Some questions on HID lighting. I have a 1974 PA28-151 and would like
to replace my landing light (cowl mounted) with an HID light. I know about the boom beams, but I also see that Precise Flight makes HID lighting also, and it's about half the price of LoPresti's. I looked at Precise Flight's installation manual and noticed that it was written by Knots2U. In addition, it states that the lighting is for wing mounting only and for Piper models PA24/30/39 aircraft. My question is... a PAR36 bulb is a bulb is a bulb, isn't it? Aside from perhaps the legality of the FAA approving this STC for one specific location, wouldn't this bulb and installation kit work just as well for a cowl-mounted light? The specifications for this bulb are exactly the same specs as for all of the other HID bulbs, i.e. 500,000 CP, 35 watts, 12 volts, 2.5 Amps, PAR36, etc. Steve KDMW |
No the hid's might not fit in a space for an incandescent par36.
The high voltage connector/plug is a complication and may need extra space. Is the back of the bulb on your plane open to the cowel so that there is lots of space? I am unfamiliar with your situation. John Steve - KDMW wrote: Some questions on HID lighting. I have a 1974 PA28-151 and would like to replace my landing light (cowl mounted) with an HID light. I know about the boom beams, but I also see that Precise Flight makes HID lighting also, and it's about half the price of LoPresti's. I looked at Precise Flight's installation manual and noticed that it was written by Knots2U. In addition, it states that the lighting is for wing mounting only and for Piper models PA24/30/39 aircraft. My question is... a PAR36 bulb is a bulb is a bulb, isn't it? Aside from perhaps the legality of the FAA approving this STC for one specific location, wouldn't this bulb and installation kit work just as well for a cowl-mounted light? The specifications for this bulb are exactly the same specs as for all of the other HID bulbs, i.e. 500,000 CP, 35 watts, 12 volts, 2.5 Amps, PAR36, etc. Steve KDMW |
On Jun 28, 10:27*am, The Visitor
wrote: No the hid's might not fit in a space for an incandescent par36. The high voltage connector/plug is a complication and may need extra space. Is the back of the bulb on your plane open to the cowel so that there is lots of space? I am unfamiliar with your situation. John Steve - KDMW wrote: Some questions on HID lighting. I have a 1974 PA28-151 and would like to replace my landing light (cowl mounted) with an HID light. I know about the boom beams, but I also see that Precise Flight makes HID lighting also, and it's about half the price of LoPresti's. I looked at Precise Flight's installation manual and noticed that it was written by Knots2U. In addition, it states that the lighting is for wing mounting only and for Piper models PA24/30/39 aircraft. My question is... a PAR36 bulb is a bulb is a bulb, isn't it? Aside from perhaps the legality of the FAA approving this STC for one specific location, wouldn't this bulb and installation kit work just as well for a cowl-mounted light? The specifications for this bulb are exactly the same specs as for all of the other HID bulbs, i.e. 500,000 CP, 35 watts, 12 volts, 2.5 Amps, PAR36, etc. Steve KDMW- Hide quoted text - - Show quoted text - Thanks... there is a lof of open space behind the bulb, so much so that I can get to the back of it to change it without having to pull the cowl. A good 8-10 inches I would say. Steve KDMW |
You also need a place to mount the separate power supply, which is connected
via a cable to the bulb. It can be a distance away, like on the firewall, although you need to watch out for the generation of electrical noise in your radios/nav gear when doing so. I paid around $550 each from Xevision, for their brighter 50W bulbs. |
On Jun 27, 7:40*pm, Steve - KDMW wrote:
Some questions on HID lighting. I have a 1974 PA28-151 and would like to replace my landing light (cowl mounted) with an HID light. I know about the boom beams, but I also see that Precise Flight makes HID lighting also, and it's about half the price of LoPresti's. The HIDs are quite a bit deeper. And you need a place to mount the power supply. Around here, a local shop is installing them with a field approval. A sample 337 that has been approved would help you. I seem to be a corner case.... I installed one in my Bonanza and I've had trouble with the vibration killing the bulb. No one can figure it out. FWIW. Bill Hale Loveland CO I looked at Precise Flight's installation manual and noticed that it was written by Knots2U. In addition, it states that the lighting is for wing mounting only and for Piper models PA24/30/39 aircraft. My question is... a PAR36 bulb is a bulb is a bulb, isn't it? Aside from perhaps the legality of the FAA approving this STC for one specific location, wouldn't this bulb and installation kit work just as well for a cowl-mounted light? The specifications for this bulb are exactly the same specs as for all of the other HID bulbs, i.e. 500,000 CP, 35 watts, 12 volts, 2.5 Amps, PAR36, etc. Steve KDMW |
On Jun 28, 12:02*pm, "
wrote: On Jun 27, 7:40*pm, Steve - KDMW wrote: Some questions on HID lighting. I have a 1974 PA28-151 and would like to replace my landing light (cowl mounted) with an HID light. I know about the boom beams, but I also see that Precise Flight makes HID lighting also, and it's about half the price of LoPresti's. The HIDs are quite a bit deeper. *And you need a place to mount the power supply. Around here, a local shop is installing them with a field approval. *A sample 337 that has been approved would help you. I seem to be a corner case.... I installed one in my Bonanza and I've had trouble with the vibration killing the *bulb. *No one can figure it out. FWIW. *Bill Hale Loveland CO I looked at Precise Flight's installation manual and noticed that it was written by Knots2U. In addition, it states that the lighting is for wing mounting only and for Piper models PA24/30/39 aircraft. My question is... a PAR36 bulb is a bulb is a bulb, isn't it? Aside from perhaps the legality of the FAA approving this STC for one specific location, wouldn't this bulb and installation kit work just as well for a cowl-mounted light? The specifications for this bulb are exactly the same specs as for all of the other HID bulbs, i.e. 500,000 CP, 35 watts, 12 volts, 2.5 Amps, PAR36, etc. Steve KDMW- Hide quoted text - - Show quoted text - A field approval sounds like a good option. I don't think space is an issue for me, I have a good 8-10 inches clearance behind the bulb. Mounting the power supply to my firewall should be easy... that's how the boom beam would be done if I bought that (for $1100 versus the Precise Flight at $550). Steve KDMW |
Steve - KDMW writes:
A field approval sounds like a good option. I don't think space is an issue for me, I have a good 8-10 inches clearance behind the bulb. Mounting the power supply to my firewall should be easy... that's how the boom beam would be done if I bought that (for $1100 versus the Precise Flight at $550). Two issues come to mind besides clearance: vibration and temperature. Not sure if either is an issue, but... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
I installed HID lights in the wings of my Baron- they work great, use a lot
less current, and put out a lot more light. However, you do need some space for the power supply, and the bulb itself is deeper than a standard incandescent. I wanted to put one on the nose gear taxi light, but because of space concerns and the need to mount the power supply in the wheel well, where it might interfere with gear retraction, stuck with the standard taxi light. You will also need a field approval. We got ours approved prior to installation, which then took around three hours a side. I got mine from Xevision, since they make a 50W setup, which puts out more light, and was also a bit cheaper. Aviation Consumer had a great review of the various systems fairly recently. |
On Jun 27, 6:40*pm, Steve - KDMW wrote:
Some questions on HID lighting. I have a 1974 PA28-151 and would like to replace my landing light (cowl mounted) with an HID light. I know about the boom beams, but I also see that Precise Flight makes HID lighting also, and it's about half the price of LoPresti's. I looked at Precise Flight's installation manual and noticed that it was written by Knots2U. In addition, it states that the lighting is for wing mounting only and for Piper models PA24/30/39 aircraft. A bunch of us bought them around here. The shops started installing them until they realized the FSDO said there was no way they would ever approve them. I know some FSDOs have been totally happy with them but our FSDO doesn't want anything to do with them. Either call your FSDO or have your IA call before you get into the job. -robert |
Lighting | Rio | Aviation Photos | 0 | December 28th 07 02:13 AM |
HID Lighting | Mike Rapoport | Owning | 35 | October 5th 06 09:02 PM |
EL Cockpit Lighting? | JB | Owning | 10 | October 21st 05 07:23 PM |
Electroluminescent Lighting | dave | Home Built | 10 | February 27th 04 03:46 PM |
Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 06:06 AM |
