Recently a set of DG-600 wings have shown up for sale. They are
damaged but don't apear to be beyond repair. I'm considering using a these wings for an experiment I've been toying with for some time. . I've never seen a DG-600 in person so I could use some help with a few basic questions. What is the weight of DG-600 wings? What is the max non-lifting weight of a DG-600? I found the empty weight and max gross weight but not the non-lifting weight. Does a DG-600 have automatic control hookups? Does a DG-600 have a flap/aileron mixer or are the control of the flap deflection and ailerons separate? Any other comments would also be useful. I would not be using the fuselage or tail surfaces, only the wings, flaps and ailerons. Thank you in advance. Dan Rihn ASW-20 WO |
Dan wrote:
Recently a set of DG-600 wings have shown up for sale. They are damaged but don't apear to be beyond repair. I'm considering using a these wings for an experiment I've been toying with for some time. . I've never seen a DG-600 in person so I could use some help with a few basic questions. What is the weight of DG-600 wings? I believe mine were around 150 lbs. each. What is the max non-lifting weight of a DG-600? I found the empty weight and max gross weight but not the non-lifting weight. 246 kg / 542 lbs. Does a DG-600 have automatic control hookups? Yes, via two torsion tubes per side. Does a DG-600 have a flap/aileron mixer or are the control of the flap deflection and ailerons separate? The DG-600 has flaperons, not separate aileron/flap. Marc |
The non-lifting weight is included he
http://www.gliding.co.uk/bgainfo/tec...60015and18.pdf I have an electroic copy of the flight manual if you want it - let me know. Regards Martyn At 18:10 06 July 2008, Dan wrote: Recently a set of DG-600 wings have shown up for sale. They are damaged but don't apear to be beyond repair. I'm considering using a these wings for an experiment I've been toying with for some time. . I've never seen a DG-600 in person so I could use some help with a few basic questions. What is the weight of DG-600 wings? What is the max non-lifting weight of a DG-600? I found the empty weight and max gross weight but not the non-lifting weight. Does a DG-600 have automatic control hookups? Does a DG-600 have a flap/aileron mixer or are the control of the flap deflection and ailerons separate? Any other comments would also be useful. I would not be using the fuselage or tail surfaces, only the wings, flaps and ailerons. Thank you in advance. Dan Rihn ASW-20 WO |
The non-lifting weight is in he
http://www.gliding.co.uk/bgainfo/tec...60015and18.pdf I have an electronic copy of the flight manual if you want it. Regards Martyn At 18:10 06 July 2008, Dan wrote: Recently a set of DG-600 wings have shown up for sale. They are damaged but don't apear to be beyond repair. I'm considering using a these wings for an experiment I've been toying with for some time. . I've never seen a DG-600 in person so I could use some help with a few basic questions. What is the weight of DG-600 wings? What is the max non-lifting weight of a DG-600? I found the empty weight and max gross weight but not the non-lifting weight. Does a DG-600 have automatic control hookups? Does a DG-600 have a flap/aileron mixer or are the control of the flap deflection and ailerons separate? Any other comments would also be useful. I would not be using the fuselage or tail surfaces, only the wings, flaps and ailerons. Thank you in advance. Dan Rihn ASW-20 WO |
On Jul 6, 11:57*am, Martyn Johnson
wrote: The non-lifting weight is in he http://www.gliding.co.uk/bgainfo/tec...60015and18.pdf I have an electronic copy of the flight manual if you want it. Regards Martyn At 18:10 06 July 2008, Dan wrote: Recently a set of DG-600 wings have shown up for sale. *They are damaged but don't apear to be beyond repair. *I'm considering using a these wings for an experiment I've been toying with for some time. * . I've never seen a DG-600 in person so I could use some help with a few basic questions. What is the weight of DG-600 wings? What is the max non-lifting weight of a DG-600? I found the empty weight and max gross weight but not the non-lifting weight. Does a DG-600 have automatic control hookups? Does a DG-600 have a flap/aileron mixer or are the control of the flap deflection and ailerons separate? Any other comments would also be useful. I would not be using the fuselage or tail surfaces, only the wings, flaps and ailerons. Thank you in advance. Dan Rihn ASW-20 WO- Hide quoted text - - Show quoted text - Thanks to both Marc and Martyn, this is exactly what I needed. Flaperons with torsion tubes will make my project easier. Now all I need is a little more ambition. Thanks again, Dan |
On Jul 6, 6:46*pm, Dan wrote:
On Jul 6, 11:57*am, Martyn Johnson wrote: The non-lifting weight is in he http://www.gliding.co.uk/bgainfo/tec...60015and18.pdf I have an electronic copy of the flight manual if you want it. Regards Martyn At 18:10 06 July 2008, Dan wrote: Recently a set of DG-600 wings have shown up for sale. *They are damaged but don't apear to be beyond repair. *I'm considering using a these wings for an experiment I've been toying with for some time. * |
Some SZD-55-1 Questions | WDM | Soaring | 13 | July 16th 13 04:41 AM |
PMA Questions | Mike Granby | Piloting | 24 | December 11th 05 11:24 PM |
Questions for Jay? | mikem | Owning | 8 | February 29th 04 02:09 PM |
Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 06:06 AM |
Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) | Jim Yanik | Military Aviation | 2 | October 9th 03 09:36 PM |
