Got a Cessna 206 that emits a steady tone during transmission only.
The pitch increases with rpm to a point where ATC refuses service. No tone is emitted on battery power only (Alt. off). No problem yesterday, problem today. Noise remains with audio panel on/off, using L/R trans switch, speaker on/off, swapping headsets(Bose). Aircraft has 95 amp alt. (belt drive), noise filter. Please email me if more infor. is needed. Thanks R |
On Sun, 29 Jun 2008 08:57:09 -0700 (PDT), "
wrote: Got a Cessna 206 that emits a steady tone during transmission only. The pitch increases with rpm to a point where ATC refuses service. No tone is emitted on battery power only (Alt. off). No problem yesterday, problem today. Noise remains with audio panel on/off, using L/R trans switch, speaker on/off, swapping headsets(Bose). Aircraft has 95 amp alt. (belt drive), noise filter. Please email me if more infor. is needed. Thanks R Sounds like a bad noise filter on the alternator. rj |
Take the alternator off and have your local alternator shop check the
"diodes" in it. They are not certified to repair it but they can sure check it out for you. Bad diodes will cause a hum that changes in pitch with rpm. They can also cause the alternator output to be unstable as seen in a quivering amp meter. |
I had a problem like this and it turned out to be a bad ground on the
ptt. On Jun 29, 2:34*pm, wrote: Take the alternator off and have your local alternator shop check the "diodes" in it. *They are not certified to repair it but they can sure check it out for you. *Bad diodes will cause a hum that changes in pitch with rpm. *They can also cause the alternator output to be unstable as seen in a quivering amp meter. |
| Micro Air transmission-garbled | [email protected] | Soaring | 7 | June 17th 07 04:50 PM |
| C206 rental - KS, OK, noth TX - where? | grumman_driver | Piloting | 3 | April 10th 06 07:12 PM |
| Subaru flywheel pto without transmission | [email protected] | Home Built | 2 | November 26th 05 09:00 AM |
| JPI 800 & GMA 340 into C206 in EASA countries? | Jouni Laukkanen | Owning | 3 | August 4th 05 08:30 AM |
| Transmission design? | Otto Gyro | Rotorcraft | 1 | November 7th 03 05:41 PM |
