I was looking at some pictures of an LS-1F..........does the fuselage
have a wing fairing? from the pix it appears the wings plug right in to the side of the fuselage like an LS-3. Does this model have auto-hookups? looks like maybe the elevator does. Also, is the F model Experimental? Thanks, Brad |
On Sep 9, 1:38*pm, Brad wrote:
I was looking at some pictures of an LS-1F..........does the fuselage have a wing fairing? from the pix it appears the wings plug right in to the side of the fuselage like an LS-3. Does this model have auto-hookups? looks like maybe the elevator does. Also, is the F model Experimental? Thanks, Brad Brad, No wing fairing on the fuselage. Some have add-on fairings that extend the wing-root, but I believe they stay on the wing. I believe Sam Giltner made his own fairings. You could check with him for more info on that. The factory also made add-on fairings, but don't know if they're still available. Probably not given the age. Elevator is the only auto-connection. The ailerons and spoilers are a blind connect (no access hatch), but very easy. Especially with sleeves. I use the LS sleeves on mine and love them. Mine is experimental, but most other owners I've talked to have standard airworthiness certificates. Let me know if you want more info, Dave |
EW to PDA question... | Bob | Soaring | 3 | September 15th 05 01:40 PM |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
OSH question | Bill Chernoff | Home Built | 8 | November 20th 04 01:07 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
