Hi,
I am building a diorama with a 1/48th scale B-17 at low altitude. It will have two engines turning and two shut down. My question is, would a B-17 have its landing flaps deployed at all at this lower speed and altitude if it was not landing, just hedge-hopping home? And if so, how much? Thanks, Walt |
Subject: B-17s at Low Level
From: Air Force Jayhawk Date: 3/12/04 6:14 AM Pacific Standard Time Message-id: On 12 Mar 2004 12:02:27 GMT, (WalterM140) wrote: Hi, I am building a diorama with a 1/48th scale B-17 at low altitude. It will have two engines turning and two shut down. My question is, would a B-17 have its landing flaps deployed at all at this lower speed and altitude if it was not landing, just hedge-hopping home? And if so, how much? Thanks, Walt I would doubt it. Flaps are designed to let you fly slower but increase the drag tremendously. If an airplane is crawling home wounded on less than full engine power, drag is the last thing you want. AFJ Unless of course the hydraulic system has been shot out in which case both flaps and landing gear would be down. As I vaguely remember it that hydraulic sytem in a B-17 worked off one engine.I don't remember which one. But I might be wrong about that, Check with a guy who flew B--17's to be sure. But you could justify showing it with wheels and flaps down if an engine is shut down. You might add a trail of smoke for reality. How about a red flare or two fired from the B-17 to show wounded aboard? Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
From: Dale Date: 3/12/04 7:53 AM Pacific Standard Time Message-id: In article , (ArtKramr) wrote: Unless of course the hydraulic system has been shot out in which case both flaps and landing gear would be down. As I vaguely remember it that hydraulic sytem in a B-17 worked off one engine.I don't remember which one. But I might be wrong about that, Check with a guy who flew B--17's to be sure. But you could justify showing it with wheels and flaps down if an engine is shut down. You might add a trail of smoke for reality. How about a red flare or two fired from the B-17 to show wounded aboard? The hydraulic system on the B-17 operated the cowl flaps and the brakes...nothing else. The gear and flaps were electrically operated. The hydraulic pump was electric, there is no engine driven pump on the B-17 so having an engine out wouldn't affect the hydraulics. I've got a little over 300 hours in a B-17. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html Thank you for the correction. I have zero hours in a B-17. My memory fails on that subject. What group did you fly with? ETO or PT? Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
(ArtKramr) wrote: Thank you for the correction. I have zero hours in a B-17. My memory fails on that subject. What group did you fly with? ETO or PT? Didn't fly 'em in the military...just did the airshow thing to impress the chicks. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
hydraulic sytem in a B-17 worked off one engine. That was the Lancaster, Art. One of the virtues of the Fortress so far as battle damage went was that it relied so little on hydraulics for the flight controls. Walt |
Dale wrote:
In article , (ArtKramr) wrote: Unless of course the hydraulic system has been shot out in which case both flaps and landing gear would be down. As I vaguely remember it that hydraulic sytem in a B-17 worked off one engine.I don't remember which one. But I might be wrong about that, Check with a guy who flew B--17's to be sure. But you could justify showing it with wheels and flaps down if an engine is shut down. You might add a trail of smoke for reality. How about a red flare or two fired from the B-17 to show wounded aboard? The hydraulic system on the B-17 operated the cowl flaps and the brakes...nothing else. The gear and flaps were electrically operated. The hydraulic pump was electric, there is no engine driven pump on the B-17 so having an engine out wouldn't affect the hydraulics. I've got a little over 300 hours in a B-17. Dale, with some time on them I'm sure that you'd agree that when limping home on two engines having your flaps or gear down would very likely ruin your chances of ever getting home, right?. -- -Gord. |
"Gord Beaman" ) wrote: Dale, with some time on them I'm sure that you'd agree that when limping home on two engines having your flaps or gear down would very likely ruin your chances of ever getting home, right?. At the weights I flew the airplane it performed fairly well on two engines, even so why stack the deck against yourself by adding drag. G On a hot day, or high field elevation having the gear/flaps out could certainly make a difference in the outcome. There was a bunch of discarded ammo and .50s from the continent to England for a reason. G -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
pretty much but it would depend on what altitude you were at and how far
away you were form home, i've read a few instances where they were just on the other side of the channel and made it; maybe not to their own base, but to somewhere like manston, or woodbridge or bellied in on a field. "Gord Beaman" wrote in message ... Dale wrote: In article , (ArtKramr) wrote: Unless of course the hydraulic system has been shot out in which case both flaps and landing gear would be down. As I vaguely remember it that hydraulic sytem in a B-17 worked off one engine.I don't remember which one. But I might be wrong about that, Check with a guy who flew B--17's to be sure. But you could justify showing it with wheels and flaps down if an engine is shut down. You might add a trail of smoke for reality. How about a red flare or two fired from the B-17 to show wounded aboard? The hydraulic system on the B-17 operated the cowl flaps and the brakes...nothing else. The gear and flaps were electrically operated. The hydraulic pump was electric, there is no engine driven pump on the B-17 so having an engine out wouldn't affect the hydraulics. I've got a little over 300 hours in a B-17. Dale, with some time on them I'm sure that you'd agree that when limping home on two engines having your flaps or gear down would very likely ruin your chances of ever getting home, right?. -- -Gord. |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Horsepower required for level flight question... | BllFs6 | Home Built | 17 | March 30th 04 01:18 AM |
| Q for Jim Weir or others: solid state fuel level probes? | Charlie England | Home Built | 11 | March 12th 04 01:35 AM |
| Heads up: threat level going to orange | richard riley | Home Built | 6 | December 23rd 03 11:49 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
