ASL CamGuard?
Old June 12th 08, 04:34 AM posted to rec.aviation.owning
Orval Fairbairn[_2_]
Default ASL CamGuard?
I just saw an ad for ASL CamGuard and wonder if anyone out there has any
experiences with this product that they would like to share.
Good?
Bad?
Neither?
Is it just a detergent or a balonium-based material, or does it have
lubricating properties, such as TCP has?
Remove _'s from email address to talk to me.
Old June 13th 08, 03:41 AM posted to rec.aviation.owning
Ray Andraka
Good?
Bad?
Neither?
Penn Yan recommended it to me just before they got FAA approval on the
stuff. I've been using it on Penn Yan's recommendation, but I can't
tell you whether it makes a difference or not. It is supposedly at rust
inhibitor additive. I don't know that it has any lubricating
properties. The claims seem more plausible than some of the claims of
past snake oils.
Old June 13th 08, 09:08 PM posted to rec.aviation.owning
Bob Fry
"OF" == Orval Fairbairn writes:
OF I just saw an ad for ASL CamGuard and wonder if anyone out
OF there has any experiences with this product that they would
OF like to share.
Aviation Consumer tested it favorably:
"The middle ground--and it's admittedly vast--is the 60 hour-a-year
owner who needs the airplane for three hours each December through
March. CamGuard is the clear winner here, since its performance is
nearly as good as the dedicated storage oils, it's cheaper and allows
normal operation.
Thus far, we've been impressed with CamGuard and we're using it in our
own airplane. As we go to press this month, CamGuard is on the verge
of obtaining FAA approval. Frankly, that doesn't impress us much but
some buyers want the FAA imprimatur. Approved or not, we think it's a
good product."
http://www.aviationconsumer.com/issu...rs/5541-1.html
OF Is it just a detergent
No. Detergents aren't used in aviation engines.
OF does it have lubricating properties, such as TCP has?
No. TCP isn't a lubricant. CamGuard is an anti-corrosion additive, not
a lubricant.
An old person said to a youth, 'As you are, I once was; as I am, you
shall be.'
~ Mexican proverb
Old June 14th 08, 04:45 AM posted to rec.aviation.owning
OF like to share.
normal operation.
good product."
a lubricant.
I want to thank everybody who responded. I may just try the stuff!
Orval
Old July 8th 08, 12:36 PM
Edward Kollin Edward Kollin is offline
Junior Member
First recorded activity by AviationBanter: Jul 2008
Quote:
Originally Posted by Orval Fairbairn[_2_] View Post
Bob Fry
writes:
OF like to share.
normal operation.
good product."
a lubricant.
Orval
Camguard is conceptually the additive package that I designed for the Exxon Elite oil. It contains 11 additives and is 100% active. It prevents rust/corrosion and deposits, reduces wear and conditions seals.
I was the director of the engine laboratory at Exxon Research and Engineering
and performed the initial research on the Elite oil. Exxon management decided to copy the Aeroshell oil. When I left Exxon I was asked to formulate Camguard.
Regards,
Ed
Old July 8th 08, 05:46 PM posted to rec.aviation.owning
john smith
Engineering
formulate Camguard.
WOW!
If someone could get you and Ben Vissar together, that would be an
incredible forum on engine lubrication.
Old July 9th 08, 03:59 AM
Junior Member
Quote:
Engineering
formulate Camguard.
WOW!
Ben is a great guy! He offered to help us with the Camguard certification.
Regards,
Ed
Old July 8th 08, 08:27 PM posted to rec.aviation.owning
Edward Kollin wrote:
'Orval Fairbairn[_2_ Wrote:
;639886']In article ,
Bob Fry
writes:--
OF like to share.
normal operation.
our
good product."
http://tinyurl.com/6ytgnn
not
a lubricant.-
Orval
seals.
Engineering
formulate Camguard.
Regards,
Ed
Thank you! I just received four pints and am going to put some in both
my airplane and my vintage Porsche.
Old July 9th 08, 04:06 AM
Junior Member
Camguard is really useful for older cars, as you get a substantial corrosion inhibiting boost and anti-wear protection superior to ZDDP.
