OT Weather not be flown in
Old August 2nd 08, 02:54 PM posted to rec.aviation.ifr
Default OT Weather not be flown in
at least by this pilot anyway :-)
http://www.youtube.com/watch?v=VZTfTT-EiF8
Old August 3rd 08, 09:28 PM posted to rec.aviation.ifr
tscottme[_2_]
Yikes, that's some heavy rain. Thanks for posting it. I remember one time
departing FLL with a heavy shower off the departure end. The C-172 (and
some other single Cessnas) have the air filter in the front cowl under the
prop. When we got into the heavy rain it saturated the air filter and we
lost some power. After a second I guessed what was happening and aplied
carb heat, to take advantage of the indirect air flow bypassing the air
filter, and power came back, minus the small carb heat penalty. The CFII
beside me, not an A&P like me, closed the carb heat because it robs power
and the engine once again started breathign through the soaked filter. I
re-applied the carb heat and kept my hand on the the knob while telling the
CFI "soaked air filter, leave on the carb heat." A minute later we had
cleared the shower and went back to normal ops. It's the only time I've had
any engine trouble and it sure gets your attention.
Oh yeah, make sure you don't use a paper air filter in single Cessnas. I
think an AD prevents using paper filters any more. The single Pipers don;t
have this problem because of the configuration for induction airflow.
Scott
What Barack Obama learned from the Communist Party http://tinyurl.com/5bgbpu
Democrats to America's drivers: "Let them ride bikes."
http://tinyurl.com/5z5vg7
Old August 4th 08, 12:59 AM posted to rec.aviation.ifr
On Aug 3, 3:28*pm, "tscottme" wrote:
CFI "soaked air filter, leave on the carb heat." *A minute later we had
cleared the shower and went back to normal ops. *It's the only time I've had
Anytime the engine hiccups while airborne will raise that pucker
factor :-))
Another thing to be aware of when flying in heavy rain is to put your
pitot tube heat on. Only so much room to ingest fluids and drain it
out and this happened to me while I was IMC. My airspeed was
dropping, yet everything indication wise with AI, RPMs, VSI all
checked out straight and level. It was 58 degrees so icing wasn't a
factor.
My instructor told me to put on pitot heat and sure enough after a few
minutes, the airspeed came up to normal indications. He had that
happen to him so he recognized the problem waaaay sooner then me at
that time.
Sooo, anytime I am in precip in IMC, pitot heat goes on and stays on.
Old August 4th 08, 06:36 PM posted to rec.aviation.ifr
Everett M. Greene[_4_]
"tscottme" writes:
think an AD prevents using paper filters any more. The single Pipers don't
Mooney Super 21's have an air filter bypass that's supposed to
give a slight power boost at altitude. However, using the bypass
in certain meteorlogical conditions can result in injector icing
and has led to fatalities.
Old August 5th 08, 06:02 AM posted to rec.aviation.ifr
Jon Woellhaf
Yup. This could have killed me in April of 1989.
Everett M. Greene wrote,
Anyone flown atn LPV yet? Sam Spade Instrument Flight Rules 40 January 13th 07 10:28 AM
Warm Weather Pilots, Cold Weather Ops john smith Piloting 3 December 2nd 04 04:00 PM
has anyone flown with these ? Damian John Paul Brown Rotorcraft 4 April 16th 04 09:48 PM
has anyone flown with these ? Damian John Paul Brown Aviation Marketplace 0 April 15th 04 04:25 AM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 04:03 PM
