I came upon a Clarke sandblaster gun, filled it with abrasive, ran the
pressure up to 100 PSI and tried it out. this is a syphon type blaster that looks a bit like a paint sprayer. I know when spraying paint folks advise you to have something in the line to dry the air. Is a dryer necessary if I'm spraying abrasive? Has anyone had results they were please with using a sandblaster gun? - Mike |
On Aug 7, 2:39*pm, Michael Horowitz wrote:
I came upon a Clarke sandblaster gun, filled it with abrasive, ran the pressure up to 100 PSI and tried it out. this is a syphon type blaster that looks a bit like a paint sprayer. I know when spraying paint folks advise you to have something in the line to dry the air. Is a dryer necessary if I'm spraying abrasive? Has anyone had results they were please with using a sandblaster gun? - Mike What part of the world are ya in ??? Florida or some tropical place with the relative humidity that's close to taking a shower then I would install a dryer in the airline. If you are in Arizona, with 110f air and 4 % humidty then the part will never rust/corrode.. G Ben...... |
What I do is have a small dryer with a male and female quick disconnect that
I snap in line ahead of the gun when painting or using a sandblaster. You can pick these up for less than $10 at Princess Auto( Canadian version of Harbor Freight) Nothing worse than just about finishing a great paint job and have a drop of condensation sprayed over it! When sandblasting one drop of water can get the sand clogged or put little rust spots on bare steel. Disconnect the dryer and keep it in a plastic bag so it won't soak up moisture from the surrounding air when not in use.. Bob "stol" wrote in message ... On Aug 7, 2:39 pm, Michael Horowitz wrote: I came upon a Clarke sandblaster gun, filled it with abrasive, ran the pressure up to 100 PSI and tried it out. this is a syphon type blaster that looks a bit like a paint sprayer. I know when spraying paint folks advise you to have something in the line to dry the air. Is a dryer necessary if I'm spraying abrasive? Has anyone had results they were please with using a sandblaster gun? - Mike What part of the world are ya in ??? Florida or some tropical place with the relative humidity that's close to taking a shower then I would install a dryer in the airline. If you are in Arizona, with 110f air and 4 % humidty then the part will never rust/corrode.. G Ben...... |
I came upon a Clarke sandblaster gun, filled it with abrasive, ran the pressure up to 100 PSI and tried it out. this is a syphon type blaster that looks a bit like a paint sprayer. I know when spraying paint folks advise you to have something in the line to dry the air. Is a dryer necessary if I'm spraying abrasive? Has anyone had results they were please with using a sandblaster gun? - Mike From my past experiences in NE Ohio and Western PA, in the summer, with both siphon guns and pressure systems for abrasive blasting, you need good moisture traps and perfectly dry air. They will plug with damp abrasive. I have owned various models of both types of systems and currently use a pressurized tank blaster. |
I know when spraying paint folks advise you to have something in the line to dry the air. Is a dryer necessary if I'm spraying abrasive? Yes. Get the big, all-metal jobber from HF. It has a drain for any trapped water. Set you back $20 or so, but I have it bolted to the side of my compressor cart. The instances where you want water droplets in your compressed air are few and very far between. |
"Ernest Christley" wrote Get the big, all-metal jobber from HF. It has a drain for any trapped water. Set you back $20 or so, but I have it bolted to the side of my compressor cart. The instances where you want water droplets in your compressed air are few and very far between. To the OP: I made a homebuilt water trap, that seems to get the lion's share of the water and moisture out of the air before it can get to any desiccant type air dryer. Beware that a small desiccant will be wet and change color and be used up very quickly at the high airflow that sandblasting requires. Get a 6 foot length of 1-1/2" steel pipe, (or bigger, and bigger could only work better) and an assortment of fittings, to adapt it to a configuration like the following. You want to pipe your air supply into the bottom of the pipe, which will be used straight up and down. You will want to put the air into the pipe with a T fitting, so the air will be going into the T and traveling upwards, but a few inches lower than the T will be a reservoir area of a few inches of pipe and a drain petcock to remove accumulated water. I also put a quick disconnect on the inlet and the outlet to make it handy to hook up. After the air enters, it will travel upwards, but pretty slowly which will tend to let water drop out of suspension. Because it is in a big piece of steel, the air will also cool and condense and let more water drop out, and run down the pipe to be collected and drained out the petcock at the bottom. -- Jim in NC |
Plumbing your shop or hangar for compressed air is money well spent.
Use iron pipe, the size selected according to the run & volume. This should be defined by your local building codes. All runs should slope TOWARD the compressor. That is,any water would have to run UPHILL to find an outlet. Do not use copper nor plastic. ---------------------------------------------------------- Blasting media is also subject to contamination by moisture. It should be stored in air-tight containers. In the worse-case situation it may need to be dried before it can be used, a hell of a mess involving an oven and trays. For small parts you may wish to consider tumbling rather than blasting. -R.S.Hoover |
wrote in message ... Plumbing your shop or hangar for compressed air is money well spent. Use iron pipe, the size selected according to the run & volume. This should be defined by your local building codes. All runs should slope TOWARD the compressor. That is,any water would have to run UPHILL to find an outlet. Yep, agree, completely. In my case, I need to be portable, so my iron pipe cool-down trap is a good compromise. Another point worth mentioning. If your shop air plumbing is overhead, and it drops down to an outlet, don't use an elbow to turn out the line. It will funnel any water condensed in the down-line, right into your air hose. Instead use a T with a length of pipe below the outlet fitting, or even better, make the air line do a U-turn, then come back up to the outlet, with a drain at the low point. -- Jim in NC |
On Fri, 8 Aug 2008 02:50:05 -0400, "Morgans"
wrote: To the OP: I made a homebuilt water trap, that seems to get the lion's share of the water and moisture out of the air before it can get to any desiccant type air dryer. Done it. If all goes well (we're at 100% humidity at the moment), I'll try it tomorrow PM. or at least during the holiday weekend - report to follow - Mike |
"Michael Horowitz" wrote in message ... On Fri, 8 Aug 2008 02:50:05 -0400, "Morgans" wrote: To the OP: I made a homebuilt water trap, that seems to get the lion's share of the water and moisture out of the air before it can get to any desiccant type air dryer. Done it. If all goes well (we're at 100% humidity at the moment), I'll try it tomorrow PM. or at least during the holiday weekend - report to follow - Mike If you get tired of your trap fill up, you can get one automatically drains now at Grainger. I installed one two years ago, and haven't seen water in my 10 HP system since. |
| Thread Tools | |
| Display Modes | |
| In Memoriam: Arthur C. Clarke | WJRFlyBoy | Piloting | 28 | April 21st 08 03:11 AM |
| In Memoriam: Arthur C. Clarke | WJRFlyBoy | Owning | 26 | April 21st 08 03:11 AM |
| RIP: Arthur C. Clarke | Square Wheels[_5_] | Aviation Photos | 4 | March 19th 08 10:14 PM |
| David Clarke Reviews | Paul | General Aviation | 42 | April 21st 04 03:55 PM |
| David Clarke Reviews | Paul | Piloting | 52 | April 21st 04 03:55 PM |
