![]() gatts post on the dive spped of a trimmed power off aircraft seems to have vanished off my free agent. I experimented in the Tailwind on sunday to see what occurs on power off. now mind you the Tailwind isnt the usual FAR23 aircraft. It has no dihedral, neutral stability and not much inertia. it is however a dead honest airframe. I tried the suggestion regarding spiral instability while tootling over to Cape Naturaliste. If I set up the tailwind in balanced straight and level flight and take the hands and feet off everything the aircraft dives off in a spiral, which you'd expect from a neutrally stable aircraft encountering a gust. I tried setting everything up in balance then held my feet still on the rudders, hands off everything else. the aircraft flew with slight deviations in almost straight and level flight for 10 minutes or so. It showed no tendency toward instability which I must say surprised me. I then ran out of country and turned around back toward Busselton. I set the aircraft up again then did the throttle back to idle thing. as the power came off the tailwind put its nose down and entered an increasingly steepening turn to the right. I called it quits at that stage rather than have to walk home some 200 km. The turn is to be expected because of the rudder offset. Interesting. I didnt realise that the aircraft would be that stable if you held the rudder still. what michael (i think it was he) claimed regarding power off instability seems correct if the aircraft has no inherent stability. I think he overstates the tendency to instability for something with dihedral like the cessna 150 or piper 140. I'd would be interesting to try it in one of those aircraft. Stealth Pilot |
On Jun 9, 9:15*am, Stealth Pilot
I tried setting everything up in balance then held my feet still on the rudders, hands off everything else. the aircraft flew with slight deviations in almost straight and level flight for 10 minutes or so. It showed no tendency toward instability which I must say surprised me. The problem is that while you may think you held your feet still on the rudders, it is almost impossible to do. You will instinctively pick up a dropping wing with rudder. Prove it to yourself - hold the rudders still the same way you did before - but with your eyes closed. The airplane will dive off just the same as if your feet were off the rudders. Just don't do it for too long. Michael |
On Mon, 9 Jun 2008 07:16:08 -0700 (PDT), Michael
wrote: On Jun 9, 9:15*am, Stealth Pilot I tried setting everything up in balance then held my feet still on the rudders, hands off everything else. the aircraft flew with slight deviations in almost straight and level flight for 10 minutes or so. It showed no tendency toward instability which I must say surprised me. The problem is that while you may think you held your feet still on the rudders, it is almost impossible to do. You will instinctively pick up a dropping wing with rudder. Prove it to yourself - hold the rudders still the same way you did before - but with your eyes closed. The airplane will dive off just the same as if your feet were off the rudders. Just don't do it for too long. Michael no movement. the inner soles were pressed together and locked rock solid. have you ever flown a Tailwind? Stealth pilot |
On Jun 11, 1:04*am, Stealth Pilot
wrote: On Mon, 9 Jun 2008 07:16:08 -0700 (PDT), Michael wrote: On Jun 9, 9:15*am, Stealth Pilot I tried setting everything up in balance then held my feet still on the rudders, hands off everything else. the aircraft flew with slight deviations in almost straight and level flight for 10 minutes or so. It showed no tendency toward instability which I must say surprised me. The problem is that while you may think you held your feet still on the rudders, it is almost impossible to do. *You will instinctively pick up a dropping wing with rudder. *Prove it to yourself - hold the rudders still the same way you did before - but with your eyes closed. *The airplane will dive off just the same as if your feet were off the rudders. *Just don't do it for too long. Michael no movement. the inner soles were pressed together and locked rock solid. have you ever flown a Tailwind? A bad idea when landing unless the runway is long and/or you are not in a tail dragger. If you mean the plane designed by Wittman, which model number (W0-) Cheers |
On Tue, 10 Jun 2008 13:47:26 -0700 (PDT), More_Flaps
wrote: On Jun 11, 1:04*am, Stealth Pilot wrote: On Mon, 9 Jun 2008 07:16:08 -0700 (PDT), Michael wrote: On Jun 9, 9:15*am, Stealth Pilot I tried setting everything up in balance then held my feet still on the rudders, hands off everything else. the aircraft flew with slight deviations in almost straight and level flight for 10 minutes or so. It showed no tendency toward instability which I must say surprised me. The problem is that while you may think you held your feet still on the rudders, it is almost impossible to do. *You will instinctively pick up a dropping wing with rudder. *Prove it to yourself - hold the rudders still the same way you did before - but with your eyes closed. *The airplane will dive off just the same as if your feet were off the rudders. *Just don't do it for too long. Michael no movement. the inner soles were pressed together and locked rock solid. have you ever flown a Tailwind? A bad idea when landing unless the runway is long and/or you are not in a tail dragger. If you mean the plane designed by Wittman, which model number (W0-) Cheers W8 with the "new improved wing" (look on the plans for an explanation) |
gatts post on the dive spped of a trimmed power off aircraft seems to have vanished off my free agent. The name of the thread is "CFI Oral intel." Interesting. I didnt realise that the aircraft would be that stable if you held the rudder still. what michael (i think it was he) claimed regarding power off instability seems correct if the aircraft has no inherent stability. Fascinating. Thanks for the report. -c |
Looking for a PIREP - GATTS | mbremer216 | Instrument Flight Rules | 0 | June 3rd 06 01:38 AM |
PIREP Request - GATTS IFR Training | mbremer216 | Owning | 0 | June 2nd 06 02:52 AM |
IO 360 Power down (danger, long, rambling post!) | Jim Harper | Home Built | 24 | July 11th 04 12:04 AM |
Why do constant speed power setting charts limit RPM? | Ben Jackson | Piloting | 6 | April 16th 04 03:41 AM |
Jet fighter top speed at military power | David L. Pulver | Military Aviation | 18 | December 1st 03 07:13 PM |
