How Beat The High Cost Of Fuel: The ElectraFlyer-C
Old June 17th 08, 03:37 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Larry Dighera
Default How Beat The High Cost Of Fuel: The ElectraFlyer-C
Randall Fishman, president of Electric Aircraft Corp., flew his
ultralight trike at EAA Airventure 2007, Oshkosh. "I flew the trike
in front of the crowds, and the trike was mobbed with people every
day. The EAA folks really loved the idea." The ElectraFlyer won the
Grand Champion Ultralight and Innovation awards.
This year Fishman hopes to fly his new ElectraFlyer-C (a re-engined
Moni motorglider with an 18-horsepower electric motor) at EAA
Airventure 2008. The ElectraFlyer-C cruises at 70 mph, stalls at 45
mph, and has a top speed of 90 mph and a flight duration of ~1-1/2
hours. The electric motor directly drives a 45-inch ground
adjustable, two-blade PowerFin carbon fiber propeller, which lifts the
aircraft at a climb rate of 500 to 600 fpm. The experimental
amateur-built airplane is currently in its required 40-hour flight
testing phase.
http://registry.faa.gov/aircraftinqu...cmndfin d.y=5
The motor is powered by a 78 pound, custom-built lithium-ion polymer
battery with a power output of "5.6 kilowatt hours"; projected life is
300 to 500 full discharge cycles or more than 1,000 partial cycles.
The battery can be recharged in as little as two hours using a
220-volt charger (or six hours with a 110-volt charger). The cost for
a full recharge is 70 cents with the 110-volt charger. Fishman says
it's feasible to carry a small 110-volt charger as baggage on
cross-country flights.
More information:
http://www.flickr.com/photos/2722498...56704/sizes/o/
http://www.electraflyer.com/electraflyerc.html
http://www.flickr.com/photos/2722498...7605355156982/
Video: http://www.electraflyer.com/news.html
http://www.aero-news.net/news/sport....e-f146a285a148
Old June 22nd 08, 05:05 AM
opqr304 opqr304 is offline
Junior Member
First recorded activity by AviationBanter: Jun 2008
Red face 41
Very splendid, I like very muchhentai sexshower sexbritish office sexpublic sex videosfree anime sex videos
__________________
health
Old June 22nd 08, 04:42 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Richard Riley[_1_]
1 horsepower = .75kw. So 5.6 kilowatt hours is only 7.51 horsepower
hours. Good enough for a short burst to get you to altitude and soar
the thermals, bu you aren't going anywhere cross country.
Compare it to a really inefficient 2 stroke, burning .6 lb/hp-hr.
Your battery is equal to .75 gallons of gas.
Old June 22nd 08, 11:26 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Larry Dighera
On Sat, 21 Jun 2008 20:42:12 -0700 (PDT), Richard Riley
wrote in
I would say that depends on how much power the aircraft requires for
sustained level flight. If that can be achieved on 5 hp, the battery
will theoretically provide 1.5 hours run time (assuming 100%
efficiency).
What is the difference in cost between that amount of fuel and the
cost to charger the battery? Noise? Vibration? Reliability? ...
I give Mr. Fishman credit for the success his project has achieved to
date considering its funding and staff.
Old June 25th 08, 04:44 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Bill Daniels
True for chemical batteries but EEStor devices store energy as an
electrostatic charge. If their press is to be believed, they have 10 - 100x
the capacity per pound as lithium ion. Even with lithium chemistry, silicon
nanowire anodes from Stanford promise 10x the charge.
Electric power is a fast moving target these days. Who is to say what might
be possible. Don't write it off too quickly.
"Bryan Martin" wrote in message
One major problem with battery powered electric systems is that all the
reactants must be carried onboard. This puts them at a major
disadvantage with fuel burning systems. An aircraft with a fuel burning
engine only has to carry its fuel onboard, the oxidizer is pulled out of
the air. This give a fuel burning engine a major weight and range
advantage over a battery powered electric system.
Bryan Martin
N61BM, CH 601 XL, Ram Subaru, Stratus redrive.
Old June 25th 08, 07:15 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
EEStor's claim's are a little too good to be believed by anyone that
knows anything about capacitors, and that's being charitable.
Time will tell if their product matches their press releases.
One problem with using capacitors for energy storage for stuff like
motors is the discharge curve which will require some rather heavy
voltage conversion trickery, though the problem isn't that big a deal
for a ground vehicle.
Jim Pennino
Remove .spam.sux to reply.
Old June 22nd 08, 02:20 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Scott[_7_]
Wait a second...5.6 KWH doesn't really tell you how much HP it is, does
it? All it says is that it consumes 5.6KW in an hour. If you only ran
the motor for 5 minutes per hours, the HP would be 12 times that or
approx. 90 HP. Using KW HOURS doesn't tell the whole story. Running a
100W light bulb 10 hours uses 1 KWH and so does running a 500W bulb for
2 hours but the 500W bulb does more work at any instant in time (it's a
lot brighter!). Now, if that motor was rated at 5.6KW, then yes, I'd
agree it is about 7.5 HP.
Scott
Old June 22nd 08, 03:57 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Scott
True, KWH is a measure of energy, whereas HP (and KW) is a measure of
power. Of course, this makes me wonder why the OP said the battery has
a "power output" of 5.6KWH; that statement doesn't make any sense.
Granted, he was obviously talking about the capacity of the battery,
not the power output, but if somebody is making an electric plane one
would hope they would know their terminology
Old June 22nd 08, 04:21 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Frank Olson
Scott
The OP stated the motor was 18 H.P. "This year Fishman hopes to fly his
new ElectraFlyer-C (a re-engined Moni motorglider with an 18-horsepower
electric motor)..."
Old June 24th 08, 02:09 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Peter Dohm
"Scott" wrote in message
100W light bulb 10 hours uses 1 KWH and so does running a 500W bulb for 2
hours but the 500W bulb does more work at any instant in time (it's a lot
brighter!). Now, if that motor was rated at 5.6KW, then yes, I'd agree it
is about 7.5 HP.
Scott
You have a good point, but the KW Hours rating of the battery does seem a
bit low. Even when you consider that cooling drag nearly absent, what
little I think I know about the base airframe suggests that the battery
rating needs to be at least twice the stated amount in order to provide the
stated performance and endurance. The usual power of ten error in
transcription does not make much sense in this case, but there are
apparently two batteries of equal sive--and everything that I could find
appeared to originate from a single article.
In any case, it is interesting; but the economics really do not work based
upon the stated maximum10 year and 1000 hour battery battery life. Even if
the electricity was free and gasolene was more than twice its current cost,
the gasolene powered airplane, on which it is bsed, would still give much
greated utility for less cost. Nontheless, my hat's off to him for the
effort.
Peter
How Beat The High Cost Of Fuel: The ElectraFlyer-C Larry Dighera Piloting 71 June 26th 08 05:45 PM
Fighting the high cost of flying Jay Honeck[_2_] Piloting 31 June 11th 08 11:30 AM
High Cost of Sportplanes Gordon Arnaut Home Built 110 November 18th 05 10:02 AM
Fix the high cost [Was:] High Cost of Sportplanes Evan Carew Home Built 40 October 8th 05 04:05 AM
These are not YOUR airplanes - Was: High Cost of Sportplanes Lakeview Bill Home Built 28 September 21st 05 01:37 PM
