SZD-36 Cobra 15
Old July 26th 08, 03:01 AM posted to rec.aviation.soaring
Default SZD-36 Cobra 15
A friend is considering purchasing a SZD-36 Cobra 15 glider. Comments
from anyone having owned or flown this model aircraft would be
appreciated.
Terry/DG800B
Old July 26th 08, 03:14 AM posted to rec.aviation.soaring
Paul Remde
Hi Terry,
I think that it is the type owned by Matthew Sawhill in Ankeny, Iowa. He
would be a good reference. ... Or is it his glider that is for sale? Did
he move up to something else?
Paul Remde
appreciated.
Terry/DG800B
Old July 26th 08, 12:26 PM posted to rec.aviation.soaring
On Jul 25, 9:14 pm, "Paul Remde" wrote:
Hi Terry,
Paul Remde
appreciated.
Terry/DG800B
Sawhill flies a Foka 4.
Old July 26th 08, 03:17 PM posted to rec.aviation.soaring
GK[_1_]
On Jul 25, 10:01*pm, " terry-
appreciated.
Terry/DG800B
Please make sure that you have the translated copy of Polish
Maintenance Manual from SZD!
It is a beautiful wooden glider however as with any construction it
requires preventative maintenance. There has been an accident in
Alabama where a roman screw retracted from the lower spar (due to a
wear of supporting bushing) and wings collapsed during a high speed
pass. Maintenance manual calls for periodical replacement of those
parts and such a glider would not have been airworthy in Poland.
Regards
GK
Old July 26th 08, 07:45 PM posted to rec.aviation.soaring
Martin Gregorie[_3_]
Default Off thread topic: Roman Screw? Que?
pass.
What is a roman screw?
Is it the same type of wing fixing that the SHK used?
I've not seen the term before and a web search failed to find a suitable
definition.
martin@ | Martin Gregorie
gregorie. |
org | Zappa fan & glider pilot
Old July 26th 08, 09:19 PM posted to rec.aviation.soaring
GK[_1_]
On Jul 26, 2:45*pm, Martin Gregorie
pass.
definition.
martin@ * | Martin Gregorie
gregorie. |
org * * * | Zappa fan & glider pilot
- http://pl.wikipedia.org/wiki/%C5%9Aruba_rzymska
Old July 26th 08, 11:07 PM posted to rec.aviation.soaring
Tim Taylor
On Jul 26, 2:19 pm, GK wrote:
On Jul 26, 2:45 pm, Martin Gregorie
pass.
definition.
gregorie. |
-http://pl.wikipedia.org/wiki/%C5%9Aruba_rzymska
In the USA it would be called a Turnbuckle.
Old July 27th 08, 12:41 PM posted to rec.aviation.soaring
pass.
definition.
gregorie. |
Same here, but how, exactly, does that attach the wings? I can understand
that it might pull them together and onto the fuselage pickup pins, but
what locks the spars together?
Martin Simon's 3-view of the Cobra shows the spars apparently meeting at
the fuselage centre line and some sort of circular hatch above their
meeting point: that's why I asked if the Cobra used a similar mechanism to
the SHK.
gregorie. |
Cobra Parts ventus2 Soaring 8 August 19th 05 04:57 PM
COBRA TALON, COBRA SPOT Allen Thomson Military Aviation 0 December 9th 03 06:44 PM
FS-Cobra Ed Hollestelle Soaring 0 November 4th 03 10:24 PM
Cobra Weapons Mike Keown Military Aviation 2 July 30th 03 07:43 PM
