Besides abrasive blasting, or sanding, how do you remove the black
scale from factory/Spruce fresh tubing? - Mike |
mhorowit wrote:
Besides abrasive blasting, or sanding, how do you remove the black scale from factory/Spruce fresh tubing? - Mike I've been told that you don't, and I didn't. Just give it a rough sanding to improve paint adhesion and paint it. |
On Sun, 31 Aug 2008 23:49:43 -0400, Ernest Christley
wrote: mhorowit wrote: Besides abrasive blasting, or sanding, how do you remove the black scale from factory/Spruce fresh tubing? - Mike I've been told that you don't, and I didn't. Just give it a rough sanding to improve paint adhesion and paint it. I like that - Mike |
On Mon, 01 Sep 2008 07:26:35 -0400, Michael Horowitz
wrote: On Sun, 31 Aug 2008 23:49:43 -0400, Ernest Christley wrote: mhorowit wrote: Besides abrasive blasting, or sanding, how do you remove the black scale from factory/Spruce fresh tubing? - Mike I've been told that you don't, and I didn't. Just give it a rough sanding to improve paint adhesion and paint it. I like that - Mike michael you should never abrasive blast aircraft parts. you bead blast them. the difference is that "beads" are round and produce a compressed surface which is resistant to fatigue failure. grit blasting uses sharp edged particles that can leave millions of sharp stress raising dents which may reduce the fatigue life. Stealth Pilot |
| Thread Tools | |
| Display Modes | |
| Gauge of tubing??? | Michael Horowitz | Home Built | 7 | June 6th 06 02:32 PM |
| 4130 steel tubing? | TJ400 | Home Built | 2 | May 30th 06 10:21 PM |
| how do I weld aircraft tubing | [email protected] | Aviation Marketplace | 1 | May 10th 06 09:39 AM |
| The Definitive Chord & Scale Bible - Literally EVERY chord and scale! | Kind of Blue298 | Home Built | 0 | February 8th 05 06:51 PM |
| Tubing strength | Ernest Christley | Home Built | 0 | January 17th 04 12:43 AM |
