Best homebuilt for ~700 nm commute
Old July 7th 08, 09:59 PM posted to rec.aviation.homebuilt
Default Best homebuilt for ~700 nm commute
Re the Tango (composite) and RV (metal) an article in July Sport
Aviation (pg 54) addresses Drag Coefficient as a function of
construction process. The multiplier for the Drag Coefficient for
composite is 1.0-1.05 and for flush rivet metal is 1.10. Composite
can reduce drag then by 5 - 10% over a metal constructed aircraft.
Food for thought.
Old July 8th 08, 11:54 AM posted to rec.aviation.homebuilt
denny
On Jul 7, 5:29�pm, Gig 601Xl Builder
Jay Maynard wrote:
The flip side: what happens when it collects hangar rash? Repairing aluminum
is well known; repairing composites is not.
Exactly, which along with the health related issues associated with
building a composite aircraft is why any of us still work with aluminum.
Old July 8th 08, 12:19 PM posted to rec.aviation.homebuilt
denny
I can't speak for other composite airplanes, but in building a
Tango 2 or Foxtrot 4, the whole construction process teaches you to
repair any hanger rash or major damage. In one case we had an
airplane damged that the insurance adjuster said to repair. He said
he would have scrapped it if it had it been aluminum. What does this
prove? Not much. One could throw corrosion into the discussion. If
one material was universally better than the other, the other would
disappear. Health issues? We haven't seen any.
Denny
Old July 8th 08, 01:37 PM posted to rec.aviation.homebuilt
Steve Foley
"Gig 601Xl Builder" wrote in message
m...
Aluminum is not necessarily good for your health either. The guy who used to
rebuild Piper Cherokee fuel tanks (Sky-something in NH) could not lift his
right arm over his head. He had spent too much time with a rivet gun.
Old July 7th 08, 10:34 PM posted to rec.aviation.homebuilt
Paul Hastings
"Jay Maynard" wrote in message
Food for thought.
Jay Maynard, K5ZC
http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (got it!)
Could you clarify that Jay?
The way I read it your saying that composite repair is not possible or much
harder than aluminum repair.
There are well established methods for repairing composite damage, without any
annoying rivet bucking noise.
Paul
Old July 7th 08, 11:57 PM posted to rec.aviation.homebuilt
Jay Maynard
any annoying rivet bucking noise.
Why, then, can't you get composite factory aircraft repaired short of
sending the broken part back to the factory?
Yes, I know the discussion is around homebuilts, but if composite repairs
are well understood, then there should be no reason to require all repairs
to be done at the factory.
Jay Maynard, K5ZC http://www.conmicro.com
Old July 8th 08, 12:11 AM posted to rec.aviation.homebuilt
Paul Hastings
Not knowing which factory you are speaking of, my guess is more of a company
policy issue for liability reasons. I know Northwest(I live in MN too) isn't
sending parts back to Airbus they are repairing them onsite.
So are many homebuilders with composite planes, imho composite repairs are
easier. Especially in your example of hangar rash, if you ding the leading edge
in aluminum How many rivets do you have to drill and rebuck if it is a single
piece leading edge. It gets even worse if you bend an aluminum spar.
Paul
Old July 8th 08, 12:27 AM posted to rec.aviation.homebuilt
Jay Maynard
I was thinking of the LSA market, as well as being told of one DA20 that
took out a landing light and was down for six months while waiting on
Diamond to fix it.
OTOH, damage that would bend an aluminum spar would break a composite wing
in half.
I don't mean to minimize the repairs required with aluminum, certainly...but
any A&P can deal with an aluminum repair. That's a major reason I ruled out
composite aircraft when I was looking. I would expect the same would go for
composite homebuilts. Sure, the builder might well be able to fix it - but
how well would the fix work, especially in the long run? How well would it
stand up to sun and weather?
Best homebuilt for ~700 nm commute es330td Home Built 33 July 22nd 08 11:26 PM
An Icy Commute Michelle P Piloting 12 December 7th 05 03:50 AM
Can anyone ID this homebuilt? JLB Home Built 9 April 29th 04 08:01 PM
OT? write-offs for business commute Chad Munroe General Aviation 10 January 16th 04 01:02 AM
OT? write-offs for business commute Chad Munroe Piloting 8 January 16th 04 01:02 AM
