Yesterday on the takeoff roll, I discovered my airspeed indicator was
stuck. I got off tow a little early, and returned to the field to sort things out. Back on the ground, I visually inspected the pitot tube (in the vertical fin on my Ventus 2bx), removed and blew out the short pitot tube, and put it back on. Then I verified that the airspeed indicator responded correctly when I (carefully!) blew into the pitot tube. Problem solved (I thought) On tow again, I found I had the same problem - hmm. OK, I'm an experienced soaring pilot, and I don't need no stinking airspeed indicator, so off I go cross-country. As luck (or lack of airspeed indications) would have it, I landed out after 200km, about 30 miles from home - ah well. While waiting for my crew, I had plenty of time to troubleshoot the ASI problem. I repeated the steps I had done before, and verified that the ASI responded correctly on the ground - how could this be? Then I had the bright idea that the difference might be the position of the instrument panel - tilted up or down in the Ventus. So, I put the panel down in the flying position, and voila - the ASI sticks! Tilted it back up, and the ASI works fine. Tilt back down, ASI sticks. Of course, the original ground check had been done with the panel tilted up - lucky me! After a number of other experiments, I was able to confirm to my satisfaction that no tubing was being pinched when the panel was put in the flying position, and the only variable was the orientation (tilted or horizontal) of the instrument itself. This is a fairly new instrument (circa 2002), so I'm puzzled by this apparent failure. Anyone have any ideas? TIA, Frank |
On Jun 2, 9:04 am, Frank wrote:
Yesterday on the takeoff roll, I discovered my airspeed indicator was stuck. I got off tow a little early, and returned to the field to sort things out. Back on the ground, I visually inspected the pitot tube (in the vertical fin on my Ventus 2bx), removed and blew out the short pitot tube, and put it back on. Then I verified that the airspeed indicator responded correctly when I (carefully!) blew into the pitot tube. Problem solved (I thought) On tow again, I found I had the same problem - hmm. OK, I'm an experienced soaring pilot, and I don't need no stinking airspeed indicator, so off I go cross-country. As luck (or lack of airspeed indications) would have it, I landed out after 200km, about 30 miles from home - ah well. While waiting for my crew, I had plenty of time to troubleshoot the ASI problem. I repeated the steps I had done before, and verified that the ASI responded correctly on the ground - how could this be? Then I had the bright idea that the difference might be the position of the instrument panel - tilted up or down in the Ventus. So, I put the panel down in the flying position, and voila - the ASI sticks! Tilted it back up, and the ASI works fine. Tilt back down, ASI sticks. Of course, the original ground check had been done with the panel tilted up - lucky me! After a number of other experiments, I was able to confirm to my satisfaction that no tubing was being pinched when the panel was put in the flying position, and the only variable was the orientation (tilted or horizontal) of the instrument itself. This is a fairly new instrument (circa 2002), so I'm puzzled by this apparent failure. Anyone have any ideas? TIA, Frank Only time I had this happen was after I'd had the panel out of one of my gliders. I had a four line quick connect for panel removal. All appeared to work properly on the ground during pre-flight, but on tow the ASI stuck at 90kts at all speeds. After flying around for a while (watching the Blue Angels from a distance), I landed and reseated the quick connect fitting. Worked fine after that. Frank W |
what did you get out of the Pitot tube when you blew it out? Mud Daubers?
Water? water could be lying in a line that moves as the attitude of the lines change.....mud daubers leave mud in the lines that hardens to solid dry dirt (like cement) than could also be traveling in the lines with pressure. also since the needle is very close to the glass faceplate check to see that it isn't bent or have moisture inside the face that could cause enough friction to cause it to stick tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Frank" wrote in message ... Yesterday on the takeoff roll, I discovered my airspeed indicator was stuck. I got off tow a little early, and returned to the field to sort things out. Back on the ground, I visually inspected the pitot tube (in the vertical fin on my Ventus 2bx), removed and blew out the short pitot tube, and put it back on. Then I verified that the airspeed indicator responded correctly when I (carefully!) blew into the pitot tube. Problem solved (I thought) On tow again, I found I had the same problem - hmm. OK, I'm an experienced soaring pilot, and I don't need no stinking airspeed indicator, so off I go cross-country. As luck (or lack of airspeed indications) would have it, I landed out after 200km, about 30 miles from home - ah well. While waiting for my crew, I had plenty of time to troubleshoot the ASI problem. I repeated the steps I had done before, and verified that the ASI responded correctly on the ground - how could this be? Then I had the bright idea that the difference might be the position of the instrument panel - tilted up or down in the Ventus. So, I put the panel down in the flying position, and voila - the ASI sticks! Tilted it back up, and the ASI works fine. Tilt back down, ASI sticks. Of course, the original ground check had been done with the panel tilted up - lucky me! After a number of other experiments, I was able to confirm to my satisfaction that no tubing was being pinched when the panel was put in the flying position, and the only variable was the orientation (tilted or horizontal) of the instrument itself. This is a fairly new instrument (circa 2002), so I'm puzzled by this apparent failure. Anyone have any ideas? TIA, Frank |
On Jun 2, 9:04*am, "Tim Mara" wrote:
what did you get out of the Pitot tube when you blew it out? Mud Daubers? Water? water could be lying in a line that moves as the attitude of the lines change.....mud daubers leave mud in the lines that hardens to solid dry dirt (like cement) than could also be traveling in the lines with pressure. also since the needle is very close to the glass faceplate check to see that it isn't bent or have moisture inside the face that could cause enough friction to cause it to stick tim Please visit the Wings & Wheels website atwww.wingsandwheels.com "Frank" wrote in message ... Yesterday on the takeoff roll, I discovered my airspeed indicator was stuck. *I got off tow a little early, and returned to the field to sort things out. Back on the ground, I visually inspected the pitot tube (in the vertical fin on my Ventus 2bx), removed and blew out the short pitot tube, and put it back on. *Then I verified that the airspeed indicator responded correctly when I (carefully!) blew into the pitot tube. Problem solved (I thought) On tow again, I found I had the same problem - hmm. *OK, I'm an experienced soaring pilot, and I don't need no stinking airspeed indicator, so off I go cross-country. *As luck (or lack of airspeed indications) would have it, I landed out after 200km, about 30 miles from home - ah well. While waiting for my crew, I had plenty of time to troubleshoot the ASI problem. *I repeated the steps I had done before, and verified that the ASI responded correctly on the ground - how could this be? Then I had the bright idea that the difference might be the position of the instrument panel - tilted up or down in the Ventus. *So, I put the panel down in the flying position, and voila - the ASI sticks! Tilted it back up, and the ASI works fine. *Tilt back down, ASI sticks. *Of course, the original ground check had been done with the panel tilted up - lucky me! After a number of other experiments, I was able to confirm to my satisfaction that no tubing was being pinched when the panel was put in the flying position, and the only variable was the orientation (tilted or horizontal) of the instrument itself. Frank, Check your static line, also. A blocked static (in the down position) will block pitot pressure from exiting the ASI and it won't move. I'd remove both lines and make sure you can blow back from the instrument panel to the probe. Sounds like a mud-dauber problem to me. I have seen these little buggers build a nest in one afternoon. I put in one of Tim's plugs right after I remove the triple probe. JJ This is a fairly new instrument (circa 2002), so I'm puzzled by this apparent failure. *Anyone have any ideas? TIA, Frank- Hide quoted text - - Show quoted text - |
On Jun 2, 1:23*pm, JJ Sinclair wrote:
...I have seen these little buggers build a nest in one afternoon... I can top that - I've had them build two nests in a single afternoon. I found the first one on pre-flight, cleaned it out, and mama wasp built another nest before I launched. |
"Frank" wrote in message ... Yesterday on the takeoff roll, I discovered my airspeed indicator was stuck. I got off tow a little early, and returned to the field to sort things out. Back on the ground, I visually inspected the pitot tube (in the vertical fin on my Ventus 2bx), removed and blew out the short pitot tube, and put it back on. Then I verified that the airspeed indicator responded correctly when I (carefully!) blew into the pitot tube. Problem solved (I thought) On tow again, I found I had the same problem - hmm. OK, I'm an experienced soaring pilot, and I don't need no stinking airspeed indicator, so off I go cross-country. As luck (or lack of airspeed indications) would have it, I landed out after 200km, about 30 miles from home - ah well. While waiting for my crew, I had plenty of time to troubleshoot the ASI problem. I repeated the steps I had done before, and verified that the ASI responded correctly on the ground - how could this be? Then I had the bright idea that the difference might be the position of the instrument panel - tilted up or down in the Ventus. So, I put the panel down in the flying position, and voila - the ASI sticks! Tilted it back up, and the ASI works fine. Tilt back down, ASI sticks. Of course, the original ground check had been done with the panel tilted up - lucky me! After a number of other experiments, I was able to confirm to my satisfaction that no tubing was being pinched when the panel was put in the flying position, and the only variable was the orientation (tilted or horizontal) of the instrument itself. This is a fairly new instrument (circa 2002), so I'm puzzled by this apparent failure. Anyone have any ideas? TIA, Frank Frank: Isolate the problem stepwise-- Remove all lines from ASI Get a small medical syringe or similar and tubing, and put in 2-3 cc of air into the pitot line. Do this with panel down. If it works then, it is plumbing. If not, it is ASI internal problem. If ASI problem, remove from panel and retest. If not ASI, remove all connections to pitot (electronic TE, etc) and plug them. Use large syringe to pressurize the pitot line in reverse--i.e., from instrument connection end to pitot probe end, but be careful--don't blow the tubing off the internal connection to the probe. Then check for static line obstruction, same way. You could also use the large syringe to apply negative pressure at the instrument end and suck out water etc. This should diagnose it for you. Hartley Falbaum USA "KF" |
Well, yesterday I replaced my old ASI with a new one from Eastern
Sailplane, and verified that the old one was defective. I could hold the old ASI with it's face oriented vertically (normal orientation in flight) and it would stick. Oriented with its face tilted up about 30 degrees (as if it was installed in the Ventus with the instrument panel raised), and it worked fine. Gotta love Murphy's law! Frank On Jun 2, 11:04*am, Frank wrote: Yesterday on the takeoff roll, I discovered myairspeedindicatorwas stuck. *I got off tow a little early, and returned to the field to sort things out. Back on the ground, I visually inspected the pitot tube (in the vertical fin on my Ventus 2bx), removed and blew out the short pitot tube, and put it back on. *Then I verified that theairspeedindicator responded correctly when I (carefully!) blew into the pitot tube. Problem solved (I thought) On tow again, I found I had the same problem - hmm. *OK, I'm an experienced soaring pilot, and I don't need no stinkingairspeedindicator, so off I go cross-country. *As luck (or lack ofairspeed indications) would have it, I landed out after 200km, about 30 miles from home - ah well. While waiting for my crew, I had plenty of time to troubleshoot the ASI problem. *I repeated the steps I had done before, and verified that the ASI responded correctly on the ground - how could this be? Then I had the bright idea that the difference might be the position of the instrument panel - tilted up or down in the Ventus. *So, I put the panel down in the flying position, and voila - the ASI sticks! Tilted it back up, and the ASI works fine. *Tilt back down, ASI sticks. *Of course, the original ground check had been done with the panel tilted up - lucky me! After a number of other experiments, I was able to confirm to my satisfaction that no tubing was being pinched when the panel was put in the flying position, and the only variable was the orientation (tilted or horizontal) of the instrument itself. This is a fairly new instrument (circa 2002), so I'm puzzled by this apparent failure. *Anyone have any ideas? TIA, Frank |
| Thread Tools | |
| Display Modes | |
| Airspeed Indicator problems | [email protected] | Soaring | 6 | June 19th 07 03:33 AM |
| Airspeed Indicator Accuracy Tolerance | O. Sami Saydjari | Instrument Flight Rules | 11 | January 26th 06 01:48 AM |
| verifying airspeed indicator | Heino & Deanne Weisberg | Home Built | 11 | October 22nd 05 08:36 PM |
| Need glider airspeed indicator | [email protected] | Soaring | 1 | June 21st 05 10:57 PM |
| Inaccurate airspeed indicator | Wyatt Emmerich | Instrument Flight Rules | 20 | April 20th 04 01:08 AM |
