A while back I posted that I had used Monokote trim to cover some of
the larger holes in my Speed Astir fuselage. They did a nice neat job of covering the holes, but here's the follow-up. I removed one a couple weeks ago that had been in place for a couple months. The mylar pulled off cleanly, but left the adhesive behind, and boy howdy was that stuff difficult to remove! Perhaps with the RIGHT solvent, it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do much but make it gooey. If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! |
Uncle Fuzzy wrote:
If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! I remember when I was a kid building RC gliders, sometimes the tinted adhesive would seep out from under overlapped seams. I took off the residue with 91% alcohol I got from the drug store. Mind you, that was around 30 y/ago. Possible the newer stuff has a different adhesive but I reckon its worth a try. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...aring/200807/1 |
Why not just ask the factory?
On Jul 18, 2:07*pm, John Smith wrote:
Why not just ask the factory? D'oh! Good idea. I must have made a pretty thorough mental disconnect from modelling (I only did it for 40 years or so) when I got into soaring! The 'edge seepage' from the IRON ON Monokote comes off easily. It's the stuff from the trim Monokote (press on) that's giving me trouble. I'll see if I can contact Top Flight. |
On Jul 18, 2:23*pm, Uncle Fuzzy wrote:
On Jul 18, 2:07*pm, John Smith wrote: Why not just ask the factory? D'oh! *Good idea. *I must have made a pretty thorough mental disconnect from modelling (I only did it for 40 years or so) when I got into soaring! The 'edge seepage' from the IRON ON Monokote comes off easily. *It's the stuff from the trim Monokote (press on) that's giving me trouble. I'll see if I can contact Top Flight. Many model covering manufacturers make an adhesive solvent that will soften the adhesive on normal covering so you can use it as trim pieces. I suspect this also cleans up the trim parts as well. For example Monokote has one see http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHZ43 If 3M cleaner did not take it off, I'd try acetone (which is also in the Monokote solvent). Darryl |
I stopped by my local sign shop and they turned me loose in their
"scrap box". The 3M vinyl is great for covering up bolt access holes in my Cirrus fuselage. They have great colors but white seems to be my old standby. |
Acetone or, (I think better) denatured alcohol. PeterK
wrote in message ... I stopped by my local sign shop and they turned me loose in their "scrap box". The 3M vinyl is great for covering up bolt access holes in my Cirrus fuselage. They have great colors but white seems to be my old standby. |
Uncle Fuzzy wrote:
A while back I posted that I had used Monokote trim to cover some of the larger holes in my Speed Astir fuselage. They did a nice neat job of covering the holes, but here's the follow-up. I removed one a couple weeks ago that had been in place for a couple months. The mylar pulled off cleanly, but left the adhesive behind, and boy howdy was that stuff difficult to remove! Perhaps with the RIGHT solvent, it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do much but make it gooey. If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! Try WD-40, and a plastic scraper (I used the end of a plastic ruler) and plenty of paper towels. Saturate the adhesive with the WD-40 and it will become gooey. Gently push the glue along with the plastic scraper until it makes a gob that's big enough to pick up with your fingers using the paper towels. You'll need to work one area at a time as the WD-40 evaporates. When you're done use some cleaner like 409 or windex to remove the residual WD-40. I've also used WD-40 and the softer paper towels to very gently remove tape residue from yaw string tape. |
Uncle...
The active ingredient in many adhesive removers is Toluene. You can buy this from Ace Hardware in quart cans labeled Toluol. It is cheap and it works. Use it outside to avoid breathing it. I also wear gloves to keep it off of my skin. Paul ZZ Uncle Fuzzy wrote: A while back I posted that I had used Monokote trim to cover some of the larger holes in my Speed Astir fuselage. They did a nice neat job of covering the holes, but here's the follow-up. I removed one a couple weeks ago that had been in place for a couple months. The mylar pulled off cleanly, but left the adhesive behind, and boy howdy was that stuff difficult to remove! Perhaps with the RIGHT solvent, it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do much but make it gooey. If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! |
On Jul 18, 1:22*pm, Uncle Fuzzy wrote:
A while back I posted that I had used Monokote trim to cover some of the larger holes in my Speed Astir fuselage. *They did a nice neat job of covering the holes, but here's the follow-up. *I removed one a couple weeks ago that had been in place for a couple months. *The mylar pulled off cleanly, but left the adhesive behind, and boy howdy was that stuff difficult to remove! *Perhaps with the RIGHT solvent, it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do much but make it gooey. *If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! Oh and I forgot. "Goo Gone" citrus based cleaner will probably knock this straight off. Maybe followed by a clean wipe of 3M cleaner, acetone or toluene, etc. I've used Goo Gone to take off residue of misapplied stripes similar to Monokote. Darryl |
| Thread Tools | |
| Display Modes | |
| Covering holes | [email protected] | Soaring | 9 | May 2nd 08 06:57 PM |
| Going of ver recommended TBO | gman | Piloting | 10 | October 11th 06 06:52 AM |
| Covering an ultralight wing with Monokote | Chris Wells | Home Built | 5 | January 10th 06 01:20 AM |
| When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 02:19 AM |
| Anywhere recommended near Rochester MN? | Dave | Aerobatics | 0 | April 1st 04 06:18 PM |
