12 Horsepower After it's successful flight at Kitty Hawk, upon its return to Dayton the Wright 'Flyer' underwent an extensive overhaul. The engine was fitted with spark plugs and a magneto, replacing the original make & break system. Whilst installing the magneto Orville discovered the original timing was so retarded that the engine's output was reduced by about half or about twelve horsepower. Timed correctly, the engine provided more than enough power to carry a passenger. This evening I was thumbing through a flyer of a different sort, this one from Harbor Freight, in which they offered a 13 hp engine for $370. The engine has a displacement of about 25 cubic inches and claims an output of 17 ft/lbs @ 2500 rpm. The Harbor Freight engine weighs78 lbs; the 'Flyer' engine ran about 200 lb. With forty feet of span and more than 500 square feet of area, I've no doubt that the Harbor Freight engine ...or even a pair of them ...could power a replica of the Wright 'Flyer,' although I can't imagine why anyone would want to do so. But the idea of using a Harbor Freight engine meshes neatly with a recent thread about a minimum flying machine. The Wright's drove their eight-foot propellers at about 1200 rpm through the use of a chain drive. Crossing the chain on one of the props gave them contra-rotation. Should a builder wish to produce a kind of power pod suitable for use on a variety of low-cost, light-weight airframes, the thirteen horsepower Harbor Freight engine, appears amenable to a 2:1 speed reduction unit. Since this is the ratio between the cam and crankshaft of all Otto Cycle engines, suitable belts and gearing is available at your nearest automotive salvage yard. -R.S.Hoover |
On Tue, 29 Jul 2008 20:44:23 -0700 (PDT), "
wrote: 12 Horsepower After it's successful flight at Kitty Hawk, upon its return to Dayton the Wright 'Flyer' underwent an extensive overhaul. The engine was fitted with spark plugs and a magneto, replacing the original make & break system. Whilst installing the magneto Orville discovered the original timing was so retarded that the engine's output was reduced by about half or about twelve horsepower. Timed correctly, the engine provided more than enough power to carry a passenger. This evening I was thumbing through a flyer of a different sort, this one from Harbor Freight, in which they offered a 13 hp engine for $370. The engine has a displacement of about 25 cubic inches and claims an output of 17 ft/lbs @ 2500 rpm. The Harbor Freight engine weighs78 lbs; the 'Flyer' engine ran about 200 lb. With forty feet of span and more than 500 square feet of area, I've no doubt that the Harbor Freight engine ...or even a pair of them ...could power a replica of the Wright 'Flyer,' although I can't imagine why anyone would want to do so. But the idea of using a Harbor Freight engine meshes neatly with a recent thread about a minimum flying machine. The Wright's drove their eight-foot propellers at about 1200 rpm through the use of a chain drive. Crossing the chain on one of the props gave them contra-rotation. Should a builder wish to produce a kind of power pod suitable for use on a variety of low-cost, light-weight airframes, the thirteen horsepower Harbor Freight engine, appears amenable to a 2:1 speed reduction unit. Since this is the ratio between the cam and crankshaft of all Otto Cycle engines, suitable belts and gearing is available at your nearest automotive salvage yard. -R.S.Hoover when people talk of lycosaurs and other dinosaur references to air cooled aircraft engines they miss entirely the measure of progress that the wright engine provides. the wright engine and a continental O-200 both have the same displacement. 12 hp vs 100 hp is not a bad measure of the improvements in engine technology. lycontisaurs ...phooey. is the harbour freight engine a V-twin? Stealth Pilot |
On Jul 30, 6:30 am, Stealth Pilot
wrote: is the harbour freight engine a V-twin? ------------------------------------------------------------------------------- It appears to be a one-lunger with a recoil starter. -R.S.Hoover |
On Jul 30, 10:51*am, " wrote:
On Jul 30, 6:30 am, Stealth Pilot wrote: is the harbour freight engine a V-twin? ---------------------------------------------------------------------------*---- It appears to be a one-lunger with a recoil starter. -R.S.Hoover This is a very insightful and thought provoking topic and I enjoyed reading it. The HF engine mentioned is a knock off of a Robin engine and is actually a fairly well made engine. I’ve found it interesting to see the larger HP rated Generic and B&S V twin engines turning up in aircraft projects and the re-drives fabricated for them. They’re less expensive then the imported engines and do a good job for their purpose. What they lack though is the 40 to 50 + HP range. This however has yet to stop innovative approaches and solutions to the problem by end users, i.e. us. |
Copperhead144 wrote:
This is a very insightful and thought provoking topic and I enjoyed reading it. The HF engine mentioned is a knock off of a Robin engine and is actually a fairly well made engine. I’ve found it interesting to see the larger HP rated Generic and B&S V twin engines turning up in aircraft projects and the re-drives fabricated for them. They’re less expensive then the imported engines and do a good job for their purpose. What they lack though is the 40 to 50 + HP range. This however has yet to stop innovative approaches and solutions to the problem by end users, i.e. us. The one I looked at at the local HF store looks like the Honda industrial engines of about 25 years ago. This would probably be about right since the Chinese have been copying the hell out of small Honda motorcycles. Tony |
It appears to be a one-lunger with a recoil starter. -R.S.Hoover This is a very insightful and thought provoking topic and I enjoyed reading it. The HF engine mentioned is a knock off of a Robin engine and is actually a fairly well made engine. I’ve found it interesting to see the larger HP rated Generic and B&S V twin engines turning up in aircraft projects and the re-drives fabricated for them. They’re less expensive then the imported engines and do a good job for their purpose. What they lack though is the 40 to 50 + HP range. This however has yet to stop innovative approaches and solutions to the problem by end users, i.e. us. I bought the 6.5 hp version 2 years ago for the gocart. Nary a problem, starts usually on the first pull and runs good after a decent warming period on half choke. Now its coupon priced under $103... |
OK, Bob. I'm not even an armchair engineer, so I'll ask the question. How much weight could that HF engine get off the ground and then at what cruise? Assuming, of course, that it could be geared suitably. And what propeller? Eight foot diameter? Suitable for a minimum parasol? For a Team Airbike? Thanks, Flash wrote in message ... 12 Horsepower After it's successful flight at Kitty Hawk, upon its return to Dayton the Wright 'Flyer' underwent an extensive overhaul. The engine was fitted with spark plugs and a magneto, replacing the original make & break system. Whilst installing the magneto Orville discovered the original timing was so retarded that the engine's output was reduced by about half or about twelve horsepower. Timed correctly, the engine provided more than enough power to carry a passenger. This evening I was thumbing through a flyer of a different sort, this one from Harbor Freight, in which they offered a 13 hp engine for $370. The engine has a displacement of about 25 cubic inches and claims an output of 17 ft/lbs @ 2500 rpm. The Harbor Freight engine weighs78 lbs; the 'Flyer' engine ran about 200 lb. With forty feet of span and more than 500 square feet of area, I've no doubt that the Harbor Freight engine ...or even a pair of them ...could power a replica of the Wright 'Flyer,' although I can't imagine why anyone would want to do so. But the idea of using a Harbor Freight engine meshes neatly with a recent thread about a minimum flying machine. The Wright's drove their eight-foot propellers at about 1200 rpm through the use of a chain drive. Crossing the chain on one of the props gave them contra-rotation. Should a builder wish to produce a kind of power pod suitable for use on a variety of low-cost, light-weight airframes, the thirteen horsepower Harbor Freight engine, appears amenable to a 2:1 speed reduction unit. Since this is the ratio between the cam and crankshaft of all Otto Cycle engines, suitable belts and gearing is available at your nearest automotive salvage yard. -R.S.Hoover |
On Jul 30, 11:41 am, "Flash" wrote:
How much weight could that HF engine get off the ground and then at what cruise? Assuming, of course, that it could be geared suitably. And what propeller? Eight foot diameter? Suitable for a minimum parasol? For a Team Airbike? -------------------------------------------------------- Dear Flash, I don't know. I'm not an engineer either... I don't even play one on TV. But the equation for flight sez the lift has to exceed the weight and the thrust must exceed the drag. Lift involves air foils and velocity -- for a given wing-area a particular wing will generate x-amount of lift at a given speed (or forward velocity). The 'Flyer' grossed-out at about 700 lbs (!!) with Orville on-board. It had about 500 square feet of lifting surface and its forward velocity was between 28 and 30 miles per hour. This is when you begin to appreciate the fact 'horsepower' does not appear in the flight equation :-) Abbott's 'Theory of Airfoils' tells you how much lift will be produced by a given airfoil at a certain speed and angle of attack. Manipulate that to find out how much wing-area you'll need to generate enough lift to overcome your weight. Not enough? then increase the size of the wing... but keeping in mind that one form of drag is a by-product of lift. You're liable to run out of thrust before you arrive at sufficient wing area. Torque can be manipulated to achieve the best match to a particular airframe. When that happens, the velocity of the thrust-slug will be a very close match to the cruise velocity of the airframe. This is where your loses due to drag will be the least. The real genius of the 'Flyer' is that the Wright's guesstimated 30mph as their flying speed and designed their system of thrust to match. They knew the rpm of the engine and how much torque it was producing at that speed. They geared this down and designed a pair of propellers capable of converting that amount of torque into thrust and achieved an incredible 82% efficiency in converting the available torque into thrust. (The typical light plane of today is lucky if it sees 60%). I think a more practical approach to the problem would be to define the airframe in terms of weight, thrust, speed and wing area. You may then manipulate those factors to see if your engine is a suitable match. For example, you might consider increasing the area of the wing.. Of course, doing so will increase the weight. Your goal is to see if you can arrive at a suitable compromise before the weight becomes excessive. An even more successful approach is to start with a clean sheet of paper. With the engine fully defined (or reasonably so :-) you know about how much work it can do. That can be translated into a wing having a particular air foil, chord and span, from which you can determine the weight of the wing. Those factors would be manipulated as often as requred to determine Worse Case -- which will tell you if the match WON'T work -- and the Nominal Case -- which tells you if the thing will work.. at least, on paper. -R.S.Hoover |
This is straight from Evans, a good starting place for understanding the mathematics of flight. Evans also developed a straight forward design spreadsheet that brings it all together as a performance estimate. It takes all the following and puts it in columns by airspeed from 40 to 200 mph. That is usually in range of what people design. But here, with only 13 hp, you would want to expand the low speed end of the table. Often, low and slow machines are dominated by parasitic drag. Open structure, lots of struts and wires. Guess high and then double it! That has implications on performance. Like cruise speed and stall speed at the same place on the clock? Also very little excess power for climb. (Lift HAS to be higher than weigh to climb ![]() When you have some idea of the drag estimate, the performance numbers can be estimated. Once the airplane is completed and flying one can actually measure all the parameters that were initially wild guesses. The Equations Basic descriptive equations - Equ 1..14 Drag in all it's many forms - Equ 15..19 Performance estimate - Equ 20..28 Equasions are numbered for reference. Variable definitions at end of the page CHAPTER 1 AERODYNAMICS ----------------------- GENERAL ------- (1) Q = .00256 V^2 (2) Gross Weight Estimate: Gross Wt.(1 place) = Payload /.35 Gross Wt.(2 place) = Payload /.40 (Payload = Persons * Baggage + Fuel) (3) Reynolds No. (RN) = 778 * c * V (4) V Stall (Vs) = 20 * sqrt((W/S)/CLmax) (5) Wing Area (S) = W / ( Q * CLmax) (6) Wing Area (S) = (391 W) /(V^2 * CLmax) (7) CL = W / (S * Q) (8) CL = 391 * W / (S * V^2) (9) Lift (L) = CL * S * Q (10) Lift (L) = (S * CL * V^2) / 391 (11) Span (b) = S /C (both the same - inches or feet) (12) Chord (C) = S/b (13) Wing Loading = W / S (14) Aspect Ratio (AR) = b/C or b^2/S DRAG ---- WETTED AREA DETERMINATION (Sw ) ------------------------- (If the airplane was totally immersed in water, all surfaces would be wetted.) (a) Add exposed wing and tail areas and multiply by 2.06 for curved area of top and bottom surfaces. (b) Divide fuselage length into a number of sections, Multiply perimeter of each cress section by its longitudinal width. Add rear surfaces. (c) Sum up all surface areas = S COEFFICIENT OF FRICTION (Cf ) ----------------------- Super clean Sailplane Cf =.003 Clean Q2, Dragonfly .005 Enclosed Basic Trainer, Mono .009 Open Biplane, Exp. Radial .014 (15) Parasite Drag (Dp) = Cf Sw q (16) Parasite Drag (Dp) = (D/q) x q ??? (17) Coef. Induced Drag (Cdi) = CL^2 /(Pi * AR) (18) Induced Drag (Di) = Cdi S q (19) Total Drag (DT)= Di +Dp Ercoupe = 4.4 Cherokee 180 = 3.9 Varieze = 2.1 Lancair 200 = 1.6 Q2 = 1.3 Dragonfly = 1.3 PERFORMANCE ----------- (20) Prop Eff. (n) = .85 (less for shorter props, more for longer) (at 3000 RPM n .5)!!! Prop n = .85/(1+( DT /Q * Prop Diameter^2) (21) Thrust HP Req. = D * V /375 (22) Max THP (Tm)= n(BHP) (23) Cruise THP(Tcr) = .75 (.90 for VW) (24) Climb THP (Tcl) = .90 (.95 for VW) (25) Level Flit THP Req (TL) = .00267 * (DV/n) (26) Excess THP (Te) = Tcl - TL (27) Rate Climb (RC) = (Te * 33,000) /W (28) THP req. climb = (RC * W) / 33000 WHE V = Velocity in MPH Persons = 170 pounds Baggage = 4 pounds each Fuel = 6 pounds / gallon C = chord in inches W = Weight in pounds (usually Gross weight) L = Lift in pounds D = Drag in pounds S = surface in Sq Ft rc = rate of climb in ft/Min n = effeceincy pd' = prop diameter in feet CLmax: Fabric = 1.2 Metal = 1.3 Composite = 1.35 * |
This was origonally written on a TRS80 (with line numbers and no WHILE)
As it, it should run under Qbasic interpreter, or compiled with QB45. Anyone who wants to play with it but doesn't have the software to run it can email me and I'll send a compiled executible file. FF = 0 TT = NOT FF doRun = TT KK$ = "LVSCQ?" 'initial values: L = 555 W = L A = 55 V = A * 1.4666 CL = 1.2 S = 125 CLS PRINT "Finite Wing Theory: ---== R. Lamb 1983 ==---"; : PRINT WHILE doRun = TT PRINT "solve for Lift Velocity Surface Clift Quit [LVSCQ?] "; Z$ = "" WHILE Z$ = "" Z$ = UCASE$(INKEY$): IF Z$ = CHR$(13) THEN Z$ = "" IF Z$ = CHR$(27) THEN Z$ = "Q" IF INSTR(KK$, Z$) = 0 THEN Z$ = "" WEND SELECT CASE UCASE$(Z$) CASE "L" PRINT " Calculate LIFT.............." GOSUB doLift CASE "V" PRINT " Calculate Velocity.........." GOSUB doVel CASE "S" PRINT " Calculate Wing Area........." GOSUB doSurf CASE "C" PRINT " Calculate Coef. of Lift....." GOSUB doCL CASE "?" 'GOSUB doDump PRINT " Variable dump:---------------------------" PRINT " Lift / Weight "; L; " lbs" PRINT " Airspeed "; A; " mph = "; V; " fps" PRINT " Coefec of Lift "; CL PRINT " Wing Area "; S; " sq ft" PRINT " -----------------------------------------" CASE "Q" doRun = FF END SELECT WEND END doLift: GOSUB GetSurf GOSUB GetVel GOSUB GetCL L = .001188 * CL * V * V * S PRINT " Lift = "; L RETURN doVel: GOSUB GetSurf GOSUB GetCL GOSUB GetWgt V = SQR(L / (.001188 * CL * S)) A = V * .681 PRINT " Velocity = "; PRINT USING "#,###.#"; A; PRINT " MPH = "; PRINT USING "#,###.#"; V; PRINT " FPS" RETURN doSurf: GOSUB GetCL GOSUB GetWgt GOSUB GetVel S = L / (.001188 * CL * V * V) PRINT " Surface = "; S RETURN doCL: GOSUB GetWgt GOSUB GetVel GOSUB GetSurf CL = L / (.001188 * S * V * V) PRINT " Coeff. Lift = "; CL RETURN GetSurf: PRINT " Wing Area (sq ft) ["; S; "]"; INPUT ""; X IF X 0 THEN S = X RETURN GetVel: PRINT " Airspeed (mph) ["; A; "]"; INPUT ""; X IF X 0 THEN A = X V = X * 1.467 END IF RETURN GetCL: PRINT " Coeff. Lift (#.##) ["; CL; "]"; INPUT ""; X IF X 0 THEN CL = X RETURN GetWgt: PRINT " Gross Weight (lbs) ["; L; "}"; INPUT ""; X IF X 0 THEN W = X ' steady state W = L L = X END IF RETURN |
| Thread Tools | |
| Display Modes | |
| q horsepower | Euro-Motors | Aerobatics | 2 | May 19th 08 01:25 AM |
| more horsepower | T-Bone | Piloting | 11 | March 20th 06 11:56 PM |
| Lycoming Horsepower Calculation? | Mark Doble | Home Built | 1 | June 20th 05 11:46 PM |
| Thermals and Horsepower | Ken Kochanski (KK) | Soaring | 14 | January 9th 05 06:50 PM |
| Horsepower | Andre | Home Built | 3 | July 18th 03 11:50 AM |
