Trouble filing IFR to Canadian Airports
Old June 2nd 08, 04:52 AM posted to rec.aviation.ifr
Andrew Sarangan
Default Trouble filing IFR to Canadian Airports
I've made this flight many times before and never encountered this
before. I filed from my home airport (MGY) to PT(which is an NDB) to
CYKZ using DUATS. Everything went fine. When I called for my
clearance, they didn't have anything on me. So I departed VFR, and
tried calling again. Still no luck. They tried manually entering my
flight, but then said they had trouble entering my Canadian waypoint
and destination so I better call Flight Service. I filed with FSS and
called ATC again, but still ATC had nothing for me. I called FSS
again. Now he says his computer would not take CYKZ or PT, and the
only way he could do this is if I provided the lat/lon for these
places. After shuffling through a lot of mess, I found the co-
ordinates for CYKZ and read the numbers. I said forget the enroute
waypoint; I'll go direct. After nearly one hour after departure I
finally got my clearance. It was good time too because we were in IMC
not too long after that.
I was totally puzzled by this. Since when did Canadian airports and
navaids disappear from US computers?
Old June 4th 08, 08:09 PM posted to rec.aviation.ifr
Robert M. Gary
I've done this by filing an international flight plan. Is that what
you are doing or are you trying to file an FAA IFR plan? The
international is the long form that asks about ADF, VORs, etc
installations.
-Robert
Old June 5th 08, 04:30 PM posted to rec.aviation.ifr
Andrew Sarangan
installations.
-Robert- Hide quoted text -
- Show quoted text -
No, I filed an FAA flight plan using DUATS. It worked every single
time in the past. I have even filed FROM Canada to the US using DUATS
and it has always worked. This time, DUATS accepted it, but nothing
got transmitted to ATC. I am going to try again on my way back this
weekend. It could have been a temporary glitch.
Old June 7th 08, 05:41 AM posted to rec.aviation.ifr
Andrew Sarangan
Well, I filed CYKZ to KBUF using DUATS and the tower at CYKZ had my
IFR clearance without any problems. So the problem appears to be with
FSS and ATC. They were unable to enter the Canadian destinations, but
DUATS seems do the job.
Old June 7th 08, 12:57 PM posted to rec.aviation.ifr
Paul Tomblin
Not quite the same thing, but every time I fly IFR to Ottawa, I get told
to fly the CYRIL SEVEN STAR. But DUATS and Flight Service won't accept
CYRIL as a waypoint, so I file to ART, then direct. And as I get close to
ART, Wheeler-Sack Approach comes on the air and says "I have a revised
clearance for you", and then clears me to fly to CYRIL and then the CYRIL
SEVEN arrival.
Paul Tomblin http://blog.xcski.com/
[Y]ou should write for the comprehension of the next programmer who
looks at your code, keep it clean and sensible, and *not* play
any obscure Jedi mind-tricks. -- Anthony de Boer
What happened to Canadian airports on Skyvector and Aeroplanner? Andrew Sarangan Piloting 6 May 6th 08 09:57 PM
filing stars Brad Salai Instrument Flight Rules 7 August 10th 05 10:19 PM
Filing with a STAR Paul Tomblin Instrument Flight Rules 25 October 16th 04 04:23 AM
Canadian Maritime Airports: Request for Info David Megginson Piloting 0 July 22nd 04 03:24 PM
filing with DUATS Ditch Instrument Flight Rules 20 January 14th 04 09:38 AM
