question about EZRocket
Old September 22nd 03, 04:15 AM
Frederick Wilson
Default question about EZRocket
I saw a thing on Travel Channel tonight that was showing off the EZRocket.
This raised a couple of questions.
It looked like he has that thing going straight up. How can this be, with
that canard wing. Other than just brute force I thought for sure it would
stall?
Second, what is the landing speed of one of them things? It seemed like he
was hauling @$$ when he landed.
Thanks,
Fred
Old September 22nd 03, 03:00 PM
Rick Pellicciotti
"Frederick Wilson" wrote in message
et...
stall?
Thanks,
Fred
Lot's of good information about it he
http://www.xcor.com/ez.html
Paraphrasing from the web site, "The airplane performs about the same as a
O-320 powered Long-EZ".
Old September 21st 03, 09:33 PM
David O
My O-320 powered Long EZ doesn't climb at 10,000 fpm at Vne.
Actually, Rick, the web site says, "Single engine performance is
similar to a Lycoming O-320 with constant speed prop." So in that
statement they are talking about performance with only one of the two
rockets firing. Even so, the statement is not entirely accurate.
David O -- http://www.AirplaneZone.com
Old September 30th 03, 08:42 PM
Dan DeLong
As Dave Barry would say, "an alert reader....".... You are correct in
your observation. The more complex and more correct statement is that
the single engine ground roll and takeoff are similar to an O-320 with
constant speed prop at a low MSL airport. After takeoff, the piston
engine/prop thrust drops with indicated speed whereas the rocket
engines have constant thrust. Also, the piston engine power drops with
altitude.
And the reason for the short airshow routine was because the events
coordinator asked us to keep it short. Otherwise, Dick would have done
a second go-around (which he practiced at Mojave the week before). We
landed with about half of the propellants remaining, which was why we
did the LOX vent after landing and before rolling into the crowd. Too
bad; that second go-around is more impressive at lighter weight.
Glide and landing are similar to a standard Long, except that the
rocket has less drag (the added fuel tank has less drag than the prop
and cooling drag did), and the belly board is less effective ahead of
the fuel tank.
Dan DeLong
XCOR Aerospace
Old October 1st 03, 05:38 AM
David O
David O --
altitude.
the fuel tank.
Dan DeLong
XCOR Aerospace
Yes, Dan, I ran the numbers for a flat 400 pound thrust using the drag
curve of my Long EZ at 1200 lb. Best rate of climb was 2,770 fpm at
130 kt. That's why I concluded, "not entirely accurate". I then ran
the numbers for both engines firing and got a best rate of climb of
8,100 fpm at 185 kt with an aircraft weight of 1200 lb.
As for the LOX vent at Oshkosh 2002, that was something to see. I
think it was you I questioned afterward and you said it really was not
dangerous without some sort of fuel to burn. You (or whomever) said
you had once purposely put a lit cigarette into the O2 cloud -- the
cigarette burned quite rapidly and that was the extent of the effect.
Thanks putting the videos on your XCOR web site. Riding along with
Dick was a trip. I could hear the concern in his voice on that early
run when the engine didn't shut off as commanded, "We've got a major
problem here."
Old October 1st 03, 06:03 PM
Dan DeLong
David O wrote in message . ..
David O --
Putting a lighted cigarette into a LOX tank vent plume would have been
a serious safety violation and we would not have done that. We *have*
done some flammability tests by holding small samples in a GOX plume
with tongs, gloves, and a fire extinguisher standing by. None of the
tests included a cigarette, but I expect the results would have been
as you described.
You may be recalling something that a crusty old engineer demonstrated
for me back in 1974 in the Life Support Lab at Westinghouse. He
started the lesson with "Don't you try this..." and proceeded to light
a cigarette. He then drew a lungful of oxygen from a mask on an
emergency medical bottle by the swimming pool, put the cigarette in
his mouth and slowly exhaled through it. The end of the cigarette got
really bright and it burned its full length in the one exhalation. I
would guess the gas he exhaled was about 60% oxygen because of mixing
with the residual gas in his lungs.
Saw your photos. Nice. I miss living in the homebuilt world, but my
job just takes too much time, and working on my Defiant is too much
like my day job now; it's not relaxing. And my tools are on loan to
XCOR.
Dan DeLong
David O
stall?
Thanks,
Fred
The best angle of climb is about 42 degrees at 80 kt, where the rate
of climb is about 5,500 fpm. The best rate of climb is about 10,000
fpm at the airplane's Vne (never exceed speed) of 195 kt, where the
angle of climb is about 30 degrees. The two rocket engines produce
400 pounds of thrust each. Touchdown speed is 55 to 60 kt just like
any other long EZ.
You'll find some close-up pictures and info in my Oshkosh Scrapbook
from last year, www.AirplaneZone.com/Oshkosh/Scrapbook2002
Select "Index" and scroll down to "Xcor EZ Rocket".
David O
Tailwheel question Steve B Aerobatics 4 January 30th 04 03:35 AM
Air compressor question Frederick Wilson Home Built 40 October 6th 03 02:50 AM
Question on Pulsejets/Ramjets??? DarylG1532 Home Built 3 August 16th 03 03:20 AM
AVID FLYER question OB1 Kanobe Home Built 0 August 14th 03 02:46 PM
question on intercoms for my new homebuilt w b evans Home Built 1 July 23rd 03 12:57 AM
