"Priceless" in Afghanistan
Old February 25th 04, 10:27 PM
BUFDRVR
Default "Priceless" in Afghanistan
kind of doubt a loaded B1B could fly supersonic that low. Max speed is
something like mach 1.2. Sounds like bull**** to me.
Sure they can. This is not the first (or, I'm sure last) time a Bone has done a
super sonic pass as a show of force over Afghanistan.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old February 26th 04, 11:37 PM
BUFDRVR
Why can't a B-1 go straight up (for however short a time)?...if
it can do a 60 deg attitude then are you telling us that it
cannot go another 30 deg?....why not?...
I'm sure it could, but how long they could do it, I don't know. Personally I
think a 60-degree climb to "out-of-sight" flight level is more impressive than
a 90-degree climb to a few thousand feet above where you started the climb.
BUFDRVR
Old February 27th 04, 07:27 AM
Jim Knoyle
"BUFDRVR" wrote in message
I
than
climb.
I'm still impressed years later after watching a U-2-R2 take off from
Moffett and disappear directly overhead at the Mt. View Baylands
where I stood. That's about 3 miles for the ground leg and if I knew
the altitude where it would disappear on a perfectly clear summer day
it would be a very simple trig. problem. Sure looked like straight up to me.
JK
Old February 27th 04, 10:23 PM
BUFDRVR
I don't doubt your assessment for a second...however...do you
really think that if an a/c can climb to 'out of sight' at 60 deg
that it can only climb a few thousand feet at 90?....doesn't
compute to me.
I'll only speak from personal experience here. Believe it or not, at one point
the B-52H held the Time to Climb record for its class (or at least, that's what
my FTU IP told me, although 8 years later I've not checked it out) and will
climb pretty good at an *initial* climb angle of 50-60 degrees. Now, if you
increase that angle of climb by just a few degrees, you get a very small VVI
increase, but a greater airspeed loss (ops checked by myself as a young
co-pilot with too agressive of a pull). I've never taken a BUFF to 90-degrees
in the real world, but if the sim is any indication, you could not sustain a
90-degree climb for more than 7-10 seconds before you ran out of flying
airspeed. In 7-10 seconds, by my guess, you would only climb about 3,000 feet
(if that). Now, perhaps a light weight Bone has greater excess thrust (easy to
check on fas.org), but I don't think a Bone could go verticle for too much
longer than a BUFF.
BUFDRVR
Old February 27th 04, 06:28 PM
Admin
"David Casey" wrote in message
On Thu, 26 Feb 2004 19:10:20 -0500, Allen Epps wrote in
May I introduce David Casey. He wants to join the Air National Guard in NM
but can't get the waiver. He's part of a group that still attempts to take
over certain areas on the usenets with this BS. He's part of the so called
404th that infests the us.* areas. Just ignore the idiot and press on.
Old February 28th 04, 04:27 AM
Admin
"Tank Fixer" wrote in message
k.net...
on Fri, 27 Feb 2004 18:44:04 GMT,
"Gord Beaman" ) "Gord Beaman" )
attempted to say .....
"Admin" wrote:
The fact remains that the B-1B is not designed for
a 90 degree vertical unless you like smacking the ground and spreading
yourself over a country mile.
Don't let's get all silly here...we're talking generalities and
I think most posters here seem to think (me too) that any a/c can
go vertical if even for a short time. There may be some with
particular reasons why they can't but in general they all can.
This makes sense to me. And as Judge Judy says "If it makes sense
to me then it's true!"
The B52 wasn't designed for low level penetration operations.
But then those SAC crews must have been wrong all those years for
practicing it....
Just what do you know about the B-52? You are an Army Guard. Let me
introduce another of the us.military.army 404k00ks.
Priceless in Afganistan breyfogle Military Aviation 18 February 24th 04 05:54 AM
Hillary's visit to Afghanistan JD Military Aviation 0 December 9th 03 03:23 AM
Were AC-130s used in daylight in Afghanistan? Ron Military Aviation 0 November 12th 03 12:16 AM
Will the Pakis get the Sparrow to work on their F-16As? Tom Cooper Military Aviation 13 October 3rd 03 02:40 PM
