mode c intermittent
Old September 4th 08, 01:32 AM
skyav8r skyav8r is offline
Junior Member
First recorded activity by AviationBanter: Sep 2008
Default mode c intermittent
Howdy,
I have an Aeromech 8140B20 encoding altimeter with a KT76 transponder. Mode C is intermittent with ATC. Is it more than likely this is an altimeter problem or transponder problem? Sometimes when it is not reporting, i cycle the transponder off then back on and it starts reporting again. That works about 30 percent of the time, if that much. Thanks in advance,
Brian
Also, sould an aeromech and aerosonic encoding altimeter interchange as far as the connections are concerned?
Old September 4th 08, 05:31 AM posted to rec.aviation.owning
Orval Fairbairn[_2_]
skyav8r wrote:
Howdy,
reporting again. Thanks in advance,
Brian
Also, sould an aeromech and aerosonic encoding transponder interchange
Check for oil/dirt buildup on the TXP antenna. THere is usually a lot of
carbon in that stuff -- it can short out the antenna on Xmt.
Remove _'s from email address to talk to me.
Old September 4th 08, 06:49 PM posted to rec.aviation.owning
Mike[_22_]
"Orval Fairbairn" wrote in message
news
skyav8r wrote:
Howdy,
Brian
This is the most common problem and should always be checked first. The
radar sensor interrogates Mode3 2-3 more times for every ModeC
interrogation. So poor reception/transmission will show up on ModeC first.
I clean my antenna at every oil change, but my plane throws off almost no
oil. The more oil your plane goes through, the more often you should clean
the antenna.
Old September 4th 08, 07:02 AM posted to rec.aviation.owning
Robert M. Gary
On Sep 3, 5:32*pm, skyav8r wrote:
Howdy,
Brian
I've had this problem. Luckily each time its been right before our IFR
cert. My avionics guy says that there is some timing thing in the
transponder and it gets out of sync making it intermitant. The
avionics guy can tune it up and it will work great.
-Robert
Old September 4th 08, 06:20 PM posted to rec.aviation.owning
The Visitor
I had a similar problem in mine, then it got worse. Trouble was whenever
it was in the shop, it was working. Finally some guy thought to gently
heat gun the thing and found the failed part. I think it was a capacitor
that when warm, stopped working. It's had other problems too, like that
expensive final transistor going.
Just my experience....
John
skyav8r wrote:
Howdy,
Brian
Old September 4th 08, 07:13 PM posted to rec.aviation.owning
Tauno Voipio
John
skyav8r wrote:
Howdy,
Brian
The KT76 transmitter is a free-running electron-tube
oscillator built into a cavity resonator. The frequency
of the sent signal is dependent on the cavity and
electron tube properties.
When the tube gets old, its properties start drifting
around, and the transmitter frequency follows the
drift. The thing stays on channel for short while
after tuning and then gets off again.
The cure is the change of the transmitter module. The
tube cannot be changed from the cavity alone.
Tauno Voipio (CPL and avionics engineer)
tauno voipio (at) iki fi
Old September 4th 08, 09:16 PM posted to rec.aviation.owning
Mike[_22_]
"Tauno Voipio" wrote in message
John
skyav8r wrote:
Howdy,
Brian
If that were the case he would be having trouble with Mode3 also, and he
only indicated problems with ModeC.
Old September 5th 08, 02:58 PM posted to rec.aviation.owning
The Visitor
Well that is probably what they changed out for me one time it totally
failed. It was very expensive. Almost the cost of a new (different
brand) transponder. Now for new aircraft, dual transponders are the way
to go.
John
Old September 5th 08, 10:41 PM posted to rec.aviation.owning
Morgans[_2_]
"The Visitor" wrote
Now for new aircraft, dual transponders are the way to go.
Perhaps I am missing something obvious, but why would you need (or want) two
transponders for new aircraft?
Jim in NC
Old September 5th 08, 10:51 PM posted to rec.aviation.owning
john smith
Required if you fly above FL180 isn't it?
mode c intermittent skyav8r Owning 0 September 4th 08 01:32 AM
Intermittent failures all weekend Ron Natalie Piloting 5 March 25th 07 05:25 PM
Air Force investigating intermittent engine failure on aircraft. SPLASH-TWO Aviation Photos 25 November 23rd 06 06:34 PM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
C182 - Intermittent Alternator WinstonCup Owning 9 November 12th 04 12:22 AM
