Looks like the need for more than single seat fighters is becoming an
issue again. From the April Seapower: http://www.navyleague.org/sea_power/apr_04_16.php "Boeing's Ted Herman, business development manager for the F-18 program, told Sea Power the Super Hornet tanker helps "extend the legs" of the strike aircraft and does not compromise on aerodynamic performance. But the Navy is not entirely content with the Super Hornet as a tanker. While converted to refuel, the jet is not carrying weapons for strike missions. Fitzgerald said the Navy would consider a replacement for its C-2 logistics aircraft that may offer refueling capability. The C-2 replacement would either be the V-22 Osprey tiltrotor or the next model C-2. The Navy begins to retire the current fleet of C-2s in 2014. "We are thinking about whether we just have C-2 replacement planes for logistics, or whether we should buy some more that would be available for recovery refueling," Fitzgerald said." Instead of a C-2ish aircraft, I would suggest a modern analogue to what was arguably the most sucessful "CSA" the Navy produced: http://www.a3skywarrior.com/featurep...Det1_NG616.jpg And this "CSA" could carry up to 12,500 lbs of ordnance internally and had an *unrefueled* combat range of better than a 1000nm. Fifty years later there is gushing praise for 4000 lbs and 600 nm. http://www.a3skywarrior.com/cogdell/drop.jpg |
What a nice surprise, to jump on a newsgroup and see a plane my father
crewed in. |
sid wrote:
Looks like the need for more than single seat fighters is becoming an issue again. From the April Seapower: http://www.navyleague.org/sea_power/apr_04_16.php "Boeing's Ted Herman, business development manager for the F-18 program, told Sea Power the Super Hornet tanker helps "extend the legs" of the strike aircraft and does not compromise on aerodynamic performance. But the Navy is not entirely content with the Super Hornet as a tanker. While converted to refuel, the jet is not carrying weapons for strike missions. Fitzgerald said the Navy would consider a replacement for its C-2 logistics aircraft that may offer refueling capability. The C-2 replacement would either be the V-22 Osprey tiltrotor or the next model C-2. The Navy begins to retire the current fleet of C-2s in 2014. "We are thinking about whether we just have C-2 replacement planes for logistics, or whether we should buy some more that would be available for recovery refueling," Fitzgerald said." Instead of a C-2ish aircraft, I would suggest a modern analogue to what was arguably the most sucessful "CSA" the Navy produced: http://www.a3skywarrior.com/featurep...Det1_NG616.jpg And this "CSA" could carry up to 12,500 lbs of ordnance internally and had an *unrefueled* combat range of better than a 1000nm. Fifty years later there is gushing praise for 4000 lbs and 600 nm. http://www.a3skywarrior.com/cogdell/drop.jpg An A-3 size airframe would be handy for tanker duties. and could maybe also serve as a carrier-based mini-MC2A (combined AWACS/ELINT aircraft). Developing this would be relatively straightforward, assuming some money can be found. The problem comes when you try to make it a bomb dropper too. That demands a lot of more expensive design choices to keep the aircraft survivable against modern defenses (signature reduction, weapon delivery systems, etc.) That's not going to be affordable at all. Sure, a new A-3 could carry more bombs, but it woudn't strike more targets at once, which two or three JSFs can do. -- Tom Schoene Replace "invalid" with "net" to e-mail "Our country, right or wrong. When right, to be kept right, when wrong to be put right." - Senator Carl Schurz, 1872 |
"Thomas Schoene" wrote in message thlink.net...
http://www.a3skywarrior.com/cogdell/drop.jpg An A-3 size airframe would be handy for tanker duties. and could maybe also serve as a carrier-based mini-MC2A (combined AWACS/ELINT aircraft). Developing this would be relatively straightforward, assuming some money can be found. The problem comes when you try to make it a bomb dropper too. That demands a lot of more expensive design choices to keep the aircraft survivable against modern defenses (signature reduction, weapon delivery systems, etc.) That's not going to be affordable at all. There was a little blurb in AvWeek some time ago about the USN revisiting the idea of putting a refueling capability on the E-2s after some experiences in OIF. Wouldn't it be nice to have a trappable refuelable MC2 that could keep up with the strike package (I know, it would take way too much money for the ASEA style antennas to make that happen). I hesitate to open this can of worms...But what the hell. Faced with S-400, FT-2000, and ultra long range AAM threats, MC2A style aircraft will need susceptability reduction as well in the not too distant future. The idea that these aircraft can off unfettered in benign bastions and still do the job is one potential adversaries are actively attempting to dispell: http://www.aeronautics.ru/s400triumph.htm http://www.stormpages.com/jetfight/wwwboard/2359.html http://www.sinodefence.com/airforce/...nce/ft2000.asp So that money may be required no matter what a decade from now. Indeed, the Air Force is already looking at the BWB and MACK concepts for use as a stealthy KC-X aircraft in the 2015 timeframe. Sure, a new A-3 could carry more bombs, but it woudn't strike more targets at once, which two or three JSFs can do. What such an aircraft would offer is the abilty to loiter with more bombs per airframe, and also potentially carry something bigger than 2000 lb limit CVWs are saddled with today. And wouldn't it be nice for a carrier capable aircraft to deliver 8000 lbs out past 1000 nm unrefueled....But like you said, money for this won't be forthcoming. Thread drift: Did you that the A-3 was known to have even carried small cars... |
"Charlie Wolf" wrote in message
... I've been gone for quite a while (retired AWC - 1992) but I still don't fully understand why they are throwing away the S-3's?? Seems it's the answer to several of the things that have been mentioned in this thread... It would be. My best guess would be that the Hornet Mafia, wanting to use the Hornet for anything and everything wouldn't allow NAVAIRSYSCOM to even consider any other airframe. __!_!__ Gizmo "Welcome to NAVAIRSYSCOM, owned and operated by McDonell-Douglas, er Boeing" |
gizmo-goddard wrote:
"Charlie Wolf" wrote in message .. . I've been gone for quite a while (retired AWC - 1992) but I still don't fully understand why they are throwing away the S-3's?? Seems it's the answer to several of the things that have been mentioned in this thread... It would be. My best guess would be that the Hornet Mafia, wanting to use the Hornet for anything and everything wouldn't allow NAVAIRSYSCOM to even consider any other airframe. __!_!__ Gizmo "Welcome to NAVAIRSYSCOM, owned and operated by McDonell-Douglas, er Boeing" Ah, the F/A -18 Hornet "the Swiss Army knife of airplanes." A jack of all trades & master of none! Does it play the "Green Hornet" theme song on engine starts? :-P |
(sid) wrote in message . com...
Looks like the need for more than single seat fighters is becoming an issue again. From the April Seapower: http://www.navyleague.org/sea_power/apr_04_16.php "Boeing's Ted Herman, business development manager for the F-18 program, told Sea Power the Super Hornet tanker helps "extend the legs" of the strike aircraft and does not compromise on aerodynamic performance. But the Navy is not entirely content with the Super Hornet as a tanker. While converted to refuel, the jet is not carrying weapons for strike missions. Fitzgerald said the Navy would consider a replacement Here is a realted tidbit in the current AvWeek... Navy plans to continue dominating the world's oceans despite tight budgets will require, among other things, strategic aerial tanking that, in turn, will drive experiments with launching KC-130s from large-deck aircraft carriers, Rear Adm. Jay M. Cohen, chief of naval research, says at the annual Navy League convention here. The idea is to give Navy and Marine aircraft what Cohen terms "overland persistent tanking." Wonder how the Hornet Mafia would take to this... |
On 12 Apr 2004 13:59:03 -0700, (sid) wrote:
(sid) wrote in message . com... Looks like the need for more than single seat fighters is becoming an issue again. From the April Seapower: http://www.navyleague.org/sea_power/apr_04_16.php "Boeing's Ted Herman, business development manager for the F-18 program, told Sea Power the Super Hornet tanker helps "extend the legs" of the strike aircraft and does not compromise on aerodynamic performance. But the Navy is not entirely content with the Super Hornet as a tanker. While converted to refuel, the jet is not carrying weapons for strike missions. Fitzgerald said the Navy would consider a replacement Here is a realted tidbit in the current AvWeek... Navy plans to continue dominating the world's oceans despite tight budgets will require, among other things, strategic aerial tanking that, in turn, will drive experiments with launching KC-130s from large-deck aircraft carriers, Rear Adm. Jay M. Cohen, chief of naval research, says at the annual Navy League convention here. The idea is to give Navy and Marine aircraft what Cohen terms "overland persistent tanking." Some problems with using a KC-130 are.... a. getting them off the deck with a decent load b. conducting any other ops while the damn thing is on the deck (you're not going to be striking a Herc into the hangar without a lot of sawing). --- Peter Kemp Life is short - drink faster |
Peter Kemp wrote in message . ..
On 12 Apr 2004 13:59:03 -0700, (sid) wrote: (sid) wrote in message . com... Looks like the need for more than single seat fighters is becoming an issue again. From the April Seapower: http://www.navyleague.org/sea_power/apr_04_16.php "Boeing's Ted Herman, business development manager for the F-18 program, told Sea Power the Super Hornet tanker helps "extend the legs" of the strike aircraft and does not compromise on aerodynamic performance. But the Navy is not entirely content with the Super Hornet as a tanker. While converted to refuel, the jet is not carrying weapons for strike missions. Fitzgerald said the Navy would consider a replacement Here is a realted tidbit in the current AvWeek... Navy plans to continue dominating the world's oceans despite tight budgets will require, among other things, strategic aerial tanking that, in turn, will drive experiments with launching KC-130s from large-deck aircraft carriers, Rear Adm. Jay M. Cohen, chief of naval research, says at the annual Navy League convention here. The idea is to give Navy and Marine aircraft what Cohen terms "overland persistent tanking." Some problems with using a KC-130 are.... a. getting them off the deck with a decent load b. conducting any other ops while the damn thing is on the deck (you're not going to be striking a Herc into the hangar without a lot of sawing). --- Peter Kemp I'm just passing along what the Admiral had to say... Since Boeing is so wrapped up with wanting to continue finding uses for their geriatric aircraft types (767 and 737), they may as well reopen production of the A-3. |
| Thread Tools | |
| Display Modes | |
| Gulf Sickness Redux? | DunxC | Military Aviation | 0 | September 18th 03 07:36 AM |
| Nosewheel Shimmy and Scalloped Tire Redux, Plus | Larry Smith | Home Built | 2 | September 15th 03 05:03 PM |
| NA as alternate...redux | Bob Gardner | Instrument Flight Rules | 1 | September 11th 03 11:26 PM |
| Oshkosh 2003 Redux | Sydney Hoeltzli | Home Built | 97 | August 14th 03 05:29 PM |
| Lightspeed -- Was:Oshkosh 2003 Redux | Jack McAdams | Home Built | 8 | August 14th 03 04:19 PM |
