Automotive alternators are sometimes installed on certified airplanes.
Are automotive (or any other type) starters ever used on a certified engine. For instance, is there a Delco automotive equivalent to the starter on a C85? Thanks, Wallace |
Wallace Berry wrote in message ...
Automotive alternators are sometimes installed on certified airplanes. Are automotive (or any other type) starters ever used on a certified engine. For instance, is there a Delco automotive equivalent to the starter on a C85? Thanks, Wallace The statute of limitations expired, so yes, I have had a C-85 generator rebuilt at an auto shop several times, made a nifty landing light flasher for about 8 bucks with parts from Pep Boys and know of others that have used auto parts. Now someone is going to come along and say that if you do and something happens and they find non-approved parts on your plane, you could get in trouble. I always had more important things to worry about. I'm sure that you could find an automotive starter to fit at NAPA. Or let the government inspect the one you want and pay 4.329 to 8.784 times more. Chances are that if you crash-land off airport, an FAA type will show up and merely check your pilot's certificate, medical and airworthiness certificate......in fact I'm absolutely sure of it...at least in one instance. I doubt that anyone would even think of checking to see if your starter was "approved." All you have to say in the rare event they did was: "That's the one that was on there when I bought the plane." Make sure you don't log an unapproved part. KJSDCAUSA |
![]() "Orval Fairbairn" wrote in message news ![]() I remember years ago my AI stating that "starters are NOT PMA equipment." This implies that ther is really no such thing as a "certified starter." I don't believe it. |
equipment." This implies that ther is really no such thing as a "certified starter." Sounds like an Old AI tale. If he meant OEM (Original Equipment Manufacturer) then he is most certainly wrong. Whatever starter the engine maker approved is the proper starter for that engine and is therefore approved or if you will certified. It will have a part number assigned by the engine maker no matter what number the starter manufacturer may have given it. Other starters may work by they ain't legal. PMA means Parts Manufacturing Authority and is the approval that after market makers of parts must get to have approved parts legally capable of being installed on approved equipment. John Dupre' John Dupre' |
In article , (Ken Sandyeggo) wrote: Wallace Berry wrote in message ... Automotive alternators are sometimes installed on certified airplanes. Are automotive (or any other type) starters ever used on a certified engine. For instance, is there a Delco automotive equivalent to the starter on a C85? Thanks, Wallace The statute of limitations expired, so yes, I have had a C-85 generator rebuilt at an auto shop several times, made a nifty landing light flasher for about 8 bucks with parts from Pep Boys and know of others that have used auto parts. Now someone is going to come along and say that if you do and something happens and they find non-approved parts on your plane, you could get in trouble. I always had more important things to worry about. I'm sure that you could find an automotive starter to fit at NAPA. Or let the government inspect the one you want and pay 4.329 to 8.784 times more. Chances are that if you crash-land off airport, an FAA type will show up and merely check your pilot's certificate, medical and airworthiness certificate......in fact I'm absolutely sure of it...at least in one instance. I doubt that anyone would even think of checking to see if your starter was "approved." All you have to say in the rare event they did was: "That's the one that was on there when I bought the plane." Make sure you don't log an unapproved part. KJSDCAUSA Thanks for the reply. I can probably find the correct certified starter for my C-85 used. However, I may very well look into trying to match up an auto starter. My C-85 is actually not a "certified" engine anymore as it has high compression pistons and a high performance cam. It is on my Stits SA6b which is obviously a plans built aircraft. For now I'm using the "Hemingway" starter. Didn't know for sure it was in an experimental...I know, "rec.aviation homebuilt." You can use anything you want on an experimental, log it and be legal. KJSDCAUSA |
I do not think that you will find an auto starter for your C-85.I have
looked for years.You might find an auto shop that will rebuild yours for you and like someone said,it is for your boat or airboat. |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
O-200 Parts Manual | Jeff | Home Built | 3 | August 1st 03 05:16 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
