radial engine torque
Old July 17th 08, 04:00 AM posted to rec.aviation.owning
Default radial engine torque
Hi,
I have noticed by watching the videos at http://www.fulldeflection.com
, that the radial engines of the Sukhoi etc, allow more vertical
penetration, but all the Red Bull Air Race planes have boxer engines.
I would have thought that the radials would have more engine torque,
thus pulling the planes around the course quicker.
I look forward to some expert input on this.
Superdoof.
Old July 17th 08, 05:30 PM posted to rec.aviation.owning
John[_9_]
On Jul 16, 11:00*pm, wrote:
Hi,
I have noticed by watching the videos athttp://www.fulldeflection.com
Superdoof.
I'm no expert but I know that during WW2 the USAAF decided to use only
radial engines on primary training aircraft, even those built with
inline engines were redeveloped with radials. The reason was because
the radial allowed for quicker climbs to altitude because the engines
remained cooler in the climb with all cylinders exposed fairly equally
to cooling air; level flight speed was not important on short training
hops. I would think the radial engined aerobatic aircraft would have
a similar advantage in climb rate but not so much in level flight due
to drag. Over the length of the Red Bull course the inline opposed
engines would have a speed advantage compared to the radials.
John Dupre'
Old July 22nd 08, 12:43 AM posted to rec.aviation.owning
On Jul 16, 9:00 pm, wrote:
Hi,
Superdoof.
Horsepower is a function of torque and RPM. Radials often
generate their HP at lower RPM so would need higher torque at the
lower RPM to get the same overall HP out of them. The radials you see
doing aerobatics are often the Russian ones, and they're geared so
that the engine runs at a higher RPM to produce more HP from a smaller
engine, while the prop turns fairly slowly and loses less energy to
drag and also allows a larger prop diameter and therefore better
vertical performance. The radial's drawback is its higher frontal drag
that limits forward speed, as someone already mentioned.
Dan
Help ! SMALL Radial engine Chris Wertman Home Built 12 July 18th 05 02:46 PM
Help ! SMALL Radial engine Chris Wertman Military Aviation 11 January 4th 04 08:22 AM
wtb: Runout Radial Engine Randy Aviation Marketplace 0 December 20th 03 09:45 PM
radial engine Randy Aviation Marketplace 2 December 3rd 03 02:28 PM
Neat old Helicopter with radial engine... Ditch Home Built 5 September 16th 03 11:32 PM
