Carb heat: my new policy. Any comments
Old September 6th 08, 05:58 PM posted to rec.aviation.piloting
Tman
Default Carb heat: my new policy. Any comments
Flying a lot of 152s and 172s with carb heat lately. When inbound, I've
been taught to pull the carb heat "on" downwind, hey actually use it as
a power control to slow the plane just a bit mid-field, and then more
importantly, just leave the thing on till clear of the runway and
cleaning up. No matter what the temp, humidity. And to have it on at
all times when the RPM is less than the green band. Kind of a preventative.
A few times I have been coming in on short final and needed a burst of
power due to a sudden downdraft, or needed to pour on a little juice
cause my approach was coming up just a bit short. Moving the throttle
forward 1/4 to 1/2 inch, i.e. giving it a little juice but certainly not
a go around type of thing, often times I would get a stumble, hicuup,
drop in RPM'S for 2-3 seconds before the horses responded.
Lot of convective turb lately and that power really comes in handy at
times on mid to short final. Kind of a shocker when the engine doesn't
respond quite nicely.
This has happened on a few birds, especially on hot days. I think
what's happening is the engine is just too rich, hey I've got the
mixture all the way in, it's hot (air less dense), and it's (way) hotter
with the carb heat on ( air much less dense), all enriching the mixture,
and when I put on a little power the accelerator pump in the carb
over-enriches the engine for just a little bit; causing the stumble.
Other pilots and the A&P just tell me to pour on the power a little slower.
I think I'm going to follow a new SOP. Turn the carb heat off on
mid-final. Reasoning: no carb, esp a warm one is going to ice up in 30
seconds, sets me up better for a go-around, and will prevent this
stumble business (I did test it out at altitude, and it prevents or at
least seriously mitigates the stumble).
thoughts?
T
Old September 6th 08, 07:33 PM posted to rec.aviation.piloting
Lonnie[_3_]
"Tman" x@x wrote in message
been taught to pull the carb heat "on" downwind, hey actually use it as a
importantly, just leave the thing on till clear of the runway and cleaning
up. No matter what the temp, humidity. And to have it on at all times
power due to a sudden downdraft, or needed to pour on a little juice cause
my approach was coming up just a bit short. Moving the throttle forward
1/4 to 1/2 inch, i.e. giving it a little juice but certainly not a go
around type of thing, often times I would get a stumble, hicuup, drop in
This has happened on a few birds, especially on hot days. I think what's
happening is the engine is just too rich, hey I've got the mixture all the
way in, it's hot (air less dense), and it's (way) hotter with the carb
heat on ( air much less dense), all enriching the mixture, and when I put
on a little power the accelerator pump in the carb over-enriches the
slower.
seconds, sets me up better for a go-around, and will prevent this stumble
business (I did test it out at altitude, and it prevents or at least
thoughts?
T
Shouldn't be a problem, but sometimes it happens.
Apply power a little slower.
or
Carry just a tiny bit of power on final. Sounds like you might be
approaching at cut off.
or
Bump a little power every 15 to 20 seconds to keep the engine clear.
Personally I wouldn't cut the carb heat.
Old September 6th 08, 08:03 PM posted to rec.aviation.piloting
Mike[_22_]
"Lonnie" @_#~#@.^net wrote in message
preventative.
the way in, it's hot (air less dense), and it's (way) hotter with the
carb heat on ( air much less dense), all enriching the mixture, and when
I put on a little power the accelerator pump in the carb over-enriches
slower.
thoughts?
T
or
or
Neither of which would do anything to prevent potential problems.
Because flight sim doesn't care either way.
Old September 6th 08, 07:40 PM posted to rec.aviation.piloting
a[_3_]
On Sep 6, 12:58*pm, Tman x@x wrote:
Flying a lot of 152s and 172s with carb heat lately. *When inbound, I've
cleaning up. *No matter what the temp, humidity. *And to have it on at
all times when the RPM is less than the green band. *Kind of a preventative.
cause my approach was coming up just a bit short. *Moving the throttle
times on mid to short final. *Kind of a shocker when the engine doesn't
This has happened on a few birds, especially on hot days. *I think
Old September 8th 08, 03:46 AM posted to rec.aviation.piloting
gpsman
On Sep 6, 2:40*pm, a wrote:
Best practice without a lot of experimentation is to follow the POH,
I hope I never let my rookie ass become so confident I consider
deviating from the POH based on my own anecdotal experience. Next
thing you know, you're an example of someone who made reasonable
conclusions except for a heretofore unknown exception.
There's a certain risk factor, also, I think, in deviating from one's
training and, I assume in this case, longtime practice.
The OP doesn't mention their typical strip, but I think they would be
best served by adhering to the POH and just aiming a little further
down the runway.
- gpsman
Old September 8th 08, 04:19 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
down the runway.
- gpsman
This is excellent advice and I add my voice to what you have said.
General aviation engines particularly Lycoming and Continental, handle
carb ice just differently enough that every aircraft POH should be
checked to see what the engine manufacturer recommends pertaining to the
use of carb heat, especially the exact circumstances where it is
recommended and the suggested procedure for it's use.
Pilots who alter the manufacturer's recommendations on the use of carb
heat anticipating a go around situation are potentially creating a
problem where no problem should exist.
There is no reason at all why a go around should necessitate an action
with carb heat that deviates from recommended procedure.
If you have to go around, simply follow recommended procedure.
Dudley Henriques
Old September 8th 08, 02:07 PM posted to rec.aviation.piloting
Tman
Couple things I want to add to some of the (kind of) opinionated but
helpful replies in this thread.
My C152 POH, and this is a late -70s model, does not give a clear cut
protocol for use of carb heat. It basically says use it when icing is
possible or suspected. I think it's standard practice to pull it on
power reduction for approach, but as you can see from the replies here
there are a variety of standard practices. If I read the POH literally,
I'd say turning the heat off when on short final is not contrary to what
it says, and is not really more in line with its suggestions than
leaving it full on till clear of the runway or go-around power is
needed. Does one suspect carb ice in the last 30 seconds of approach?
Well there are some anecdotes in this thread that raise the possibility
of that, so maybe I won't do this practice anyways, but either way there
isn't a sentence in the POH that says to leave that carb heat on till
the wheels are on the ground.
By the way, the topic of leaning on downwind for approach under high
density altitude conditions was brought up in this thread. The C152 POH
is almost silent on that also. It talks about leaning in cruise,
leaning for max rpm in a full power static runup when over 3000 DA, and
to place the mixture rich or "for smooth operation" on approach. I've
been taught the former, but another very experienced CFI told me to lean
it out "an inch" and push it in only if you need to go around. Both
pieces of advice I'd say consistent with the POH text, and both different.
FYI, the engine stumble in the original post happens at about 2000 DA days.
Just to go off on this tangent, one CFI I has says absolutely avoid
operating your Cessna Lycoming less than 1,000 RPM -- not enough oil
pressure to lube up the beast, and in fact there is an examiner that
will demerit you if you taxi at less than 1000 RPM on your checkride.
Now another CFI is adamant about taxiing at minimum possible power -- to
save the brakes. Both very respectable experienced CFI's, both with
reasons for their suggestion. And both suggestions are "not contrary"
to the POH guideline. So sometimes you gotta use your brain to
determine a good SOP, and solicit info on the pros / cons / risks to
make your own decision. But I'm not bending any of the guidelines in
the thin POH.
And as far as taking it to the A&P... We've talked about this. He says,
well grasshopper, you go the mixture full rich, it's hot, and you punch
in the throttle -- this is a carb engine, they sometimes stumble. It's
also pretty accepted performance around here by some of the other more
experienced pilots -- there recommendation is in line with a few of the
posts here -- some combination of: don't pull the throttle to cutoff,
lean it out on downwind, push in the carb heat on short final, push the
throttle in more slowly, and/or don't worry about the momentary
hesitation / stumble , it'll get ya used to the power delay when you get
flying turbofans. That last one a little tongue in cheek....
T
Old September 8th 08, 02:29 PM posted to rec.aviation.piloting
a[_3_]
protocol for use of carb heat. *It basically says use it when icing is
possible or suspected. *I think it's standard practice to pull it on
there are a variety of standard practices. *If I read the POH literally,
needed. *Does one suspect carb ice in the last 30 seconds of approach?
density altitude conditions was brought up in this thread. *The C152 POH
is almost silent on that also. *It talks about leaning in cruise,
to place the mixture rich or "for smooth operation" on approach. *I've
it out "an inch" and push it in only if you need to go around. *Both
pieces of advice I'd say consistent with the POH text, and both different..
save the brakes. *Both very respectable experienced CFI's, both with
reasons for their suggestion. *And both suggestions are "not contrary"
to the POH guideline. *So sometimes you gotta use your brain to
make your own decision. *But I'm not bending any of the guidelines in
the thin POH.
And as far as taking it to the A&P... We've talked about this. *He says,
in the throttle -- this is a carb engine, they sometimes stumble. *It's
flying turbofans. *That last one a little tongue in cheek....
T
deviating from the POH based on my own anecdotal experience. *Next
Take a look at your oil pressure gauge as you change RPMs. If it stays
acceptable, the engine manufacturer says there's enough oil pressure.
If you are running at low manifold pressures you have set up a
condition for carb icing, haven't you? I'd suggest it would be prudent
when landing to keep the carb heat on until touchdown, or until you
decide to go around. As has been pointed out here, carb heat and
throttle can be operated with one hand when advancing the throttle.
Why take the chance of growing some ice just when a deer runs on the
runway 500 feet in front of you while you're in the flare? Or, more
likely, someone has finished their run up and is taxiing out when
you're on short final? You have the carb heat on as insurance you'll
get power when you need it, don't cancel the policy prematurely.
Keep in mind this is written by someone who flies an injected engine!
Old September 8th 08, 03:05 PM posted to rec.aviation.piloting
the thin POH.
T
If the POH says to lean for smooth operation on downwind,
then do it if the carb heat makes it stumble. These carbs are designed
to provide a rich mixture at sea level, and when the DA is higher than
that the fuel:air mix can become too rich to run properly. WE operate
at a 3000' airstrip and the DA is at 5000' or more almost all summer.
You learn something about mixture, and you learn about carb ice on
clear days, too.
Lycoming's service manuals call for an idle setting of 650-750
RPM. I think they know a little bit about lubrication and so on, a lot
more than that CFI knows about engines. 1000 RPM is way too high and
just burns out brakes. The only place 1000 RPM should be used is when
the engine has been started from a cold-soaked state, and the oil is
still thick enough that it doesn't throw onto the cylinder walls too
well. Once it's warmed up some it's OK. If the oil pressure is falling
off badly at 650 RPM, the engine's bearings or oil pump or both are
shot and it shouldn't be flying. While we're on the subject of
dragging the brakes to control speed, if you go on to get a Commercial
ticket and do that to expensive airplanes, you might find yourself
looking for another job. Overheated brakes have been known to set fire
to tires and the whole airplane goes up in smoke.
As far as approaches go, we use the "plan-for-abort-unless-
everything's-good" training. Most landing accidents are a result of a
refusal to go around when things aren't lining up properly. Airspeed,
altitude, track---everything must be within reason or we just don't
land. SO, the carb heat is left on until we accelerate to get out of
there, and we don't slam the throttle open, either. Besides risking
stumble or outright failure, it's hard on the engine when cylinder
pressures rise so high at low RPM. Take two seconds to open the
throttle unless things are really urgent.
Dan
Old September 8th 08, 06:20 PM posted to rec.aviation.piloting
Stella Starr
Sounds pretty reasonable; you can't blame every engine stumble on carb
icing (or carb heat), and I remember watching a fellow student do
go-arounds and hearing the hiccup as he jammed in full power in the "go"
part of each touch-and-go.
Carb Heat [email protected] Rotorcraft 11 April 30th 07 06:34 PM
Carb Heat vlado Piloting 9 January 22nd 07 03:08 PM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 07:26 PM
Carb heat specs? Rich S. Home Built 2 November 13th 04 04:39 PM
Cherokee Carb Heat. Greg Esres Piloting 15 July 29th 03 02:25 PM
