TruTrak ADI current draw
Old May 28th 08, 05:25 AM posted to rec.aviation.soaring
Hellman
Default TruTrak ADI current draw
Several times on this newsgroup people have asked about the power
consumption of TruTrak's electronic artificial horizon (ADI), but
until now I haven't seen a definitive answer. (Apologies if I missed
it. I did do a search on the newsgroup before posting this.) I emailed
TruTrak and got the following answer:
The current draw of the ADI is around 180 milliamps. It is nearly the same for both sizes.
Please let me know if you have any further questions. Thanks!
(I had asked if there was any difference between the 2-1/4" and the
3-1/8" models.) Not bad!
Martin
WT
Old May 28th 08, 07:50 AM posted to rec.aviation.soaring
Darryl Ramm
Martin
WT
My more serious concern with the ADI is how exactly the unit performs
in a glider - especially given it is *not* a normal artificial
horizon. It displays what TruTrack calls "vertical velocity enhanced
pitch". So what happens to the pitch indication when you encounter
significant change in vertical speed say in wave or even in a thermal.
Anybody have any actual experience using one of these? The pitch
indication behavior? How does the unit handle continuous high turn
rate thermalling?
Darryl
Old May 28th 08, 02:52 PM posted to rec.aviation.soaring
JJ Sinclair
I have been flying with the TruTrack for a year now and find it just
what I want. I use it when getting close to shear lines marked by Q's
that don't have a firm base and step-up 1000 feet from one side to the
other, like we get all the time here in the Mendacino Mountains. It is
instant-on and it can be turned on while in a bank...............comes
right up to show your correct bank angle. It looks like a gyro, but
shows no pitch information. I have had it on for 30 minutes and it
always showed the correct attitude. Plenty good enough to execute a
180 in order to get out of an unexpected IFR situation, just maintain
your cruise speed which will keep the pitch under control and crank it
around using the TruTrack....................Please no hate-mail about
the FAR's, I use it just in case I'm fiddling with the computer one
day and suddenly find everything has turned gray!
JJ
rate thermalling?
Darryl
Old May 28th 08, 03:18 PM posted to rec.aviation.soaring
Darryl Ramm
JJ
rate thermalling?
Darryl
JJ
Just to be clear. TruTrak (I keep forgetting to forget the c) is the
company, they make multiple products. You are talking about a TruTrak
Pictorial Turn and Bank, which I also have in my glider and I am also
impressed with. Marty is talking about the TruTrak ADI - an artificial
horizon. It is the pitch information in the artificial horizon that I
am mostly questioning. It would be great if it works as well as their
pictorial turn and bank, but they've not answered questions about this
when I tried before and so far I've not heard of anybody who has
really shaken one of these out in a sailplane.
Darryl
Old May 28th 08, 06:31 PM posted to rec.aviation.soaring
bumper
Concurring with Darryl, it should also be noted that the TruTrak pictorial
turn and bank (roll info only), is usually ordered set at a 1" minute
standard turn rate for glider use (we turn a lot and steeply). For power
plane use, and the default setting, it's typically set at a 2-minute turn
rate as this is the standard rate turn for instrument flying.
So, is the ADI version (with pitch), also available in the 1-minute turn
rate for gliders?
I'm also using and am happy with the roll only TruTrak.
bumper
"Darryl Ramm" wrote in message
JJ
rate thermalling?
Darryl
JJ
Darryl
Old May 28th 08, 10:52 PM posted to rec.aviation.soaring
Darryl Ramm
rate for gliders?
bumper
JJ
rate thermalling?
Darryl
JJ
Darryl
Bumper
If it is an artificial horizon/ADI it should show bank angle not turn
rate. Their documentation says bank angle.
Darryl
Non-starving pilot artists draw BIG! Jim Logajan Piloting 2 March 12th 08 01:34 PM
Trutrak auto pilot davidh Home Built 2 November 21st 07 12:48 AM
King KLX 135 and TruTrak "Digitrak" autopilot... [email protected] Home Built 3 August 31st 05 05:28 AM
TruTrak Solid-State T&B Jim Hendrix Soaring 10 August 31st 04 06:46 PM
Where do you draw the line? Bruce Greeff Soaring 4 July 1st 04 07:59 PM
