "Flight Test Evaluation of a Cherokee II Sailplane" It makes perfect sense to me that the culmination of my education should involve me flying my glider, and perhaps allowing me to improve my flying (yea right). Mostly, I just want it to involve some flying. I had a short chat with Dick Johnson at the SSA Convention about his technique. He mentioned his stopwatch method that has worked for years, but also said that on his most recent flights he has taken a flight recorder with him and the results matched pretty well. Id like to generate the drag polar for my glider. I talked to my project advisor briefly and he had me check out http://www.eagletreesystems.com/ which makes data recorders for RC aircraft. The cool thing is that I could get airspeed and altitude readouts for the entire flight, and then find the polar from that. President Bush will be mailing me a pretty nice economic stimulus check at the end of the month. I plan to do my civic duty and spend it. are there any igc approved loggers that i could use not only for records/badges/OLC etc. but also that would give me the flight information that I need to do my senior project? You all are the experts on the logger stuff. Ive breezed over the million post threads so it must be so. What do you recommend? |
On May 23, 6:50 pm, Adrian Jansen wrote:
wrote: Id like to generate the drag polar for my glider. I talked to my project advisor briefly and he had me check outhttp://www.eagletreesystems.com/ which makes data recorders for RC aircraft. The cool thing is that I could get airspeed and altitude readouts for the entire flight, and then find the polar from that. The data is easily available from almost any modern vario and GPS. It would be wonderful if it were that simple. Unfortunately the air you are flying through moves too. -- Regards, Adrian Jansen adrianjansen at internode dot on dot net Design Engineer J & K Micro Systems Microcomputer solutions for industrial control Note reply address is invalid, convert address above to machine form. obviously the air moves. flights would have to be done just after sunrise or near sunset when the air was the most calm. test would be repeated to try to work out errors. so which loggers will provide the data and fit the badge/record/OLC requirement for the best price? |
On May 23, 6:05 pm, wrote:
repeated to try to work out errors. so which loggers will provide the data and fit the badge/record/OLC requirement for the best price? All this off the top of my head as I sit at work waiting for a test to finish.... I've heard the 302 will spew a raw data stream from all sensors to the serial port after one issues a magic command. The IGC file does not include any of this info though. I think the SN-10 is capable of adding airspeed info to the IGC file, but it is not IGC certified FR. Borgelt B50 can mix airspeed info into a FR's data stream for consumption by PDA software. It's possible that a manufacturer might provide you with a firmware "upgrade" that you could use for data capture for your project, then you could reinstall the official firmware for badge flying. -Tom |
RAS, I graduate with a degree in Aerospace Engineering in December. Ive decided to entitle my senior project: "Flight Test Evaluation of a Cherokee II Sailplane" It makes perfect sense to me that the culmination of my education should involve me flying my glider, and perhaps allowing me to improve my flying (yea right). Mostly, I just want it to involve some flying. I had a short chat with Dick Johnson at the SSA Convention about his technique. He mentioned his stopwatch method that has worked for years, but also said that on his most recent flights he has taken a flight recorder with him and the results matched pretty well. Id like to generate the drag polar for my glider. I talked to my project advisor briefly and he had me check out http://www.eagletreesystems.com/ which makes data recorders for RC aircraft. The cool thing is that I could get airspeed and altitude readouts for the entire flight, and then find the polar from that. President Bush will be mailing me a pretty nice economic stimulus check at the end of the month. I plan to do my civic duty and spend it. are there any igc approved loggers that i could use not only for records/badges/OLC etc. but also that would give me the flight information that I need to do my senior project? You all are the experts on the logger stuff. Ive breezed over the million post threads so it must be so. What do you recommend? Well, you have a problem. First of all the only loger I know of that will satisfy your desire to be nice to Bush and provide some relevant information is Cambridge Instruments CAI302 All others are not US made. Second of all they are designed to be IGC loggers so they do not log things you want. You will need to combine logger and some NMEA logging software. You can roll your own, or use GPS_LOG WinCE which will provide a log of data you want, but not in IGC format (coma delimited). Second problem is that you need to get a logger that provides you with output of IAS. Cambridge CAI302 provides output of true speed, but no temperature data (?). At best you will have to altitude compensate TAS to IAS. Borgelt devices, some LX navigation devices and I believe Westerboer 921 do provide IAS. Hope that helps. Henryk Birecki |
On May 23, 6:29 pm, Henryk Birecki wrote:
wrote: RAS, I graduate with a degree in Aerospace Engineering in December. Ive decided to entitle my senior project: "Flight Test Evaluation of a Cherokee II Sailplane" It makes perfect sense to me that the culmination of my education should involve me flying my glider, and perhaps allowing me to improve my flying (yea right). Mostly, I just want it to involve some flying. I had a short chat with Dick Johnson at the SSA Convention about his technique. He mentioned his stopwatch method that has worked for years, but also said that on his most recent flights he has taken a flight recorder with him and the results matched pretty well. Id like to generate the drag polar for my glider. I talked to my project advisor briefly and he had me check outhttp://www.eagletreesystems.com/ which makes data recorders for RC aircraft. The cool thing is that I could get airspeed and altitude readouts for the entire flight, and then find the polar from that. President Bush will be mailing me a pretty nice economic stimulus check at the end of the month. I plan to do my civic duty and spend it. are there any igc approved loggers that i could use not only for records/badges/OLC etc. but also that would give me the flight information that I need to do my senior project? You all are the experts on the logger stuff. Ive breezed over the million post threads so it must be so. What do you recommend? Well, you have a problem. First of all the only loger I know of that will satisfy your desire to be nice to Bush and provide some relevant information is Cambridge Instruments CAI302 All others are not US made. Second of all they are designed to be IGC loggers so they do not log things you want. You will need to combine logger and some NMEA logging software. You can roll your own, or use GPS_LOG WinCE which will provide a log of data you want, but not in IGC format (coma delimited). Second problem is that you need to get a logger that provides you with output of IAS. Cambridge CAI302 provides output of true speed, but no temperature data (?). At best you will have to altitude compensate TAS to IAS. Borgelt devices, some LX navigation devices and I believe Westerboer 921 do provide IAS. Hope that helps. Henryk Birecki As Tom says the C 302 can dump data in LOG mode, LOG 12 gives you everything in raw format but you have to process/decode yourself. Data rate is fixed at 1 sample per second. See the dataport guide at http://www.cambridge-aero.com/300series.htm. Darryl |
Cambridge CAI302 provides output of true speed, but no temperature data (?). The 302 will output outside air temperature. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Eric Greenwell wrote:
Henryk Birecki wrote: Cambridge CAI302 provides output of true speed, but no temperature data (?). The 302 will output outside air temperature. In a fashion. It outputs it as some raw number in LOG 12 mode, but unless you know all the calibration data, this mode does not do much good. Henryk |
Eric Greenwell wrote: Henryk Birecki wrote: Cambridge CAI302 provides output of true speed, but no temperature data (?). The 302 will output outside air temperature. In a fashion. It outputs it as some raw number in LOG 12 mode, but unless you know all the calibration data, this mode does not do much good. Well, darn it, I was hoping for some easy way to display it on my PDA. I can look at it on the 302 itself, but it's 10 button presses and 5 knob clicks to get to it. A real nuisance. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Henryk Birecki wrote: Eric Greenwell wrote: Henryk Birecki wrote: Cambridge CAI302 provides output of true speed, but no temperature data (?). The 302 will output outside air temperature. In a fashion. It outputs it as some raw number in LOG 12 mode, but unless you know all the calibration data, this mode does not do much good. Well, darn it, I was hoping for some easy way to display it on my PDA. I can look at it on the 302 itself, but it's 10 button presses and 5 knob clicks to get to it. A real nuisance. The other thing the 302 fails to output in normal operating mode is indicated airspeed (it provides only true airspeed), which one would definitely want for flight test evaluation purposes... Marc |
Kentucky's toothless, Giuliani's work for Oxy-Contin, Bloomberg'sconflict of interest , junk foods and medications from same sources,lasertheft ,Economic Stimulus Plan | fusion | Naval Aviation | 0 | January 13th 08 07:15 PM |
Recording Hobbs | BG | Owning | 8 | December 7th 06 01:40 PM |
Recording Hobbs | BG | Piloting | 11 | December 7th 06 12:04 PM |
recording from intercom system | Nobody | Piloting | 10 | April 3rd 06 06:54 AM |
recording communications | Casey Webster | Piloting | 10 | February 13th 04 05:39 PM |
