The performance claims look extremely good ... is this plausible ?
http://www.dg-flugzeugbau.de/mandl-absaugung-e.html KK |
I love the timing. Right out of the XX playbook.
On Jul 30, 11:46 am, "Ken Kochanski (KK)" wrote: The performance claims look extremely good ... is this plausible ? http://www.dg-flugzeugbau.de/mandl-absaugung-e.html KK |
On Jul 30, 8:46*am, "Ken Kochanski (KK)"
wrote: The performance claims look extremely good ... is this plausible ? http://www.dg-flugzeugbau.de/mandl-absaugung-e.html KK Thanks for posting this! Sounds plausible to me, but what do I know? I DO know that at 70 knots, opening the vent in my Speed Astir (AKA the 'Grob Solar Sauna) will drive the altimeter down 100' instantly, so there is positive pressure to deal with. I also know that I have a perfect spot to make an 'experimental' vent that is completely removable. Increasing airflow in the cabin is more important to me than the performance gain. |
Dear Uncle
If your altimeter changes indications when you open the vent, that indicates your altimeter is not connected to STATIC. Best to check you plumbing. Guy Acheson, "DDS" On Jul 30, 9:16�am, Uncle Fuzzy wrote: Sounds plausible to me, but what do I know? �I DO know that at 70 knots, opening the vent in my Speed Astir (AKA the 'Grob Solar Sauna) will drive the altimeter down 100' instantly, so there is positive pressure |
On Jul 30, 8:17 pm, wrote:
Dear Uncle If your altimeter changes indications when you open the vent, that indicates your altimeter is not connected to STATIC. Best to check you plumbing. Or (dramatic pause) it means that someone (previous owner?) has chosen the cockpit as the static source. If this is the case, I think Mr Fuzzy just learned why it's an excellent BACKUP source and a poor primary one (hint-use a pneumatic toggle to switch to cockpit static only when your REAL static system is waterlogged/frozen) Use your ships actual static system. It works better than the cockpit. My 2 Pesos, -Paul |
On Jul 30, 9:48*pm, sisu1a wrote:
On Jul 30, 8:17 pm, wrote: Dear Uncle If your altimeter changes indications when you open the vent, that indicates your altimeter is not connected to STATIC. *Best to check you plumbing. Or (dramatic pause) it means that someone (previous owner?) has chosen the cockpit as the static source. If this is the case, I think Mr Fuzzy just learned why it's an excellent BACKUP source and a poor primary one (hint-use a pneumatic toggle to switch to cockpit static only when your REAL static system is waterlogged/frozen) Use your ships actual static system. It works better than the cockpit. My 2 Pesos, -Paul OR, Uncle Fuzzy decided that he'd like his ALTIMETER to read the same pressure as his FLIGHT RECORDER when the pneumatic switch is in the CABIN position on his line to the Altimeter. |
![]() Uncle Fuzzy decided that he'd like his ALTIMETER to read the same pressure as his FLIGHT RECORDER when the pneumatic switch is in the CABIN position on his line to the Altimeter. Now there is a thought.... Open the air vent if you are close to airspace to make the logger think you are lower, and fit an extraction vent if you want that height record. jim |
wrote: The performance claims look extremely good ... is this plausible ? http://www.dg-flugzeugbau.de/mandl-absaugung-e.html KK Ventus mods have used a funnel behind the wheel well for years, typically a 2" piece or pipe would form the exit. Improvement here is the shape of the exit. Regards Al |
On Jul 30, 12:43*pm, "
wrote: On Jul 30, 8:46*am, "Ken Kochanski (KK)" wrote: The performance claims look extremely good ... is this plausible ? http://www.dg-flugzeugbau.de/mandl-absaugung-e.html KK Ventusmods have used a funnel behind the wheel well for years, typically a 2" piece or pipe would form the exit. Improvement here is the shape of the exit. Regards Al Can someone e-mail more info on Ventus mods? Thanks, Andy |
Cockpit air vents | bartbrn | Home Built | 6 | April 26th 08 02:24 AM |
Trailer Vents... | Gary Emerson | Soaring | 1 | February 25th 08 07:38 PM |
Solar Vents | JJ Sinclair | Soaring | 2 | February 14th 08 01:36 PM |
Cessna air vents | Matt | Owning | 30 | January 14th 06 12:53 AM |
C172 Air vents | Matt Young | Owning | 8 | July 2nd 04 12:53 PM |
