What can good one side 1/8 plywood be covered with for asthetics/
protection ? 1. paint - how much weight per square foot per coat after the paint dries? 2. glue on white vinyl wallpaper 3. glue on grocery store aluminum foil 4. other options |
![]() wrote in message ... What can good one side 1/8 plywood be covered with for asthetics/ protection ? 1. paint - how much weight per square foot per coat after the paint dries? 2. glue on white vinyl wallpaper 3. glue on grocery store aluminum foil 4. other options Give us a clue on where and what the application is. Inside an aircraft, outside of aircraft? Where on the aircraft? Or is an aircraft at all? -- Jim in NC |
Application is exterior on fuselage.
![]() wrote in message ... Application is exterior on fuselage. Personally, I would go with the fiberglass and resin. Fabric and dope works, but glass should last forever. Oh, I've been told that the surface under the glass must be as smooth as the finish you want to achieve. -- Jim in NC |
"Morgans" wrote: wrote in message ... Application is exterior on fuselage. Personally, I would go with the fiberglass and resin. Fabric and dope works, but glass should last forever. Oh, I've been told that the surface under the glass must be as smooth as the finish you want to achieve. Too heavy! Doped Ceconite (or Stits) essentially last forever, too, as long as you keep the bird hangared. And -- you can get a mirror finish, if you desire. The secret is lots of thin coats of dope, sanded between coats, then polished. -- Remove _'s from email address to talk to me. |
![]() "Orval Fairbairn" wrote Too heavy! Doped Ceconite (or Stits) essentially last forever, too, as long as you keep the bird hangared. And -- you can get a mirror finish, if you desire. The secret is lots of thin coats of dope, sanded between coats, then polished. Yeah, I hear you, but I think you are not thinking light enough on the weight or the fiberglass cloth. I'm talking the weight of cloth that would be used for model airplanes. I recall that using that, it is barely heavier than fabric and dope. Rich Shankland's Emerald used glass, I believe. Many Falcos go with glass. I don't doubt that fabric and dope is very good. I'm just putting the info out that glass is also an option, and one that many prefer. -- Jim in NC |
On Tue, 05 Aug 2008 23:13:44 -0400, Orval Fairbairn
wrote: In article , "Morgans" wrote: wrote in message ... Application is exterior on fuselage. Personally, I would go with the fiberglass and resin. Fabric and dope works, but glass should last forever. Oh, I've been told that the surface under the glass must be as smooth as the finish you want to achieve. Too heavy! Doped Ceconite (or Stits) essentially last forever, too, as long as you keep the bird hangared. And -- you can get a mirror finish, if you desire. The secret is lots of thin coats of dope, sanded between coats, then polished. Actually Model airplane glass is probably no heavier than Dacron and more durable. |
The fiberglass being proposed for this is not the standard layup glass
used for normal layups. It is a very light weight (.5 oz) cloth that is often used in boat construction to cover and protect teak and other exposed wood. It is so thin and light that it becomes transparent. Orval Fairbairn wrote: In article , "Morgans" wrote: wrote in message ... Application is exterior on fuselage. Personally, I would go with the fiberglass and resin. Fabric and dope works, but glass should last forever. Oh, I've been told that the surface under the glass must be as smooth as the finish you want to achieve. Too heavy! Doped Ceconite (or Stits) essentially last forever, too, as long as you keep the bird hangared. And -- you can get a mirror finish, if you desire. The secret is lots of thin coats of dope, sanded between coats, then polished. -- Remove _'s from email address to talk to me. |
In article
, " wrote: What can good one side 1/8 plywood be covered with for asthetics/ protection ? 1. paint - how much weight per square foot per coat after the paint dries? 2. glue on white vinyl wallpaper 3. glue on grocery store aluminum foil 4. other options Normally, plywood aircraft are covered with lightweight, doped fabric ("glider cloth"). See CAM 18. -- Remove _'s from email address to talk to me. |
![]() "Orval Fairbairn" wrote Normally, plywood aircraft are covered with lightweight, doped fabric ("glider cloth"). See CAM 18. Many are also using a very light grade of fiberglass cloth and resin if it is on the outside of the craft. That is what Falco recommends, IIRC. -- Jim in NC |
lightweight headset | John T | Piloting | 4 | July 5th 06 05:44 PM |
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length | Spar | Home Built | 4 | March 11th 04 11:31 PM |
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length | Spar | Aviation Marketplace | 4 | March 11th 04 11:31 PM |
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length | Spar | General Aviation | 4 | March 11th 04 11:31 PM |
lightweight helmet | Joa | Home Built | 16 | January 14th 04 08:59 PM |
