Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Hand Held Tach
Old August 20th 08, 03:19 AM posted to rec.aviation.misc
Brian Whatcott
Default Hand Held Tach
The radio modelers have developed a useful market for gadgets.
I bought a tach a while ago, and I keep meaning to mention it
here.
The price was right - around $25.
It's intended for measuring off two or three blade props.
In other words, it counts either two flashes or three as a revolution.
When I point it at this screen (Free Agent News Reader) it registers
1800 rpm i.e 60 flashes / sec if I select two blade, or
1200 rpm if I select 3 blade. If I point it at a compact fluorescent,
it indicates 3600 rpm (120 flashes/sec)
People apparently use it with reflective patches stuck on their props
Half inch numerals on an LCD display with a prop image (2 or 3 blade).
Battery lasts a long long time.
"Tower Hobbies Digital Mini-Tach"
Brian W
Old August 20th 08, 11:01 PM posted to rec.aviation.misc
James M. Knox
Brian Whatcott wrote in
here.
I modified one of those some years back... worked quite well. Never needed
any reflective patches for the prop of a real aircraft... works just fine
in daylight.
The two mods I made we
1. Changed the internal clock frequency so that it read out in tens of
RPM. The stock model I bought (only one they had back then) read out in
hundreds of RPMs. [Lots of model aircraft have props that turn in the tens
of thousands of RPM.]
2. Made the sensor a plug-in. This gave me the option of using it as
originally designed (fine for a SEL single), or on a cable from within the
cockpit (for a twin, with the sensor taped to the wing).
James M. Knox
TriSoft ph 512-385-0316
1300 Koenig Lane West fax 512-371-5716
Suite 200
Austin, Tx 78756
Old August 21st 08, 01:10 AM posted to rec.aviation.misc
Brian Whatcott
On Wed, 20 Aug 2008 22:01:34 GMT, "James M. Knox"
here.
in daylight.
James M. Knox
Suite 200
Austin, Tx 78756
I can see the virtue of that remote sensor mod. That would make it a
panel mountable.ay 2.5 X3.5 X 3/4 inch (about)
THe display goes to five digits now, so #1 mod would not be a concern
Brian W
Old August 20th 08, 11:54 PM posted to rec.aviation.misc
JGalban via AviationKB.com
What rpm should I expect if I'm using MS Outlook as a newsreader?:-))
Seriously, I've seen several folks using the hobby store tachs at the
airport. As far as I know, they don't require any patches to be stuck to the
prop. The big upside is that they cost about 10% of what specialized
aircraft optical tachs (Prop Tach, TruTach) cost. As with most things, if
it's for an airplane, multiply the normal price by about 10.
Message posted via http://www.aviationkb.com
Hand held non-aviation GPS john smith Piloting 11 November 27th 06 08:13 PM
Looking for a new hand held GPS Paul Tomblin Piloting 8 March 20th 06 12:38 PM
GPS Hand Held for Badges Papa3 Soaring 17 June 1st 04 09:12 PM
Hand Held Radios (Com + Nav)and GPS...Help? [email protected] Piloting 30 February 23rd 04 11:07 PM
Use of hand-held GPS on FAA check ride Barry Instrument Flight Rules 1 August 9th 03 09:25 PM
