See:
http://www.aviationweek.com/aw/gener...hannel=defense I suppose that will allow the P-8A to use MAD while staying at high altitude. But is the small, disposable MAD gear a Scan Eagle would carry as good as the tail stinger on a larger aircraft? |
On Jun 11, 12:16*am, Dave wrote:
wrote : See: http://www.aviationweek.com/aw/gener...s/SCAN060908.x.... eadline=Boeing%20Reveals%20Sub-Tracking%20ScanEagle%20Study&channel=defen se I suppose that will allow the P-8A to use MAD while staying at high altitude. *But is the small, disposable MAD gear a Scan Eagle would carry as good as the tail stinger on a larger aircraft? Probably. The external magnetic influences would certainly be much smaller.. In addition, using 21st century technology, instead of '70s or '80s, would likely make a smaller, more efficient package. Dave in Sandy Eggo AT1, USN (Ret) More on UAV's that might someday be launched from the P-8A: http://www.aviationweek.com/aw/blogs...3-d22a245e68c9 BTW, the article in the original post says the ScanEagle is supposed to follow a submarine around for up to 24 hrs. Is that possible with just a MAD? I thought MAD was usually used to confirm sonar contacts, and pin down the Sub's locations for a more accurate torpedo drop. |
It looks like the P-8 is going to use expendable UAV's to look
at surface targets too: http://www.aviationweek.com/aw/blogs...5-6ca2d4b9d24d Using expendable UAV's for routine missions like this could get expensive after awhile. |
On Fri, 27 Jun 2008 09:09:22 -0700 (PDT), wrote:
It looks like the P-8 is going to use expendable UAV's to look at surface targets too: http://www.aviationweek.com/aw/blogs...5-6ca2d4b9d24d Using expendable UAV's for routine missions like this could get expensive after awhile. For routine missions you wouldn't. |
:It looks like the P-8 is going to use expendable UAV's to look :at surface targets too: : :http://www.aviationweek.com/aw/blogs...5-6ca2d4b9d24d : :Using expendable UAV's for routine missions like this could get :expensive after awhile. : Apparently that costs less than the loss of airframe life from using the airplane to do it, which is why it's being considered. -- "Millions for defense, but not one cent for tribute." -- Charles Pinckney |
Cessna Reveals "Cirrus Killer" | Darkwing | Piloting | 31 | July 28th 06 07:29 PM |
For F-5 fans - Iran reveals new F-5 based twin-tailed Azarakhsh fighter | TJ | Military Aviation | 1 | July 11th 04 09:40 PM |
Britain Reveals Secret Weapon - Chicken Powered Nuclear Bomb ! | Ian | Military Aviation | 0 | April 2nd 04 03:18 PM |
Wild flight reveals gaps within FAA --Philadelphia Inquirer | News | Piloting | 0 | March 29th 04 01:30 AM |
Aviation Conspiracy: AP Reveals Series Of Boeing 777 Fires!!! | Bill Mulcahy | General Aviation | 18 | October 16th 03 09:15 PM |
