navigation question
Old February 22nd 04, 02:09 AM
mah
Default navigation question
Was toying with my gps recently and plotted a course from my home in the
midwest to London Heathrow. I know it uses great circle routing to
calculate the distance and course. Going from west to east it shows a
course of about 45 degrees. On the return trip it shows an intial
course of 310 degrees.
Now, to my old mind, I would have thought a reciprical course of 225 .
It is something in the spherical formula used for the great circle but
I'm too rusty to work through it.
An old navigators who want to help me out?
Thanks in advance.
MAH
Old February 22nd 04, 02:25 AM
John R Weiss
"mah" wrote...
A reciprocal initial heading works for a rhumb line (constant heading) course,
but not for a great circle course (except along the Equator or any longitude
line. In all other cases, great circle routes are curved when plotted on a
Mercator map.
Old February 22nd 04, 10:27 AM
Cub Driver
You answered the question yourself: it was a Great Circle route. The
heading would change continuously in theory, at intervals in practice.
I wouldn't worry about it, if I were you. Trust your GPS. If you ever
do it in practice, you can always brush up on your celestial
navigation.
all the best -- Dan Ford
email: (requires authentication)
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old February 22nd 04, 01:42 PM
Eugene Griessel
mah wrote in message ...
You do not give a lat/long for your home position so a logical answer
is problematical. However a great circle from Heathrow on the angle
of departure you indicate would pass through (roughly) Upper Heyford,
Avon, Kidderminster, Highley and Westbury. However 310 is probably a
rather rough heading for calculations (I know my GPS only gives exact
degrees) so the track may lie considerably to the North or South is
the range is 309 - 311.
Old February 25th 04, 11:25 AM
mah
Thanks to all who replied. Occasionally I need to scrape the rust off
the neurons and exercise things.
MAH
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 06:05 PM
